Hi,
I’ve recently been interested in P60 drop-ins, and have a few, plus several SolarForce hosts. I also happened to have bought a C8 light a couple of weeks ago, from Amazon:
http://www.amazon.com/gp/product/B00547SCXG/ref=oh_details_o01_s00_i00?ie=UTF8&psc=1
Amazon also has a C8 with an XML emitter, so I started wondering if there were drop-ins for C8, similar to how there are drop-ins for P60, so I could “upgrade” the C8 to an XML via a new drop-in. From searching, I gather that there aren’t, so, from more googling, I found that there was a TrustFire TF-R2 that had some of the better thermal design of C8, but that could take P60 drop-ins.
It wasn’t easy finding a TF-R2, but thanks to folks on BLF, I got pointed to a website, sobuying.com, that was supposed to have them, and I ordered one, but it looks like it’ll take several weeks to get here.
In the meantime, I got a couple of P60 dropins from SolarForce, the “Solarforce 880 Lumens U2 XM-L 3 mode”.
So I was thinking that if that drop-in worked with the C8, I could upgrade it to XM-L U2.
I removed the original C8 drop-in from the C8, removed the screw-on reflector from my SolarForce drop-in, and tried to put the SolarForce drop-in in there, but the opening in the C8 head/bezel was much too big.
Then, I got some aluminum foil, and folded it a couple of times so that I had about a 1/2” strip, and wrapped the SolarForce drop-in in that (with the big spring still on the drop-in), and then shoved (literally) the aluminum-wrapped SolarForce drop-in into the C8, from the front.
I then screwed the tube onto the head, and the bezel ring and lens, and put an 18650 in the light.
And, it worked!
The drop-in is pretty snug in the neck, and doesn’t move, and I left the light on high for over 30 minutes. The body got a little warm, but not too bad.
To me, this seemed to have worked out ok, so I was wondering, am I missing something? Also, in general, would I be able to do this with any C8?
I guess that from a lot of searching, I’ve seen various threads where someone would opine that P60 drop-in with C8 would be good, but if what I did is ok, then is there something wrong?
Thanks,
Jim
Edit: Here’s what it looks like in the C8 (using the original C8 reflector):
Jim
