What exactly does a toroid do, and what would happen if I replaced a small toroid with a larger one?
An inductor resists changes in electric flow by storing energy magnetically. It smoothens fluctuating currents, and using a bigger inductor may or may not alter the circuit significantly. It’s used in buck and/or boost circuits to regulate voltage and current.
Here’s some excellent info by Le Quack at LPF:
You mean besides oppose changes in current flow? It’s basically just a very-efficiently-made Inductor.
Hopefully this will generate some useful discussion!! It’s hard to answer, for some reason.
I’m grinding down the same trail, so I can maybe be some small help, but only as another traveler may remember a certain watering hole or cave along the way.
It’s funny, to me, how the answer that question is so-often a description of what it does, not how it does it. The physics interests me the most, but I’m weird that way. [/watering hole]
Sorry. What do you mean by “small” and “large”? Physical size isn’t a reliable indicator of performance, is why I ask…
Inductance (in Henries) of a Toroid is determined by the material of which it’s made (or not made, in an air-core inductor) and the number of wire turns taken around it. AFAIK, the smallest possible Inductor is a simple single turn of wire in the air.
Generally, higher (or “larger”) inductance results in a lower resonant frequency, in RF applications.
To finally answer your question, in a tuned resonant circuit, changing the Toroid to one with a different Inductance will probably just wreck it. Getting a different physical size with the same Inductance might change how much net current you could carry, but only through that component (not necessarily the rest of the circuit supporting it).
Sorry to wander. I hope to cull this post to its essence as this discussion takes off — hint, hint! (Time to hear from them what knows what to know!) :party:
