The design features double o-ring sealing with a manufacturers depth rating of 100 meters. The torch features a safety twist on/off and sliding variable dimmer with ~20 lighting levels - simply unscrew the barrel a quarter of a turn and it can not activate in your luggage. Approximately 70 minutes burn time at 800 lumens (max) or well over two hours on lower settings.
Specs: CREE XM-L T6 LED
Electrodeless magnetic control switch
800 max luminous flux
Reflector: Mirror reflector
173m max range (on land)
Anodized aircraft 6061 aluminum
Power by 1*18650/18700(3.7V) battery (not included)
45.00mm(head dia) * 30.00mm(body dia) * 149.00mm(length)
Amphibious 100m deep diving sealed compression resisted design
3.5mm extra toughened glass lens
2.5~8.4V voltage range
Net Weight: 210g
Well, it is similar to the D01 i reviewed a while ago but with XM-L instead of XP-G R5 emitter and a tad different head. The D01 is rated 100m. Pretty happy with the D01 one.
Please review the D06 if you have the will and time. :)
A non-diving version would cost around $40. There aren't any sub-$100 T6 100 meter waterproof diving torches on the market. The magicshine ones all flood or burn themselves out so I'm pretty happy with this find. I will have access to a pressure pot around August and will take it down well past 300' then.
I'd love to see a review. Sadly this is out of my price range, but generally xtar makes some solid lights for the money.
This is not spam since this is in the "want to sell" part of the forum. Members don't always realize that this part of the forum exists because they only work off the BLF frontpage so please don't SPAM rate the seller.
The factory says the 60m depth rating is old as the torch has an 'extra tough glass lens' equal to or better than the D01. Either way its deeper than I will be taking this torch. 40m yes... 60m not exactly. ;-) I will definately take it to 100m in a pressure pot in a month or two to see what happens.
For what its worth camera housings have much larger glass lenses (surface area) and are about half the thickness and they have no problem at depth.
SOme memebers here (especially gcbryan who apparently dives every other day) wo-uldnt aggree with that.
Hi uses Magicshine, if im not mistaken, whole time.
Where did you find info that Magicshines flood and burn out?
And D06 is around 101$ on chinaqualitygoods, includinhg shipping, when discount is deducted (automatic 3% discount for more than 100$ purchase and anything you have on top of that),
