Test/Review of Duracell Plus Power AA
Official specifications:
  • Battery Size Code: AA
  • Battery Voltage: 1.5V
  • Nominal Internal Impedance: 181mOhm @ 1kHz
  • Battery Technology: Alkaline
  • Battery Terminals: Raised Positive and Flat Negative
  • External Diameter: 14.5mm
  • External Height: 50.5mm
  • Weight: 23.8g
  • Battery IEC Code: LR6
  • Battery NEDA Code: 15A
  • Operating Temperature Max: 54°C
  • Operating Temperature Min: -20°C
A primary alkaline cell from the local B&M store.
The capacity is good at low loads, but drops fast with increasing load as usual for alkaline.
Conclusion
Alkaline is not good for high current drain, but they work fine at low loads.
Notes and links
Great for clocks I suppose!
Great for a lot of things (Except when they leak), but not for flashlights.
