If you wanted a filler for JB Weld, or Arctic Alumina adhesive, (for use as a heat sink), which one below would you use?
In Powdered Form:
Copper
Aluminum
Graphite
Carbon
Diamond
And... anyone really know which is way above the others? Since they are all power and would all be used as a filler, so it's not like a solid object. Is it a mute point?
This is what I use, six and a half bucks for a half pound. I mix it with JB weld Industro for potting. I don’t have any numbers but it does seem to really do the trick. I know that my protected drivers will shut down without it and with it they are generally fine.
global.kyocera.com › HOME › Characteristics of Fine Ceramics
Thermal: heat conductivity. … Fine Ceramics Offer a Wide Range of Thermal Conductivity … Aluminum nitride and silicon carbide transfer heat particularly well….
I really have no idea what is the “best” but I mix an even ratio of each so I just put out a pile of each of the epoxies and another matching one of the Carbide. So roughly 30%.
I would use it for heatsinking, but not for potting a driver. I am thinking of lights where trying to make a heat sink is a pain and after the T08 deal, I see how easy it is to mold one right in the light, as long as the surfaces are waxed first. So, I am not worried about electrical conductivity, just the best thermal transfer.
If only we had little heat pipes handy, so the heat could be pulled out of the flashlight to some kind of collar from which it could go away. Here’s a comparison between a solid metal rod and a heat pipe: http://www.waermeleitrohre.de/eng/wlr049.htm
Depends on the epoxy. Arctic Silver and Arctic Alumina are better heat conductors than RTV. RTV is somewhere around 1.5 to 1.8 W/m.K I think Arctic Silver is about 8.5 W/m.K and I don’t remember what Arctic Alumina is. So, RTV isn’t better than those epoxy compounds, but maybe better than regular epoxy.
Point is, if any of it were mixed with a high ratio of Copper or Diamond dust, it should increase thermal transfer.
Thanks for the update. Bottom line is that they are both terrible compared to metals… but also an order of magnitude better than air. For those who aren’t sure what that means, they are both about 10x more thermally conductive than free air. Actually 14x or so at the high end.
Adding the things OL asked about in the original post seems to improve things further.
