IS: Hobby 3D Printing Service
85 posts / 0 new
CalvinIS
CalvinIS's picture
Hey guys, we've decided to start offering some limited 3D printing services for people who are interested in that sort of thing as a side hobby. We have an UP Plus 2 3D printer with red, orange, yellow, green, blue, white, and black ABS plastic. We've been using it to print out 3D cases for the Radiant Electronics LPM and various things found online.
Max print size: ~ 4.5" x 4.5" x 4.5"
Pricing will vary by size but we plan to make it very reasonable. PM me for more details.
Please note this is not a professional service, we do not offer design services and require the STL, UP3, or UPP files.
Quick overview on 3D printing:
Plastic is essentially melted and squeezed through a nozzle and the object is drawn in the 3D plane. Because the printer can only print layers at a time the strongest part is when force is applied perpendicular to the piece. The best analogy I've heard so far is that 3D printing is like making things with legos, it's strong when you push down on it but weak on the sides as the pieces pull apart. The final product is NOT printed as a solid piece like injection molding but made of very fine layers that adhere to each other, in the picture below you can see the horizontal layers. 3D Printing is often used in rapid prototyping for proof of concept pieces and it should be noted that the end printed product should only be considered as a toy.
A great place to look for 3D files is at http://www.thingiverse.com/
Free CAD Software:
http://www.openscad.org/
http://www.sketchup.com/ (choose educational free version)
Printing: http://www.thingiverse.com/thing:53451
Illumn. Instagram. Facebook.
If I don't answer your PM I'm not ignoring you, please PM me again in case it got lost under a stack.
Edited by: CalvinIS on 01/27/2014 - 15:00
leaftye
Last seen: 20 hours 29 min ago
Nice. I bet I could come up with a few things.
The low mode should be lower.
Reviews: Efan IMR18350 700mAh 10.5A, <a href="http://
mizjif
mizjif's picture
Last seen: 1 day 21 hours ago
I really want to start designing and printing my own fishing lures. Awesome new toy! This is a very cool service to offer.
moderator007
moderator007's picture
Last seen: 4 hours 42 min ago
I need a 32650 battery holder to use 2 batteries in parallel for a friends hobby charger. I need the holder to keep it simple for him to charge the batteries. PM with details on what I need to do and perceived cost.
I had considered making him one out of kydex, but this looks a lot easier and more professional.
Bort
Bort's picture
Last seen: 1 week 1 day ago
I wish i had the ability to make designs to send for printing, but i have nothing
The Journal of Alternative Facts TM
"It is critical that there is a credible academic source for the growing and important discipline of alternative facts. This field of study will just keep winning, and we knew that all the best people would want to be on board. There is a real risk in the world today that people might be getting their information about science from actual scientists"
CalvinIS
CalvinIS's picture
moderator007 wrote:
I need a 32650 battery holder to use 2 batteries in parallel for a friends hobby charger. I need the holder to keep it simple for him to charge the batteries. PM with details on what I need to do and perceived cost. I had considered making him one out of kydex, but this looks a lot easier and more professional.
We don't offer design services, just printing.
EDIT: I did some quick research, here's a parametric battery case: https://www.thingiverse.com/thing:5051 it's possible you would be able to edit it to fit your required dimensions.
http://www.sketchup.com/download
Sketchup Make is free to download, just select educational use.
Alternatively people who already have a CAD background can just export as an STL file from SolidWorks, Autodesk, etc.
Dweano
Last seen: 2 years 6 months ago
ABS? I am new to the 3D printing game, but what does the stuff end up as? Hard plastic? Something that would hold up to moderate use? Such as a magazine follower? If so…i am interested
CalvinIS
CalvinIS's picture
Dweano wrote:
ABS? I am new to the 3D printing game, but what does the stuff end up as? Hard plastic? Something that would hold up to moderate use? Such as a magazine follower? If so...i am interested
It ends up coming out as hard plastic yes but strength is based on thickness, you can even make threads with it. Another issue is that strength is better on certain planes due to the nature of 3D printing and the orientation of the print. For example, below is an 18650 battery carrier we printed. If you look really closely you can see the layers on how the 3D print was made. The weak point in this particular print is in the neck where the threads are as that is where the walls are thinnest. I threw the carrier around and that was the breaking point, otherwise it is reasonably strong.
People have designed and made all sorts of things from moving gears to flashlight holders: http://www.thingiverse.com/search/page:6?q=flashlight&sa=
nitro
nitro's picture
Last seen: 6 months 1 day ago
make a 3×18650 battery holder and all u would need to have made is copper tabs ?
CalvinIS
CalvinIS's picture
nitro wrote:
make a 3x18650 battery holder and all u would need to have made is copper tabs ?
Basically yes. There are quite a few battery holder designs, but not many in specialized li-ion form: https://www.thingiverse.com/search/page:1?q=battery&sa=
Bort
Bort's picture
Thank you, i will look into it
CalvinIS
CalvinIS's picture
Bort
Bort's picture
If memory serves ABS is what they use to make Lego
nitro
nitro's picture
radio shack has this kit for $1500
i like this https://www.thingiverse.com/thing:33706
CalvinIS
CalvinIS's picture
Gear printed and moving.
Dweano
So how much do you charge? Say I wanted something made up how would I go about doing it? Also I have been messing around and it looks like sketchup saves as .SKP. Can that work or does it need to be converted?
CalvinIS
CalvinIS's picture
We're kind of making it up as we go along, we'll probably charge based on print material volume. I believe you can export Sketchup files to STL. It's highly experimental since print settings will be different depending on the intended use of the object. We've been testing out different materials mostly for our own product housing and seen good results. The only problem I can foresee is if the design people submit isn't structurally strong enough because the "walls" are too thin, which is why we don't want to offer a design service because we don't have enough experience in structural and material design. This is more of a test hobby service we're offering on the side since we have the machine available and as we pick up more knowledge we may make it more official. The time requirement for 3D printing is pretty high especially if a print doesn't work out. The Radiant Cases we have take over 2 hours to print.
Dweano
Interesting. Well if you need someone to give you a trial run I did just make my first thing in sketchup haha
CalvinIS
CalvinIS's picture
Using OpenSCAD I downloaded and modified a parametric battery holder. http://www.thingiverse.com/thing:5079/
I entered in some rough measurement for a dual 32650 holder, this particular design looks like it requires some screws, nuts, and bolts. You can even set the dimensions of the spacing between the batteries, size of the nuts, bolts, and screws using OpenSCAD (free software).
I went and generated a triple 18650 holder as well:
What have you sketched up?
lightme
lightme's picture
Last seen: 2 years 4 months ago
Nearly all the plastic you see on cars and bikes is ABS so you know it’s durable. Welding is about the only way to repair it. Adhesives and epoxies don’t stick to it very well.
nitro
nitro's picture
Calvin can u make it like this but for 3× 18650 cells ? https://www.thingiverse.com/thing:33706
Dweano
Just a small simple thing
CalvinIS
CalvinIS's picture
nitro wrote:
Calvin can u make it like this but for 3x 18650 cells ? https://www.thingiverse.com/thing:33706[/quote]
I would probably need dimensions on how big a diameter for the entire holder and max height.
Got a file link?
Dweano
Not yet. I just uploaded a picture for a general idea type thing
WarHawk-AVG
WarHawk-AVG's picture
Last seen: 2 weeks 5 days ago
That blue 18650 protector is pretty cool!
Any price on them?
FlashPilot
FlashPilot's picture
Last seen: 3 hours 10 min ago
What a great toy you’ve got there. Would the plastic be tough enough to hold up to the typical fine threads of a battery tube, and can it reproduce such fine threads?
CalvinIS
CalvinIS's picture
Any price on them?
FlashPilot wrote:
What a great toy you've got there. Would the plastic be tough enough to hold up to the typical fine threads of a battery tube, and can it reproduce such fine threads?
I'm not sure if the tube is robust enough for me to even sell to people. I did a torture test dropping it on concrete and carpet and the weak point turned out to be the threads, the entire cap broke off with the threads inside after tossing it up to the ceiling because it's the thinnest part of the design. The resolution of the printer is quite high 0.15mm (150 microns), the problem is just that too thin of a thread would break. While it may be ABS plastic, it's printed in fine layers so it's not as strong as a solid piece. I'll probably print some out and send out some samples if you guys really want them.
lightme
lightme's picture
CalvinIS wrote:
I’m not sure if the tube is robust enough for me to even sell to people. I did a torture test dropping it on concrete and carpet and the weak point turned out to be the threads, the entire cap broke off with the threads inside after tossing it up to the ceiling because it’s the thinnest part of the design. The resolution of the printer is quite high 0.15mm (150 microns), the problem is just that too thin of a thread would break. While it may be ABS plastic, it’s printed in fine layers so it’s not as strong as a solid piece. I’ll probably print some out and send out some samples if you guys really want them.
Would HDPE be a better choice for threaded pieces? Do you only have ABS?
Bort
Bort's picture
i could be wrong, but in plastic i think threads and thin sections are always going to be weak points
I was chatting with another member a while back about 3D printing, and one thing no one ever mentions about it is that the pieces often have less strength then an identical item with the same material made by conventional means (but of course you need no molds and you can make unique shapes with a 3d printer)
CalvinIS
CalvinIS's picture
The printer we have only works with ABS and PLA plastics, personally we only have ABS on hand.
Bort wrote:
i could be wrong, but in plastic i think threads and thin sections are always going to be weak points I was chatting with another member a while back about 3D printing, and one thing no one ever mentions about it is that the pieces often have less strength then an identical item with the same material made by conventional means (but of course you need no molds and you can make unique shapes with a 3d printer)
I did say that:
CalvinIS wrote:
... While it may be ABS plastic, it's printed in fine layers so it's not as strong as a solid piece. I'll probably print some out and send out some samples if you guys really want them.
Bort
Bort's picture
I did say that:
CalvinIS wrote:
… While it may be ABS plastic, it’s printed in fine layers so it’s not as strong as a solid piece. I’ll probably print some out and send out some samples if you guys really want them.
yes you did, i meant outside of BLF, all the news stories out there promote its strengths but ignores its weaknesses, i had no idea about reduced strength till recently
