I just ordered a solarforce L2r. I want to put in some kind of warm white dropin. I don’t know if I want a low voltage to run on AAs or do something different like an MCE(I don’t have one of those) and two 14500s. Any ideas? Pitch them here.
Deereelight is supposed to have some good neutral dropins for the javelin ...
Thanks Bob, a warm XML would be great but that’s a pretty hard animal to find. I see a lot of WW MCEs in hosts for cheap but I don’t need another p60 host lying around. That is an option though. I just want something different than all the cool white Q5s and XMLs I have around here. A good WW xpg would be nice. I will make the battery situation fit for whatever I get. I’m looking for a WW XPG, MCE or XML dropin. XREs are out. I’m off to check out the deereelights now but I don’t know how cheap those are.
I'm not sure why xre's are out, because they have the best selection of available options.
I just wanted something different but that’s proving hard to find. I was thinking of this http://www.kaidomain.com/ProductDetails.aspx?ProductId=10965 a light that I think Agenthex liked in another thread. I would have to use a spacer and run off one battery though. The thing that adds some complication to this is the battery situation. Im just looking for something a little different. I may just end up with an xre and that will be cool because I still don’t have any warm whites. Still looking for ideas.
Yes that's a good light, but it needs a mod. The stock reflector threads are too shallow for the mce on that particular pill (exaggerated mc-e beam hole), so I just swapped for some other random OP reflector in another dropin and now both work well. Needs to back out a couple turns to get rid of the hole entirely. I liked it as is in the nice and shiny clone L2 host.
The best dropin for 2x14500 is this http://www.dealextreme.com/p/cree-q2-led-drop-in-module-for-wf-502b-and-similar-flashlights-3-6v-12v-input-12501
I have had that dropin in mind as plan B. I just ordered it. Thanks
