Review: Solarforce L2T
111 posts / 0 new
old4570
Last seen: 4 hours 18 min ago
The Solarforce L2T , the latest version in the L2 series offered by Solarforce . The L2 series has gained a following among-st flashaholics seeking value for money hosts , either for custom , self built or 3rd party P60 drop ins , allowing for semi custom lights to be assembled that better meet user requirements .
  And the latest is the L2T , it is fully compatible with the other hosts in the L2 series and swapping parts should not be a problem , I was able to replace the bezel , tailcap , and head with those from a stock L2 , making the L2T fully LEGO compatible [ LEGO = Parts interchange allowing for customizing the host ]
Pictured L2T body with stock L2 head and tailcap .
L2T with stainless steel L2 bezel .
One of the greatest selling points of the L2 series has to be the LEGO-ability of the lights , allowing people to customize there lights to make them more personal , one should never under estimate the need of people to customize .
L2T as it arrived .. Perhaps a little lightly packaged , but came relatively quickly - not waiting to long is nice .
Very well machined threads .
Left to Right =  Stock L2 with SS bezel , L2P  and then the L2T
The finish on the L2T is very mat , and it feels almost dry to the touch , and that seems to offer just a little bit more of a secure feel , as the stock L2 and even the L2P are more slick [ slippery feeling - if I can say that ] , this mat finish just feels warm and secure . The knurling and surface finish are just great , and the anodizing is just so well done , and the internal machining is really good as are the threads . The O rings are nice and tight giving one confidence to get this light wet , and thanks to the O rings , the tailcap and head screw on ever so smoothly and the light locks up drum tight .
  The L2T tailcap continues to impress , the clicky is very mechanical and firm [ I like it ] and is of the forward clicky configuration , which should help to endear the L2T with all those who demand tactical features in there lights . I did put in a older XR-E single mode drop in to just test the clicky , and it worked really well , there are no glitches of any kind as the switch is clicked on [ some forward clickies have a small glitch that cause mode changes as you go from momentary on to being clicked on ] .
 Overall I was very impressed with the L2T , and I'm very much looking forward to building a U2 XM-L drop in for it , should make for a very nice flashlight . Bottom line , for the money paid , this is an excellent P60 host , offering serious value for your money , I can find nothing to fault with this one , and if anything , it has simply impressed me all to heck !
If your looking for a P60 host , I can highly recommend the L2T from Solarforce .
Surface finish is Type-11 - I wasnt sure - but Solarforce has confirmed it .
 Always remember , the easiest thing in the world to do , is to expel hot air from your lungs and through some vocal chords ..
The resulting sound may , or may not be worth listening too ….
Edited by: sb56637 on 08/26/2014 - 17:22
sb56637
sb56637's picture
Last seen: 1 hour 1 min ago
Very nice review, I've been interested to read about this light. I like the looks of the head quite a lot. Not so much the rest of the body.
Thanks again for the review! Frontpage'd and Sticky'd.
gen1.3_
gen1.3_'s picture
Last seen: 5 years 11 months ago
Great review! Is there a difference between the diameter of the reflector between the L2T and L2,L2P? The L2T looks to have a deeper reflector. How about the "tactical" grip , is it rubber or aluminum? Removable? Since it has a matte finish, time will tell if it will be durable.
old4570
Grip ring is rubber .. Being rubber it should be removable , but this one fits my hands well .
Takes a standard P60 drop in .
The head is the same length as the L2P , but the bezel makes it look deeper , in one of the pictures , I have it less the bezel ring [pic9]
sb56637
sb56637's picture
Ah.. that changes things. I would like it a lot more without the grip. I thought it was machined aluminum.
I like the idea of a forward clicky, but I don't like the protruding switch boot. That was the standard switch?
agenthex
agenthex's picture
Last seen: 5 years 3 months ago
The story here has to be the fwd clicky w/ mode dropins. Must select mode first before turning on.
Reading this makes you smarter: http://lesswrong.com/
old4570
Yes sorry folks , the grip ring is very well color matched , the clicky on the L2T is standard forward switch .
A normal L2 is reverse clicky .. Im not sure if you can buy the L2T with anything else but the forward clicky , you may need to mod it if you want reverse .
Though using a forward clicky is no real issue , except changing modes takes a little more work .
agenthex
agenthex's picture
Can you check if the switch circuit in the tail is the same as the l2? SF will sell you one for $2, I found out because I burned one by putting the battery backwards.
Also, is the coating HA-2/3? Ie, is it scratchproof?
Langcjl
Langcjl's picture
Last seen: 10 months 2 weeks ago
I have been waiting for someone to get their hands on one of these. I think it looks real nice. I have to find a good holster, it doesn't look like it will fit in the open holsters I use.
Piers said " ....but who wants enough light, when you have the option for far too much "
old4570
Anodizing ?   Feels more like it were parkarised , anyhow , Solarforce description .
L2T
The L2 Series has been becoming more and more popular in the public market since it first production. In view of this, Solarforce now provides users with our newest model of the L2 Series �V L2T. In addition to the remarkable features of flexibility and wide-application of the L2 Series, the design of L2T is a combination of style and practical nature. The L2T bodies are mainly constructed of precisely CNC-ed aluminum alloy and consisted of head, battery tube and tail-cap switch as its major parts. Users may install various high-efficiency bulb modules and / or accessories to the L2T depending on their needs.
Specifications and Features:
-             Consisted of head assembly, battery tube and tail-cap switch (bulb modules are not included), which are replaceable and compatible with Solarforce accessories designed for the L-Series
-             Body constructed mainly of T6061 T6 aluminum alloy
-             Compatible with various Solarforce LED and xenon bulb modules
-             Forward click tail-cap switch
-             Colour: black
-             Uses two CR123A or 16340, or one 18650 battery by default
-             Standard tail-cap click switch
-             Water-proof design
-             Size (length x head diameter x battery tube diameter): 136 x 32 x 25.4mm
-             Weight: 87g (excluding drop-in modules and batteries)
2100
Looks good, mine came also today, but I wasn't around....so need to wait till tomorrow morning to collect it from the post office.
JohnnyMac
JohnnyMac's picture
I love the look of that new head more than any of the others as well as that awesome matte finish it has! If the body was knurled like the others but with that matte finish it would be so pimp. I think it would make me consider getting my first SolarForce light.
Davx
Davx's picture
Last seen: 2 years 11 months ago
A Solarforce review not made by Foy?? Ok, the world is changing...
Good review old4570!
"There are always new jobs, women, and apartments......there is only ONE BLF." - Chicago X (27/03/2012)
Buwuve
Buwuve's picture
Last seen: 1 year 8 months ago
I asked the same question a few days ago on facebook and tehy wrote HA-2.
Light up the darkness.
monanoke
monanoke's picture
Last seen: 2 weeks 1 hour ago
Great review old4570, swaying me more towards the order button every second! Love the look of that head!
C
SashiX
SashiX's picture
Last seen: 4 years 10 months ago
Excellent review, Matt Wink I like this new model. Waiting tailstand version Silly
2100
My L2 are pretty much scratch proof.  Unless you put them in your pocket for weeks and run around with keys beside them.  So not too much worries.
Match
Match's picture
Last seen: 2 years 10 months ago
Nice review, Old4570.  I like this one in particular because they've done away with that awful hex-nut anti-roll ring on the head.  May have to try one.
agenthex
agenthex's picture
You mean the surface material? Mine gets worn down, not a huge deal but ha-iii is obviously "better".
old4570
Type-2 it is , I just got a reply from Solarforce ...
edc
edc's picture
Last seen: 3 years 4 months ago
you made me buy it!
http://i1193.photobucket.com/albums
2100
My HA stuff flakes....even for Dereelight quality, but its really a very minor flake, usually its at the edges.    Sealed
The guys at CPF says that only the top few lights have HA that are good enough not to flake, their Fenix etc all flake to a certain degree with hard usage.
But seriously, this type II surface really has a confidence inspiring surface, more so than my L2P / L2X.
linterno
Last seen: 5 years 2 months ago
2100 wrote:
... their Fenix etc all flake to a certain degree with hard usage.
My Fenix L2D did less than 2 months after I bought it while being under my pillow.
I Probably had a dream and bit my flashlight. It is the only explanation valid at CPF.
df2dot
Last seen: 1 year 4 months ago
nice pics btw
looks like this will do the job - little pricey for the accessories at SF but seems to be higher quality host ...
and i can t believe they made such a nice host with the switch boot hanging out - looks as awkward as a Baboons ass IMO. should have made it red lol. seriously something protected would have been nice.
... does this have any better contact than say Sky*Ray S-R5 body in your experience or anyone else's experience? i am a bit worried about the MF 3 mode xml getting to hot and to warm for holding
thx for any thoughts on that
old4570
1st , wrap the pill with al-foil to improve heatsinking ..  Nice firm fit into the host ..
2nd , all P60 hosts are about the same size [ physically speaking ]
So as long as the pill is wrapped and fitted to the host , they will heatsink about the same .
Most hosts are a little over size , to make sure they accept the pills .  Which is why it has become standard practice to wrap the pills with Al-foil to make a tight fit that transfers heat .
2100
What da... even under the pillow?   Probably the plating process or some...."too hard can't stick".  LOL!  Hmm....seriously Type II is fine for me but high quality pls.  Like L2 (good), Xeno E03 (well done), L2T (seriously crazy good!!!!)
2100
I find wrapping it in alu foil, make it a bit thicker, and then screw it into the host as opposed to just pushing it in, coz when you screw it in the foil will be tucked nicely inside (push it in and it bunches up).  It becomes so tight that it won't pop out.   If one is anal you can apply a bit of thermal compound.  But don't take it out once it's inside, you'd have to re-do it again.   The reflector won't be too hot vs the host part holding the drop-in - decent heat transfer even for XM-L.
2pts1scn
Last seen: 2 years 5 months ago
 I rec'd the L2T and tried the KD U2 XM-L 5 mode drop-in in it and found that the switch apparently does not handle the higher current. Mode changes are erratic, you never know what you're going to get (like a box of chocolates? not so sweet). The drop-in works fine in my L2. I presume the UF and Manafont multimode drop-ins are working well in the L2T?
 Hello to all, I'm rather new in town - nice neighbohood you have here.
cabfrank
Last seen: 6 hours 9 min ago
from all of us
old4570
Could be the switch - I dont think its the current , mine handles XM-L just fine .
The forward clicky switch can sometimes have a slight contact issue when it clicks on , there is a momentary on and of - and depending on the drop in - can change modes on you as you click it on - most annoying with a 5 mode - you may wish to use a less sensitive drop in / driver .
Or swap out the switch to a normal revers clicky , unfortunately - thats the way it goes some times  .
2pts1scn
 I'll leave this drop-in with the L2 and get a different one for the L2T and see how that goes.
