I had bought a Mini AAA “C8” flashlight a while back for 3 or 4 dollars, and it’s just been sitting. Well I decided to make something of it, so I put a Nichia 219B on 16mm Noctigon inside.
It still has the plastic lens and reflector, but that’s because it does not have a removable bezel, or anything to hold the lens/reflector in place without press-fitting it in the way it was made.
Here is a set of pictures below, with a reference picture I found. I need to do this because I had to glue the pill inside to make sure the pressure of the body being screwed in did not push the pill and pop the reflector out.
In the reference picture for explanation:
Led is the Nichia on the star. Below the led, there is 2 pennies I grinded to size, thermal glued to each other, and the black plastic ring is actually an aluminum ring I had from something, that fits snug in it’s place. The boost driver gives decent current to the LED it seems, as it is quite bright, and draws 1.6a from an alkaline cell with 1.5v.
Thanks! This is definitely an addicting hobby. The pennies were 1960some, so 95% copper. With the 2 pennies and copper mpcb, it’s at least 5mm of copper under that LED, with Arctic Alumina adhering the aluminum pill to the body. Won’t have to worry about heat for sure.
Also, the other day I modded my Garrity flashlight with an XML2 4C and TIR optic, and 8x7135 driver. Pictures below:
