Best Thermal Paste According to Independent Studies?
61 posts / 0 new
kronological
kronological's picture
Have you seen the countless claims from countless makers of thermal grease/paste? They are all the best…have the finest ingredients…nano-tubular, micro-metallic, thermally conductive secret sauce. Many claim customer/industry tests prove their claim, yet never seem to provide proof/links to verify their claims.
So I am currently searching for independent studies that can give some insight into this. Here is what I have found so far:
Hardwaresecrets. review from 10/05/2011.
Benchmarkreviews. from 6/14/2009.
I’ll keep searching for other studies, especially newer ones.
Are you aware of any?
No one, after lighting a lamp, puts it away in a cellar nor under a basket, but on the lampstand, so that those who enter may see the light.
My Reviews: Ma
downlinx
downlinx's picture
Last seen: 2 months 5 days ago
BLF Community Battery Pull Thread http://budgetlightforum.com/node/32720
kronological
Thanks downlinx. Can you check your first link (Toms). I’m getting a 404 message.
My Reviews: Ma
flydiver
Last seen: 13 hours 7 min ago
Maybe with a little Dijon?
(hint-read the first review link)
AlexGT
AlexGT's picture
Last seen: 43 min 30 sec ago
That liquid pro ultra is kind of cool, liquid metal hmmm…
http://www.amazon.com/Coollaboratory-Liquid-Thermal-Interface-Material/d...
I wonder if it would run and make a short circuit if applied to flashlights…
I think I might get a tube of Gelid GC-Extreme to try it out…
downlinx
downlinx's picture
Weird the link will not attach so here it is plain text
http://www.tomshardware.com/reviews/thermal-paste-performance-benchmark,...
aoeu
aoeu's picture
AlexGT wrote:
That liquid pro ultra is kind of cool, liquid metal hmmm... http://www.amazon.com/Coollaboratory-Liquid-Thermal-Interface-Material/d... I wonder if it would run and make a short circuit if applied to flashlights... I think I might get a tube of Gelid GC-Extreme to try it out...
Not for aluminum! Which rules out most flashlight applications.
From the Toms Hardware review - image from them.Lower is better.
Bort
Bort's picture
Last seen: 18 hours 31 min ago
The Journal of Alternative Facts TM
"It is critical that there is a credible academic source for the growing and important discipline of alternative facts. This field of study will just keep winning, and we knew that all the best people would want to be on board. There is a real risk in the world today that people might be getting their information about science from actual scientists"
leaftye
Last seen: 1 month 4 days ago
http://www.coollaboratory.com/en/products/liquid-copper/
No mention of issues with aluminum.  It might be worth trying.
The low mode should be lower.
Reviews: Efan IMR18350 700mAh 10.5A, <a href="http://
texaspyro
Last seen: 1 year 3 months ago
Has anybody tested… paste… you know, the tasty favorite snack of pre-schoolers everywhere? I’d try it but I’m gonna go and huff some freshly mimeographed tests…
downlinx
downlinx's picture
There gave been quite a few test involving toothpastes and surprisingly enough it wasn’t worse than some thermal pastes.
eebowler
eebowler's picture
I wouldn’t be surprised if the liquid metal is an alloy of gallium which by itself isn’t that expensive.
My gratitude to those who are willing and able to help others (in whatever way you can)! Being human is more than just existing for yourself. Smile
texaspyro
Gallium and/or indium are used. Neither is a friend of aluminum or aluminium.
comfychair
comfychair's picture
Last seen: 2 years 9 months ago
I am not even going to post in this thread.
Bort
Bort's picture
no problem, can i ask why?
leaftye
Probably because he doesn't think the hot rodding efforts are worth the marginal gains, so nobody else should bother doing something they might enjoy doing anyway.
comfychair
No, it's not that at all. Those strawmen sure are easier to knock down though, aren't they?
Show me a test that shows any change at all in light output between a copper MCPCB with really bad thermal paste and a copper MCPCB soldered to the pill. Show me. I would think you would want to know if these things are real too, why am I the silly one by asking for the proof that these things actually work?
Bort
Bort's picture
comfychair wrote:
No, it’s not that at all. Those strawmen sure are easier to knock down though, aren’t they?
I assume the laws of thermodynamics apply so increased thermal transfer rate means the heat gets from one surface to another more easily when the interfaces are more thermally conductive. How much does that affect flashlights is a legitimate question, your saying not much, if someone wants to test this and provide some data then no one will object.
As the links i posted above demonstrate don’t use cheese in place of thermal compound
raccoon city
raccoon city's picture
Last seen: 4 min 31 sec ago
Share a Coke with Bort!
bort
comfychair
In a synthetic test where you have a tiny 1cm x 1cm patch and pumping 200 watts through it, those thermal paste charts are probably perfectly true. But change that to 30 watts through a 16mm diameter MCPCB and you can't measure any difference between the worst and the best. The difference is less than the margin of error of the measuring equipment.
Now, how much time, effort, & money (this is still 'budget light forum', right?) are you willing to invest for zero gain?
This does not mean the bottom of the MCPCB & top of the pill do not need to be flat. This does not mean a hollow pill is just as good as a solid pill. This does not mean a non-direct aluminum MCPCB with a dielectric layer in the middle is as good as a direct-thermal copper MCPCB. Do the proper prep work, that's far from 'none of this stuff matters'. The stuff that makes a difference matters. The stuff that does not make more light come out does not matter.
Bort
Bort's picture
bort
Bort is not one to change his avatar but this photo was impossible to resist Smile
comfychair wrote:
In a synthetic test where you have a tiny 1cm x 1cm patch and pumping 200 watts through it, those thermal paste charts are probably perfectly true. But change that to 30 watts through a 16mm diameter MCPCB and you can’t measure any difference between the worst and the best. The difference is less than the margin of error of the measuring equipment.
Now, how much time, effort, & money (this is still ‘budget light forum’, right?) are you willing to invest for zero gain?
This does not mean the bottom of the MCPCB & top of the pill do not need to be flat. This does not mean a hollow pill is just as good as a solid pill. This does not mean a non-direct aluminum MCPCB with a dielectric layer in the middle is as good as a direct-thermal copper MCPCB. Do the proper prep work, that’s far from ‘none of this stuff matters’. The stuff that makes a difference matters. The stuff that does not make more light come out does not matter.
your probably right, as an unknown person said “In God we trust; all others must bring data”
and:
Tom E
Tom E's picture
Last seen: 1 hour 48 min ago
I've been using GC Extreme, but comfy is probably right. I'm interested in sustained reduction of temperature at the LED, and I have higher confidence in GC Extreme right now for longevity (both long runtimes and life cycle), based on various sources/reviews from real users online - of course it's all from usage on CPU heatsinks, but they measured apparent real differences in temps. Does that apply to the lower power levels of LED's? Maybe, probably not the same though.
Problem is I'm not aware of anyone that has done comparative tests on our modern LED's and MCPCB's. Even so, again, I'd be interested in how they perform over time, and also what the temps are at the critical spots. Keeping the LED cooler at high amps will probably extend the lifetime of the LED (not only brightness is at stake), but again, anything over 3A to the LED is beyond manufacturer's limit.
Mitko
Mitko's picture
Last seen: 12 hours 13 min ago
Best thermal paste for what purpouse? CPU cooling, Led cooling?
You see, my PC is watercooled, back in 6 months i changed the CPU to 4770K…and i didnt got the cooling results i wanted, then i have decided to change the thermal interface between the CPU core and the protective cap -voila, temperatures dropped with 10 degrees!
My great surprice came after 2 weeks, the CPU temp not only rised, but rised alot! Up to 95 deg C under prime 95( while watercooled!), and the CPU became unstable…i used Prolimetech PK 2 by that time…then i swapped it with Pk3… with Gelid….same results after 1-2 weeks of heavy usage
Then i found a topic about that matter in Extreme systems forum, it seems that under heavy load and constant high temps most CPU thermal compound are degrading pretty fast especialy when put on a naked CPu core, exept the pure sillicon based thermal paste and of course liquid metal, now my CPU`s thermal interface is Coolaboratory Pro liquid metal, and after already 5 months i can say its rock solid
The GPu core on the other hand do not degrade thermal pastes that fast! Its bigger, and usualy works cooler, under heavly load and OCed temperatures never pass beyond 55 deg C
Since LEDS are always under high temperatures, maybe results there are simmilar- liquid metal cant be used on Al headsinks , so i dont have that huge experience exept with 2×30w Bridgelux emitters mounted on huge CM copper headsinks
P.S
When i removed the CPU cap the default Intel thermal interface was a pure sillicone glue of some sort
Have pics, if someone is interested
Btw, i have never tested AS5….its 99% micronised Silver, maybe it wont degrade , but it can oxidise
fellfromtree
fellfromtree's picture
Last seen: 4 years 3 months ago
I used to be on extreme and evga forums Smile Yeah been using that for years Mitko.. *Just note it doesn’t work on aluminum which is like all the pills
Mitko
Mitko's picture
Yeah i mentioned that, but on copper it works! Plus, AS5 issue that i mentioned earlier…have to test it though
My point here is that PK1-2-3 or even Gelid wont do any good here, vise-vesra, they are worst that a cheap pure sillicon paste, the emitter in our case is always working at its max( most of the times at least), temps are above 85 deg, those CPU pastes arent designed for that
Yet…AS5….unfortunately my CPU is permanently metal- glued, and the LED die dont have build in thermal sensors
Have to ask someone from Xtreme if he tested with AS5, they do experiment alot
Joshniss
Last seen: 9 months 11 hours ago
Ive always had great luck with arctic silver 5
Serville
Serville's picture
Last seen: 4 years 2 months ago
There is very little difference among all of them. Even the best thermal paste will only give you a 3-4 Celcius better than the cheap one, which doesn’t make meaningful difference IMHO.
It’s more about the peace of mind, knowing you have used the best.
I’m not suggesting that you go with the cheapest one, but I’m also not seeing the point why anyone would spend $12 for a 4-gram syringe.
I’ve tried possibly all the best thermal paste in the market for comparison, from Shinetsu, Gelid, Prolimatech, Zalman, and my conclusion is that they are not worth the money you spend.
Even the infamous Shinetsu 7783D ($8-9 3 gram) only lowers my CPU 3C better than the cheap Servisol thermal paste ($2 25 gram tube) at full CPU load.
I bought Servisol 5 years ago, and I still have half tube even now. It performs the same like 5 years ago.
If you want to save your money, go aliexpress & search for Halnziye HY-810 or GD900, which I suspect to be the same thing.
It’s so much cheaper than those “fancy” pastes from Shinetsu, Tunix, Gelid, etc for a much more reasonable price.
You can get GD900 for $7.70 for 3 syringes @15gram, which you can use for a lifetime. They are non-bleed pastes. Viscocity is medium.
I have used Halnziye HY-810 & GD900 in the last 2 years. I bought HY-810 for only $10 (20 syringes 1gram) , and $ 4.5 for GD900 (30 gram tube). They give the same performance as the stupidly expensive Shinetsu, Prolimatech PK3, you name it (but I actually use Servisol for my flashlight). Unfortunately HY-810 is a little more difficult to find in retail package now, but you can still find it in Ebay for $1 a tube 1 gram.
Or simply buy GD900 in aliexpress, which you can buy much cheaper in a tube of 30gr ($5).
Both HY-810 & GD900 performs exactly the same in my overclocked i7, and I actually suspect they are the same thermal paste produced by Halnziye, only re-packaged.
Even Tunix has considered selling HY-810 under its own name as a successor of TX-4, and has asked puroverclock.com to evaluate their investment.
Here is the result:
http://www.pureoverclock.com/Review-detail/hy810-and-hy880-compound-review/
Mitko
Mitko's picture
Excuse me, but i wont agree with you: reasons
- Firstly, the temp differences arent 2-3 deg but they can reash >10
- Every deg lower DO MATTER when we speak of extreme OC
- When the LED or the CPU are well OCed that thermal paste difference is even bigger
- The main problem::: most of them DO DEGRADE pretty fast in time, and by “ in time” i mean 1-2 weeks when we are talking about extreme OS, believe me, i have a huge headaches about that matter before we cleared that issue out in Xtreme sys forum
Well, a causal user wont bennefit from an ultimate thermal interface, its true
fartybum
Fujik sold by DX is the worst I’ve ever used, usually use Arctic Allumina.
WarHawk-AVG
WarHawk-AVG's picture
Last seen: 1 week 3 days ago
In VERY high temperature and small footprint die’s the thermal coefficient/conductivity really matters, especially when it’s attached to an air cooled (or water cooled) radiation device, the faster it can move the heat from a small surface area to the larger surface area heatsink yes..those very detailed charts do come into play
With lower power direct soldered emitters and large footprint copper stars, the temperature coefficient might not be that important, due to the fact that thermal saturation occurs because the heat really doesn’t have anywhere to go once it bleeds off from the emitter to the star, to the pill, to the body of the flashlight
Cost effectiveness vs thermal effectiveness comes into play in this area
Computers vs flashlights = apples vs oranges
I use silicon and epoxy (and sometimes super cheap artic silver on the threads of the pill)…and the thermal management seems to do just fine, dropping $20-$40 on a tiny tube to put on a <$20 flashlight…well you see the conundrum?
Using good thermal compound is always good…but in flashlights will it really make that much of a difference?
vex_zg
Last seen: 7 months 2 weeks ago
just to add some info
I used Gelid GC extreme on GPUs, it has excellent performance in beginning, but after few months, it degraded to have absolutely terrible performance, worse than using no paste at all, I think it actually became a pretty good thermal isolator
