Hi,
I purchased this light at www.manafont.com.
It's an well made torch and has a very bright hot spot.
But I found there is neither screws nor holes on the aluminum disc of the head.
I wonder if it may be a problem in using the light or else.
Hi,
Welcome to BLF Candle Lamp. Normally the emitter is fixed to the pill with thermal paste or glue and works well like this . If the reflector do not contact the wires all should be well. I like Sky Ray (Lay) there finish is on the better site .Check the heat of the head ,if its really hot let it cool down.
And have a look at this.
Thanks for your reply. NiBi!
