So far nothing, except one Russian language site showing a Z2 taken apart, but I can’t tell how. Lost the link (sigh).
There’s this: Review: TrustFire Z2
Well, since I’m the first one to jump, I’ll post about the Moon M6 once I get it.
OK, I’ll compare the M6 to my “Z1 head on Z2 AA battery”
(I really like the Z1 setup — high/low/strobe, and it remembers the mode)
and also compare it to to a new Z2 I’d bought and not used
(My original Z2 switch died, after daily use — clicking through five modes frequently)
EDIT — the M6 arrived today.
Description at the “buyincoins” page is:
Mode: 3(High/Low/Strobe)
Battery: 1xAA or 1x14500(not included)
Voltage: 1.5-4.2V
Actual:
Mode: 5 (high/medium/low/strobe/SOS)
Battery: Does not light at all using any of these:
— fully charged NiMH rechargeable, Alkaline AA primary, Energizer AA lithium primary, or NiZn rechargeable
Lights up OK using a 14500 Li-ion
Black paint, not anodizing, no surprise.
Head is a slightly different shape than the Z1 or the Z2 — four flats with rounded corners; reflector on one of the flats; white painted labels on the sides:l “Cree R5” and “M6 M [icon] on”
Reflector cover unscrews just like the Z1/Z2 (part that holds the lens and a green glo-ring)
Actual reflector is either screwed down very hard or has threadlock glue, unlike the Z1 or Z2, with a white o-ring
LED looks exactly the same.
Clip is strong enough to feel secure over a belt, and its ‘grip’ spring arms hold tight around the groove.
It would probably pop off with some leverage and could be moved to the back or other side of the light easily enough,
but I like it where it is so am not moving it (not entirely convinced it’s springy enough not to bend if I pry it loose)
Verdict — ask me in a year or so. I was hoping it would be the promised 3-mode and alkaline-capable light.
My guess is, assuming I carry it like the Z2, the switch will wear out like the Z2 switch did, with daily use often in crosswalks.
The battery contact at the bottom of the head looks exactly like the Z1/Z2 — white plastic press fit or glued in.
The switch cover is the same green material, held down by the same threaded ring as the Z1/Z2, which unscrews easily.
Switch button looks exactly like the Z1/Z2 — black button in a white plastic ring coming up through the metal.
Seems assembled the same way, I guess the innards are all put in from the bottom of the head, press-fit or glued.
So, another non-repairable non-moddable light.
M6 and Z2 both weigh 70 grams, without battery.
The M6 has a thicker battery tube, but no tailcap magnet (and no little holes in the black plastic ring that holds the tailcap spring in place, it’s not easily removable (press fit?) — maybe that evens out the weight; could be there’s less metal in the head piece, I didn’t weigh those separately.
Tailcaps are not interchangeable.
M6, at least this one, has no mode memory— starts on high every time.
(Z2 and Z1 have proper mode memory, staying at the same setting)
Light produced:
M6 is a bit warmer and bigger hotspot; Z2 may be slightly brighter at all 3 levels, but that may just be the blue seeming brighter.
Z1’s low is quite a bit lower than either the M6 or the Z2.
Verdict: the Z1 remains my preferred light (on the Z2 battery case, with either NiMH or Li-ion).
Mode memory, and only high-low-strobe, so lots less clicking (and I haven’t worn out a Z1 switch yet).
