Trustfire XM-L 2x18650 Zoomable
12 posts / 0 new
VFMaddict
Last seen: 1 year 1 week ago
"You are making progress if each mistake you make is a new one."
Remember - Most great discoveries start with maki
gcbryan
You could use that thing as a bat it's so long. It would be interesting to see it in operation though. Someone buy it and post your review Smile
gcbryan
You could use that thing as a bat it's so long. It would be interesting to see it in operation though. Someone buy it and post your reviewSmile
zizo
Last seen: 8 months 1 week ago
I just tried a DX 28mm lens with my trustfire f15 xml, but much dimmer than 50mm lens. I much prefer a zoomable with a 50mm or even 66mm lens.
VFMaddict
gcbryan wrote:
You could use that thing as a bat it's so long. .....
Looking very closely at the pics of the light I've a suspicion that it can be used in 1x18650 configuration.  It sure looks like a section is designed to be removed.
Crux
Crux's picture
Last seen: 10 months 2 weeks ago
IMO The problem with zoomies is they don't capture all the light from the emitter.  Its a compromise between long and short focal length lenses.  A short focal length lens (thicker, more curvature) is better at collecting more light, but the focus (at the LED chip) is so tight that the size of the LED chip is bigger than the focal point.  A longer lens (thinner, less curvature) is easier to focus but because it is farther away, it collects less light.  A larger diameter lens is needed to increase the sweet spot, but these lenses are expensive and heavy.
So, if zoomies are inefficient what can we do?  Throw more lumens at them!  A zoomie with an XML @3A will be brighter than with am XPG @1.5A.  (But the XPG should focus better.)
I'm no optics expert so don't flame me too badly.  Please enlighten me where I've made poor assumptions.
-Crux
ZW99GT
I appreciate the idea for sure. It's also priced right @ under $30 USD shippied. Should be worth a shot, especially from what seems to be a very reputable Ebayer.
Langcjl
Langcjl's picture
I'm sure it would make an excellent bike light. I would buy one if it was listed on DX or Manafont.
Piers said " ....but who wants enough light, when you have the option for far too much "
_the_
_the_'s picture
Last seen: 14 hours 40 min ago
I ordered it. Let's compare it to Yezl T9 and see how it performs..
=the=
=the=
jamesearljonesi...
jamesearljonesisascab's picture
Last seen: 9 hours 49 min ago
does look interesting probably same led pill from X9 and stlv2.
03/04/16
8 lives left
_the_
_the_'s picture
Be-Seen Triker wrote:
Looking forward to a full BLF worthy review Smile
"Full" review here Smile
=the=
=the=
old4570
Last seen: 14 hours 15 min ago
My brother got one .. I cant say its bad , and I cant say its good ..
ill do a review of it on the week end ...
 Always remember , the easiest thing in the world to do , is to expel hot air from your lungs and through some vocal chords ..
The resulting sound may , or may not be worth listening too ….
