There are some very talented EE types on the forum.
I am only dangerous in the field but I know how to stuff things into small places.
I also know enough to understand the limitations and the challenges.
Here is my most important factor for a high power LED light; CONSISTENCY!
I “want” my 6V, 3A MT-G2 to get constant input until the last few minutes of battery life.
I have accomplished this with the standard NANJG drivers running a max of 1.05 amps.
I get full output into an XP-G or an XM-L until the very end.
How can we do this same thing with the MT-G2?
I am going to assume the following:
- The 6V MT-G2 requires 6.2V to sustain 3 amps.
- A 0.6V margin for the regulation circuit is insufficient for the V-drop across the regulators (nP2S).
- Regulation can be sustained until each source cell reaches 3.4V where a good cell will drop off quickly (80%).
Conclusion with this information would suggest that a 2S arrangement for a 6V MT-G running full rated power without sagging would be challenging.
What about the 9V MT-G2 which requires nearly 9.3V to sustain the full 2 amp draw? Will 3S 11.1V work? Being only 2 amps draw, the cell will sustain 3.45V to the 80% mark, providing 10.35V or a full 1V for drop across the regulator. Are we now in the ballpark for this challenge?
Personally, I don’t mind a 3-cell fat body flashlight which also provides a nice cavity for the driver. Maybe even a 2P extension if runtime becomes an issue… and of course, the FATBOY if 3X 26650 is desired.
A smart design would also allow different configurations where it could drive multiple XM-L2’s with a simple component change. After all, we are talking 18 watts total capability which will drive 2X XM-L at full rated current. In series, 2 XM-L2’s is pretty much equivalent to a MT-G2.
So, what do you say… does anyone have some conclusions to these assumptions? Is pursuit of a 9V 2A regulated driver feasible for driving the MT-G2 within the Cree specified usable range?
A project like this is only reasonable if the technology can support it. And the one thing I cannot stand is a flashlight that doesn’t regulate output to the end (80% of cell capacity).
If someone is up to the challenge to design the circuit, I can follow up on packaging it.
Note: I am specifically leaving out the hot-rods here which the direct drive ambitions are already addressing. I am looking for a true current regulation circuit. Preferably a buck driver that is easy to configure.
