do u like a portable led flood light?
convenient to hand-carry anywhere,
support rechargeable, a car charger will be gifted.
It is also waterproof
A good try for emergency use.
What you say?
Hello, this is up to the current, if current higher, the brightness will be higher,
if a higher brightness, normally will be available 3-4hours
if a lower brightness, normally will be available about 10 hours.
Hello, 8.10 sale is one of sale on aliexpress.com
And our store take part in it.
On 19th, August, 2014, all led lights will on sale from 20%OFF
For more led lights, please kindly refer to http://www.aliexpress.com/store/808113
Thank you.
I really like this portable light, but I really wish it had replaceable batteries instead of a battery pack. Replaceable 26650’s would have been perfect.
are you sure the battery capacity is 4400mAh ? There is another brand of this exact same light that shows about the same runtime, but shows the battery capacity as 2200mAh. Can you verify the capacity? Thanks.
Hello, richie, thanks for your carefulness.
We have checked. the 4400mAh type is out of stock.
And this one is also availble 2200mAh.
For 4400mAh type, I will check more from warehouse.
Thank you.
