Review: Olight ST-25 Baton (2xAA, 1x14500)
28 posts / 0 new
Chloe
Chloe's picture
Last seen: 3 years 8 months ago
Olight ST-25 Baton
Overall Rating:
Summary:
Battery: 2xAA or 1x14500
Switch: Side and tailcap
Modes: Moonlight, Low, Med, High, Turbo, Strobe
LED Type: Cree XM-L2 cool white
Lens: Anti-reflective coating (inside only)
Tailstands: Yes
Price: 59.95 USD (45 USD with coupon "ST25")
 Banggood
Pros:
  • Easily accessible turbo and moonlight modes
  • Good run times, particularly on high and turbo modes
  • Stealth silent tailcap switch
  • Light can be 'soft' locked out
  • Tailcap can be locked out
  • Reversible pocket clip
Cons:
  • Only available in cool white tint
  • Does not include spacer for 14500 use
  • Strobe mode is slightly hidden
Firstly, I want to thank Banggood for providing this light for review. ^_^
Instead of the usual cardboard affair, the ST-25 came in a clear box allowing the light to be seen, and displayed hung from a hook. On looks alone, I must admit it did not speak to me to be unboxed and handled. That said, the Olight Baton is a light that needs to be used to be appreciated.
Front of box:
Back of box:
Included are two spare o-rings and a manual. These o-rings are thicker than those one typically sees in flashlights:
A lanyard/wrist strap is also included:
It has a nice push button slider allowing the user to set the size.
Embroidery:
Even the attachment has a logo:
Already one has a sense of a high level of attention to detail.
Stainless steel bezel, and blue glow-in-the-dark o-ring:
The side switch is in a matching blue:
Some AA eneloops for size comparison:
It is quite small, only 152mm long. Here it is, slightly taller than a Mini Maglite:
Weight is quite reasonable. With two AA Eneloops inside the Baton weighs 125g and feels a little hefty for its slender size. For comparison, a Convoy S5 with 18650 cell together weigh a little less at 120g. With 14500 and Coolook AA spacer the Baton weighs just over 100g.
I saw some stores online stating XM-L2 U2 emitter, so I asked Olight for confirmation and was told they no longer disclose this information. It is cool white.
For someone used to single cell Li-ion lights, a 2xAA light might seem a step backwards. It is just as well then, that the Baton delivers not only in lumens and run-time, but also in terms of well thought out design.
The body features this nice cubic knurling:
On closer inspection, this knurled area is the largest and corresponds to the side button. There are three flat surfaces on the middle of the body, two either side and one on the opposite side. These flats makes the pocket clip easier to use, and by having one large area of knurling helps user locate the side button by touch.
The tailcap, with 'stealth' switch just visible:
The stealth switch has a plastic button top. What does it feel like? It is like pressing a firm spring, there is no click either in sound or feedback, and under 1mm of travel.
Here is a video demonstration comparing it to a typical clicky tailcap switch:
I found the way to produce the quietest press is to squeeze the button down and release it gently, rather than pushing it. If the button is released too quickly it can make a noise.
The Baton comes with removable pocket-clip which can be attached in both lens-up and lens-down position:
Notice the flat in the body where the pocket clip rests? Either side of this flat area are two slimmer knurled areas.
The six-sided 'nut' area forming part of the head is curious but seems mainly a cosmetic touch. I suppose in the dark it can aid feeling if the light is pointing the right way. It does not prevent the light rolling off a surface, though the pocket clip can.
Here the pocket clip is mounted in lens-down position, where it allows deep pocket carry (shown next to marker pen for size):
In this position the pocket-clip can be slid up and down along the body. In use I quite like this as it allows for tail-standing without having to remove the clip (it is quite stiff to remove).
The squared threading is anodized allowing for tailcap lockout. Standby current draw is really low (0.5mA), but I like having this option as it takes a little less thought than the 'soft' option (more on this later).
The machining is such that I can't tell if this shiny ring is a stainless steel insert or aluminium (it is aluminium). Remember those thick o-rings? When I removed the tailcap there was a faint pop from the pressure.
Inside the tailcap:
Ahh, moonlight! Laughing I really like the moonlight low on this light, it feels very natural. I love that it is easily accessible too -- whilst the light is off, one simply holds the side switch for a second.
It is low enough I can read with it as a pen light in total darkness whilst containing the spill with my other hand:
Reflection in AR lens:
The reflector is very nice, very smooth. Here is a beam shot next to a Convoy S5 with orange peel reflector (Convoy S5 left, Olight Baton right):
Although the white balance shows a greenish ring almost mid-way between hotspot and edge of beam, it does not seem at all greenish tint to my eyes in actual use, so don't be put off.
The blue GITD o-ring is a nice detail but sadly it is mostly cosmetic and does not glow for very long at all.
It also creates this blue glow when stood near a wall:
Beam shot control at 400 ISO:
This is Turbo mode running on 1x14500. The lit tree is approximately 23.5 metres away (25.7 yards):
So bright it caught the neighbours attention, in the middle of the night! Embarassed
UI
I wanted to cover this separately as the two buttons are not identical in function. Most of the UI is navigated by the side switch. The stealth tailcap switch only activates the memorised mode. It is not possible to access Turbo mode from the tailcap switch.
The manual sheet has three diagrams explaining the user interface:
From the off position, moonlight and turbo modes are directly accessible by side switch only (hold for Moonlight, double-click for Turbo). For me these are the two modes I use the most, and I love that they are so readily available.
From Moonlight mode, one must press and hold the side switch each time to access Low, Medium and High modes. I am used to being able to cycle through modes rather quickly so this is a little change of pace.
Strobe is a double-click away from all other modes. In an emergency, the easiest, quickest way to access it is to double-click for Turbo then double-click again for Strobe. To end Strobe a single press will return to the previous mode.
One small issue I have is not being able to store Strobe in the tailcap switch (whilst still having access to Moonlight and Turbo from the side switch), but this is mainly because I don't need a stealth switch.
The Baton can remember Strobe but it is overwritten when Moonlight mode is used. This is perhaps where the silent tailcap really comes into its own, if you find you need a very low amount of light without being heard (or, for that matter, one of the other regular modes).
Lastly, it is possible to lock-out the side switch by holding it for greater than two seconds whilst the Baton is off. Whilst 'soft-locked' one has to press the side switch for a second to turn the light on (Moonlight).
Current, Output and Runtime
The manual states these run times, tested with 2xAA 1900mAh NiMH:
ModeLumensTime
Turbo55030 mins
High3001 hr
Medium1006.5 hrs
Low1060 hrs
Moonlight1200 hrs
Strobe 10Hz3002 hrs
There is also a run time graph of the high mode:
For comparison I measured the high mode in lux, taken at 3 metres, with 3rd generation Eneloop Ni-MH and a protected Trustfire 'flame' 14500 Li-ion cell. The protection circuit in the Trustfire activated after an hour.
The Turbo mode is more interesting. Peak beam intensity is stated 4,400 candela, which I could verify with a lux meter via three sets of measurements taken at different distances. I took these measurements after 30 seconds:
Output of Modes
CellModeLux 1ftLux 1mLux 2mLux 3mCandela 1ftCandela 1mCandela 2mCandela 3m
1x Trustfire 14500
Turbo 49101410655 491056405895
2xAA EneloopTurbo 44001100500 440044004500
High 3220805388 322032203492
Medium 853230112 853920990
Low920105261185.4710510499
Moonlight2010 1.861
As you can see from this graph, the light gets hot and the output drops to 390 lux by 15 minutes (approximately 3500 candela).
And again with a pair of 80mm fans cooling the light, running at a gentle 5V so not to skew the results too much:
This output drop is not an issue if you use Turbo in bursts. I needed to use the light on the brightest mode for extended periods without handling and was curious about output behaviour, hence the graphs.
Current Measurements
Mode2xAA Eneloop1x14500
Turbo3.021.75
High1.150.69
Medium0.270.17
Low0.040.03
Moonlight0.00740.0091
Small update
Since I have been using this light a lot I thought I'd share pictures of the kind of wear the pocket clip makes in the anodizing. It is really HAIII. My Nitecore EA4W the black finish is a bit shiny in comparison, but it stays in a sheath so I don't worry.
You can see shiny wear spots:
At the tail end:
Also, I noticed the bezel machining is not perfect, but not that noticeable:
Thanks for reading!
Edited by: sb56637 on 09/02/2017 - 11:48
sesgum
sesgum's picture
Last seen: 3 days 22 hours ago
Thanks for the nice review!
saypat
saypat's picture
Last seen: 6 hours 59 min ago
Very nice review Chloe! It makes me want to go out and buy one! Terrific light. I am having a custom Olight S10 made as we speak. I’ll post a review of that in time. Nice shot of the neighborhood, and disturbing the peace Smile
thanks Chloe….
patrick
Racer
Racer's picture
Last seen: 3 years 9 months ago
Thanks for the review. FYI the Olight S15 Ti comes with a Ti extender which also allows you to run 2xAA, and it even has a nice, neutral tint.
pipifax
Last seen: 2 years 5 months ago
Fabulous review, thanks for the hard work!!
Beautiful photos!
Please keep up the great job. Smile
ImA4Wheelr
Last seen: 4 days 10 hours ago
Wow, excellent review and great looking light. Thanks Chloe.
DayLighter
DayLighter's picture
Last seen: 2 years 10 months ago
Nice review Chloe.. but AA/14500 light that cost over $50? ugh.. not willing to spend that much money Silly
maybe this is the reason why I only have 1 Olight light ( it was on sale from Wallbuys :bigsmile: )
The only way to do a great work is to love what you do.
lightaddict
Last seen: 5 years 9 months ago
Thanks for the write up.
harry218
harry218's picture
Last seen: 2 years 3 months ago
You can get it cheaper on eBay from China but you have to wait for the auction. :X, beware the MAP police. Opps where are my manners, thanks for the nice write-up Chloe.
Racer
Racer's picture
The S15 Ti is only 80 bucks on Amazon. So for 30 bucks more you get Titanium and the ability to have it in a 1xAA or 2xAA configuration.
harry218
harry218's picture
HKE has S15 Ti for the same price. I guess we could ask for coupon from them. My wild guess would be $60-$65. :bigsmile:
NLE
Last seen: 3 years 3 months ago
Excellent review Chloe! Very nice pics too. This must have taken quite a while to put together.
NLE
Trevi_lux
Trevi_lux's picture
Last seen: 9 months 4 weeks ago
Great review Chloe !!!, I love my ST25 :bigsmile:
Olight s15 Ti is a great Flashlight ( spanish review S15 Ti ).
But more powerful the new ST25 with 2 x NiMH:
Racer
Racer's picture
Is the ST25 higher output because the S15 is a more neutral bin? Or are they just driving it harder?
Does anyone have any issues with the S-series lights coming on in their pockets? Even with the soft lockout engaged?
Trevi_lux
Trevi_lux's picture
On my pocket always unscrewed a little the tail of the S10 and S15, better be safe …
St25 Vs S15 with extender for 2xaa (measured at 30 seconds)
(This is for the aluminium S15 with extend, I think the S15Ti with extend is more powerfull that the aluminium version)
DBSAR
DBSAR's picture
Last seen: 9 hours 45 min ago
Nice review Chloe Smile its an interesting new light in the 2-AA class.
WarHawk-AVG
WarHawk-AVG's picture
Last seen: 5 months 3 days ago
Great review
So does the battery tube come off to run a single 14500? or did you have a blank in there with it?
Interesting light but at that price…definitely NOT in my budget
jpil
Last seen: 2 weeks 3 days ago
Thanks for the nice review Chloe!
I like the blue glow-in-the-dark o-ring.
Racer
Racer's picture
The Ti versions don’t have tail cap lockout!
Trevi_lux
Trevi_lux's picture
It’s true!!!! I’ve been very lucky, I’m a mess…
Chloe
Chloe's picture
WarHawk-AVG wrote:
Great review
Thanks! ^^ It doesn’t come off. I used a Coolook blank .
I do like the way the size feels with 1×14500. The length feels right. If the body was shorter I don’t think it will be as comfortable to use because of accessing the side-switch.
It is a little longer than a Convoy S5, which I think is a really nice size:
MRsDNF
MRsDNF's picture
Last seen: 4 hours 15 min ago
Thanks for the nice review. I love your graphs.
WarHawk-AVG
Chloe wrote:
WarHawk-AVG wrote:
Great review
It is a little shorter than a Convoy S5, which I think is a really nice size:
Excellent!
I have a S5 as my ECD…love it Big Smile
StyXSIS
StyXSIS's picture
Last seen: 4 years 8 months ago
Ah ha, found it, thanks chloe, that was a good write up, the graphs are great also.
Simon
Overclocker
nice review! and great photography
i’m curious about the turbo mode using 2x nimh. seems like the “550 lumens” is not sustainable for any useful amount of time. on your graph it seems like it takes a nosedive immediately, and i mean it really really falls like a brick, and that perhaps 550 lumens only lasts for like 5 seconds or so? probably even less…
if so then it’s really no better than it’s cousin the foursevens QP2A-X which doesn’t brag about a “550 lumens” but instead puts out around 450 lumens for 3 minutes then steps down to 336. and the 450 lumens is actually sustained quite well for those 3 minutes…
Chloe
Chloe's picture
Thanks! ^^ The output drop on Turbo (using Eneloops) is perceivable during the first few minutes but it is at least gradual.
In the ceiling bounce test I just did I noticed some flickering in Turbo mode after ~5 mins on eneloops (some newish 1st gen and some 3rd gen) which I can’t reproduce using 14500. It may be the regulation to blame. I will contact Olight about it.
WarHawk-AVG
Well in the AA mode it’s acting as a boost circuit, in 14500 mode it’s acting as a regulator…the boost circuit might be getting warm and throttling back (thermal protection built into the IC)
I just got me a FandyFire C3 in…actually quite amazed at the light it puts out…but it’s only a single mode (might be time for a driver upgrade )
The fit and finish is nowhere near as nice as yours though
dangerous
dangerous's picture
Last seen: 5 years 1 month ago
Did Olight ever get back to you about the flickering? Mine flickers too.
BLF
