Looking for a Pool Bulb and came across this:
http://ledpoollightsnet.ipage.com/store/index.html
HP-20LED
120volts/50watts
The High Powered-20LED is a direct replacement (standard screw-in), 50 Watt pool lamp with a lifespan of +60,000 hours. It emits a perfect overhead daylight color (same as the sun). The HP-20LED is the perfect light for larger sized swimming pools and is presently being used in commercial applications to replace 500watt lights.
This light is our newest and brightest yet, built with a solid cast heat sink and custom hi-flow vent design allowing for the internal/ high velocity/ brushles cooling fan to dissipate heat faster- ensuring greater longevity than any other SMD LED pool light on the market!
Compared to a 500w standard bulb
The HP-20LED lasts 20x longer and uses 90% less energy!
The lamp measures approximately 5“ x 4 5/8” (diameter) which allows it to be used within
any standard light fixture.
Backed by a 3 year warranty!
Has anyone had/have any experience putting these types of bulbs into a sealed containment under water? Specifically half-life of the leds.
Of course their “reviews” are all positive and i have been unable to find any real world reviews.
Monanoke
