Review: FandyFire 2100
17 posts / 0 new
HID45
HID45's picture
Last seen: 5 years 11 months ago
FandyFire 2100 1-mode
Reviewer's Overall Rating: ★★★+
Summary:
Battery: 1X18650, 2X16340
Switch: Tailcap, reverse clicky
Modes: 1
LED Type: Cree XP-G R5
Lens: Coated glass
Tailstands: Yes
Price Payed: $17,10
Pros:
  • Hard Driven
  • Bright
  • GITD tail boot
  • Beam pattern, good throw/flood balance
  • Tailstands
  • Can use 2x16340
  • The name, man... the name.
Cons:
  • Build quality (with reservation, propably lot of variation)
  • 2x protected 16340 will not allow full tightening
  • Came unlubed
  • Knurling is quite shallow and dull
Ok. Ready to be FandyFired? Is your Fandy ready for some Firing? Prepare to see some Fire in your Fandy! This thing is just too hilarious. I can't stop smiling for this shiny tube. Not with descriptions like this floating around. I'm so childish *shakes head and laughs*. But let's try to get to business shall we. The item itself is no joke, it's one fine cheap shining thingy. There's also a 5-mode version available at the same price, but I got the single mode as I intend to mod this and I this driver is rated up to 8,4 volts, where as the 5-mode is just for 4,2. And I also wanted a high-voltage driver to be used in other project, I have plenty of max 4,2 drivers already.
Features / Value: ★★★
Well, again, what can I say (my second review and second 1-mode light...). It's a single mode flashlight. Pretty basic stuff. In addition to one mode of lighting it features GITD tail boot which I like. Some don't. Came with a strap, which is nice. There's also a silvery crenellated bezel which is propably aluminium. I'm about to bash it later, but let's just say I like the look of it. It gives the otherwise black light some contrast and is not stupidly aggressive, although it might eat couple of lumens.
Design / Build Quality: ★★★
The first thing I noticed when taking the light from it's box was that the bezel was loose. "That's ok", I thought, at least it's not glued or anything. I twisted if off and found out the bugger is actually not a bezel, as it has no use but to look cool. It has nothing to do with retaining the lens as that comes off from the inside of the light, not outside and is kept in place by the reflector. The light can be left without the "bezel", but then it looks kind of stupid. Like something was missing. Because there would be. Anyway.
While turning the bezel back to place I realized that it would not tighten. It would stay in it's place as in not fall off, but it rattles and turns by itself but it does not tighten at all. The threads were terrible, it literally just turned over the threads. Result? Some Finnish cursewords and well, now I do have a light with a glued bezel... Ok, enough chit chat, let's see some pics.
Here's a Fandy from behind (still laughing, can't help it)
Size comparison. From left L2P with (stupid) forward clicky, my STHF L2i, FandyonFire 2100, Shiningbeam S-mini and TrustFire Tr-803. It's a couple of millimeters longer than S-mini. Without that bezel thingy, or even Foybezeled they would be exactly the same size.
It tailstands. TR-803 does not. Here pictured when on for some heat testing. It does get hot (wait 'till you hear the amp readings) in 15 minutes, but not too hot to handle. It's not XML after all.
Some random parts. The reflector is quite nice. Not OP but not smooth eiter. I suppose you have some fandy fancy name to call it but I'll just say it's frosted. Gives very nice beam. Mostly floody with some throw, but no rings or dark spots whatsoever. Head came apart nicely, no glue there so it's good to go for modding.
Oh yeah, besides the bezel, there was a scratch in the head, outside the lens. Pic is bad but it can be seen on 11 o'clock on the head.
The tail parts. No spring there at all.
Trustfire flame going to Fandy. It's a pretty loose fit, but that's the case with these cells in every light. They are skinny. Cytac 2600 mah is near perfect fit.
Ok. Let's talk about amps for a while, as there were some unexpected results. DX claims that this light has digitally regulated 1,5mah driver. That's just a load of BS. And for once, not necessarily in a bad way, as I measured some serious amperage.
1 X 18650 @ 4,2V = 1,85A. Okay... they are relly driving that XPG...
2 X 16340 @ 8,15V = 0,90A.  Seems to be in line with what it's supposed to be regarding the previous result. But then...
2 X CR123 primary @ 6,4V = 1,7A! What the heck? There's over 10 watts (minus losses) going to that poor XPG.
What else... Hmmm... Well the knurling is bad. Just like L2P, when I want it to be like L2i. And it does not go on with 2 X protected 16340 if all the parts are fully tightened. It lights up when turned loose for just a fraction, couple of millimeters. 2XCR123 is ok fully tightened, no problem. Came unlubed. The threads were screaming for mercy (literally) when opening and closing for first times. Some CLP took care of that. No double O-rings, just one in every place there needs to be. Survived 10min dunk in the sink, so it's adequate.
Battery Life:
Haven't done any IRL testing, so can't really give a rating for this. But having only one hard-driven mode means it drains pretty fast. Depends how well regulated it is, one can expect somewhat over an hour of great brightness and decline from there. Starts to blink slowly when voltage drops to 3,4volts. I'm not liking that. I tend to let the cell protection take care of undervoltage.
Light Output: ★★★
This is the brightest XPG I have seen. It's brighter than standard S-mini. Quark Turbo R5 outthrows it, but Fandy outfloods the Quark big time. I have luxmeter coming in from MF so in couple of weeks (or months) I can do some serious output testing. I'd like to do some outside beamshots but the problem is there is not going to be dark outside before August. So all I have is these couple wall shots. And as I only have stupid automatic camera the exposure is not up to me so these are no good to judge the actual output, but maybe you get some idea seeing the output relative to other lights.
First, left is self-made P60 dropin XPG R4 driven at 1,4amps, right one is the FandygotFired. Fandy wins in all aspects. Hotspot size, spill size, hotspot brightness. Spill brightness is actually about the same.
Then an unfair fight. There's still the FandygotonFire and UF 3-mode XML T6 dropin on high. You can take a guess which is which. XML still rules the world, there's no arguing.
Summary: ★★★+
There's some quality issues, but in my case minor ones and there's bound to be big variation among units, so it's possible that the next one is fine. All the major thread seems to be ok. Not best I've seen even in budget class, but not bad either. XPG is really driven hard in this light and with it's great all-around beam pattern it will cover most flashlighting needs. Except when low mode is needed. It's versatile in what it eats and puts out lot of light. What's not to like. I actually almost gave up on the idea of modding this light. I like it how it is. I will propably still mod it, but later. I'm not liking the TR-803 I got the same time as standard so that will get to the feared modding workbench first. We'll see what to do with this one later.
I would give this light 4 stars, but the bezel incident plus blinking when cell is near empty drops the score by a little. I give it 3 plus.
Edited by: sb56637 on 08/26/2014 - 17:22
trooplewis
trooplewis's picture
Last seen: 6 months 1 week ago
Good review, but I'm sorry; it would have to do something totally cool and unusual for me to put a FandyFire in my collection. If you gave me one I would re-gift it. Looks like the name is stenciled on, not engraved, so maybe you could polish it off.
Rats, finally sold my 2010 509hp Mustang...now I can buy more lights!
Sold the red one too! Now guess what I drive, doing my penance for 500 hp commuters...
http://dreammustang.com/
http://i884.photobucket.com/albums/ac47/Ha
fishinfool
fishinfool's picture
Last seen: 8 months 13 hours ago
Awesome review HID!  I also have a problem with the brand name but it is a sharp looking flashlight.
Don wrote:
"But as I said long ago, you are more likely to be killed by a dead fish dropped by a seagull in the Sahara Desert than by a lithium ion
Buwuve
Buwuve's picture
Last seen: 2 years 10 months ago
Nice review and very good pictures.
One small question about your L2 with the GITD O-rings: Are they the 20mm o-rings of DX or do you use greater rings?
Light up the darkness.
Piers
Last seen: 11 months 5 days ago
It's rather a shame about the "bezel" as other than that fault it does look like a very nice light.
"The reflector is quite nice. Not OP but not smooth eiter. I suppose you have some fandy fancy name to call it but I'll just say it's frosted. "
VLOP, Very light orange peel Silly
HID45
HID45's picture
They are from a set of assorted GITD rings from Shiningbeam. They seem to be out of stock right now so can't link, but I think those are about 20mm rings. Maybe 21mm or something. The biggest ones from SB's set.
Be-Seen Triker wrote:
That switch is a new one on me.  Any change to get a make and model off of it?
I think that the one who sets the Fandy on Fire might wanna stay anonymous...
Naah. No chance. There seems to be some markings on it. I will take a closer look when I get home.
And what's with the layout of the review? There seems to be huge cap between the title Summary, and the actual summary box. When editing, they are close to each other, just like they need to be. The box right below the title. Help needed. Mr Administrator? Someone!
edc
edc's picture
Last seen: 4 years 5 months ago
If only it was called fannyfire I might consider it.Surprised
http://i1193.photobucket.com/albums
agenthex
agenthex's picture
Last seen: 6 years 4 months ago
That's seriously overdriven for a 1-mode small light...
Typo amp for volt in first para.
Seems like a decent light w/ 5 mode. I have a lot of p60 hosts and drop-ins, but recently have found a new appreciation for dedicated lights like tr-803. I find that I rarely change the drop-in's anyway once they find an appropriate home. Might have to add this one to the list.
Reading this makes you smarter: http://lesswrong.com/
sb56637
sb56637's picture
Last seen: 9 min 1 sec ago
Nice Job HID45, thanks a lot for the nice review! It never ceases to amaze me how guys from your region speak English as a second (or 7th) language so perfectly as to even pick up on the humorous pun of a name like "FandyFire". Frontpage'd and Sticky'd.
It seems to me I saw a multi-mode version of this light as well. Do you just prefer a simple 1-mode light for your needs? A single mode Li-Ion light just doesn't work for my needs, usually too much light and too hot.
HID45
HID45's picture
Thanks. It most likely has something to do with the fact we watch american TV-series and movies from day one and we play video games. A lot. And they all are in English. And nowadays with the internet... Using English in one form or another is pretty much everyday thing for most ppl regardless of age around here. I sometimes feel sorry (or pity, at least) for Central European folks because they get everything (movies, games, series) dubbed to their language, so they don't get to learn English in their everyday life without actually having to do anything.
The multimode one is lot more versatile and better for most folks. I don't prefer one mode either, but I'll mod the light anyway and saw more need for high voltage driver in future projects than multimode low voltage one, so I went for that. I'll put modded Nanjg 105 to this one and use the standard driver in some silly project later.
how2
Last seen: 5 years 3 months ago
Guys there is nothing wrong with the name.
Man-up. Yell
I can handle this name.Cool
Piers
I don't really care that apparnetly the name has another mneaning. My problem with it is that it's just a silly name!
I just wish we could find out why they called it that.
HID45
HID45's picture
Make yes, model... don't know, you decide. If you look at the pic with the switch parts. In the white switch housing it says "Omten". Nothing else. Then on the board, you can see P48 on this side. It says P49 on the othere side in the same place. Then there is markings J2 and either HS008C or HS00BC. Hard to decide, my guess would be the "8" one.
KingGlamis
KingGlamis's picture
Last seen: 8 years 7 months ago
Great review, love to see some humor thrown in.
I ordered the 5-mode version even if it does have the same silly name. Looking forward to firing Fandy. Big Smile
I've got lots of bright ideas.
cabfrank
Last seen: 32 min 29 sec ago
but just read it, and that was a funny and great review! great job, thank you.
Rockspider
Rockspider's picture
Last seen: 11 months 1 week ago
Reviving old thread, I just received a Fandyfire 2100 XPG R5 from DX, 5 mode version.
Pretty amazing! I was shocked at the amount of light this little guy throw out, and made some comparisons: it blows away the IO EDC with XP-G2, and is almost on par with a UF 2100 with XM-L, but with less spill and tighter hotspot.
Nice thing (to me at least) it has a perfectly SMO alu reflector.
Had to take DMM readings twice 'cause I couldn't believe those numbers!
2,35A on high (!!!)
1,14A on med
0,24A on low
(could not measure strobo and SOS)
Those are tailcap readings, not emitter, but anyway that's over the edge of safety for an XPG, but now I understand why it's so bright!
After all, the EDC with XP-G2 is driven at only 1,4A on high. Not a fair comparison.
Considering the added resistance of switch and the efficiency of the driver, I'd say the emitter should see around 2,2A, which from Match graphs is about the top of the lumen curve for an XPG before the diminishing return, and should be approaching 450lm when cold.
Impressive!
Yes the thing gets hot in a few minutes, but by hand comparison the heat is anyway less than the XML 2100.
I feel this little bad boy is a perfect candidate for an XP-G2 swap Laughing
Speedsix
I was a little put off by the name until I got my first Fandyfire. It was a DX special for $12 or something on the wonderful Fandyfire HD2011. It is still one of my favorite lights. The build quality is great. It puts out a smooth, even wall of bright light that is simply a joy to behold.
Despite the name, I am a big Fandyfire fan. They seem to be a cut above the other budget lights like Uniquefire.
