I’m looking for an efficient drop-in for a 4XAA P60. I was hoping to something with a single mode, long runtime and potted. Does such a drop-in exist?
What host are you using? What is the battery configuration in the host?
Its a solar force host with extensions to accept 4XAA batteries in series.
You would get 6vdc with 4AA in series
I believe most drivers that can stand full charged 18650 should be able to handle 6vdc
This one should handle that easily
http://www.fasttech.com/products/0/10001085/1105600-cree-xp-g-r5-1-mode-320-lumen-white-light-led-drop
This is a much higher power version and those AA batteries might not keep up with it for long
http://www.fasttech.com/products/1605/10001085/1292200
Xml2 runs great on 4aa because of the led requiring high forward voltage and high current and 4aa being higher than regular lithium ion
Do you have any 1 cell drop ins around already? The nominal voltage range for 4 aa’s will be approx 4-6v depending on the battery used. However, under load the voltage of the batteries will drop. Eneloops under a 2000ma load will drop to 1.2v from fresh off the charger at 1.4v.
I think if you find a drop in that will take 1 18650 or 2 CR123as (which are 3v each for a total of 6V), you’d be safe.
Probably cheaper options, but I would say this one is for sure safe
