Test/Review of Charger Xtar VP4
10 posts / 0 new
HKJ
HKJ's picture
Last seen: 1 hour 8 min ago
Charger Xtar VP4
DSC_7997
DSC_7999 DSC_7998
Xtar has many good LiIon chargers, this is a 4 channel charger in their advanced charge line: VP1: 2 slots, 3 currents and voltage display, VP2: 2 slots, 3 currents, 3 voltages, voltage display and usb out. This new model has 4 slots, 2½ currents and voltage display. Compared to VP2 only the number of slots and the maximum battery size has been improved, other features are the same or downgraded.
DSC_7990 DSC_7991 DSC_7992 DSC_7993
The charger comes in a cardboard box with lots of specifications on it.
DSC_7994
In the box is the charger, a power supply, a car adapter, a instruction manual and a warranty card.
DSC_8001
The charger has a DC connector for power input. Because it can only charge with 1A on two channel, it only need a 1A power adapter. If more channels are used all will be reduced to 0.5A.
DSC_8005 DSC_8007
The slots have raised battery connections, i.e. flat top batteries can be used. The slider works very smooth and can take batteries from 30.5mm to 71.5mm. This is enough to handle even long protected 26650 batteries.
DSC_8003
On the top of the charger is a switch to select charge current, it can select between 0.25A, 0.50A and 1.00A, the current will be the same in all four slots.
The charger will always select the highest possible current when loading it with batteries, the switch can then be used to reduce the current.
When only slot #1 and/or slot #4 is used the maximum current is 1A. If there is any batteries in slot #2 or #3 the maximum will be reduced to 0.5A.
Below the switch is the display, by holding the switch down the display can be turned off/on (but not the leds), this will not affect any function in the charger.
DSC_8011
The display captured during startup where everything is turned on.
DSC_8012
Regular charge, the battery symbol is animated when the charger is charging.
DSC_8027
The charger has a led for each channel, making it very easy to see when it is finished.
supportedBatteryTypes
supportedBatterySizes DSC_8017 DSC_8018 DSC_8019
DSC_8020 DSC_8021 DSC_8022 DSC_8025 DSC_8024
The charger can easily handle 70 mm long batteries, inclusive flat top cells.
Measurements
  • Discharges LiIon with 0.2mA to 0.3mA when not connected to power
  • Charges with 0.2mA when LiIon battery is full.
  • Below 1 volt the charger will charge with 1mA, the display will be empty and the led green.
  • Between 1 and 2 volt the charger will charge with 33mA, the display will show voltage and the led will flash red.
  • Between 2 and 3 volt the charger will charge with 85mA, the display will show voltage and the led be red.
  • Above 3 volt regular charge current is used.
  • In the regular charge range the voltmeter is within 0.01 volt, at lower voltages the tolerance is slightly larger.
  • The meter updates the voltage reading fairly often (Better than once a second).
  • The meter stops updating above 4.20 volt when the charging stops.
  • Will restart if battery voltage drops below 3.90 volt.
  • Charge will restart charging after power loss or battery insertion.
  • If any battery is placed in either of the two center slots, the maximum charge current is reduced to 0.5A (A full battery in either center slow will also reduce the current).
  • When charger is powered on display shows 0.5A charge current, but charger will automatic change to 1A if a battery is put in slot #1 or #4.
  • Current select button will decrease current when pressed, i.e. 1A -> 0.5A -> 0.25A -> 1A
Xtar%20VP4%201A%20(PA18650-31)%20%231
First charge curve shows a very nice CC/CV curve with a termination about 80mA. This is a very good charge curve.
Xtar%20VP4%200.5A%20(PA18650-31)%20%232
Xtar%20VP4%200.5A%20(PA18650-31)%20%233
Xtar%20VP4%201A%20(PA18650-31)%20%234
The other channel does also work fine.
Xtar%20VP4%201A%20(BE18650-26)%20%231
Xtar%20VP4%201A%20(PA18650-34)%20%231
Different capacity batteries, need different charge time.
Xtar%20VP4%200.5A%20(PA18650-31)%20%231
Reducing the charge current to 0.5A, does reduce the termination current to about 40mA and uses the same good CC/CV curve.
Xtar%20VP4%200.25A%20(PA18650-31)%20%231
The 0.25A charge current uses a termination current of about 30mA.
Xtar%20VP4%201A%20(AW16340-IMR)%20%231
Trying to provoke the charger with my old 16340 cell does not show any problems, the charger handles it nicely.
Xtar%20VP4%200.25A%20(AW16340-IMR)%20%231
Reducing the charge current to the 16340, makes the curve more smooth.
Xtar%20VP4%200.5A%20(KP14500-08)%20%231
A 14500 cell at 0.5A works fine.
Xtar%20VP4%200.5A%20(AW18350-IMR)%20%231
Same with a 18350 at 0.5A.
Xtar%20VP4%200.5A%20(4xPA18650-31)
With four cells the current is limited to 0.5A for all slots.
Xtar%20VP4%200.5A%2012V%20(4xPA18650-31)
Using an external 12V supply, the charger draws nearly 1A while charging.
Temp1401
M1: 32,5°C, M2: 34,8°C, M3: 35,6°C, M4: 32,1°C, M5: 38,8°C, M6: 42,4°C, HS1: 43,4°C
With 0.5A charge current the batteries are not heated much.
Temp1400
M1: 33,0°C, M2: 35,0°C, M3: 35,3°C, M4: 32,9°C, M5: 44,6°C, HS1: 65,0°C
But inside some electronic do get warm.
Startup
The charger needs about 8 seconds to turn on and will always start charging at the highest possible current setting.
Charge
When selecting another charge current, the charger will decrease current fast and increase current slowly.
Testing the mains transformer with 2500 volt and 5000 volt between mains and low volt side, did not show any safety problems.
Conclusion
The charger can handle a wide range of battery sizes from 10440 up to 32650 batteries and has a good CC/CV charge curve. The display with the precise voltage readout makes it easy to check if batteries has been over discharged. The leds is a very nice feature, that makes it easy to see when batteries are charged.
It is a good charger with nice features, but not what many people had hoped for in a VP4 charger, i.e. 3 voltages and at least 3 currents.
Notes
The charger was supplied by Xtar for review.
Edited by: sb56637 on 06/25/2015 - 14:21
velvetant
I was pretty excited about this charger until I found out current is limited to 0.5A for all slots.
I know very little when it comes to electronics. Is 1A across 4 slots possible?
HKJ
HKJ's picture
velvetant wrote:
I was pretty excited about this charger until I found out current is limited to 0.5A for all slots. I know very little when it comes to electronics. Is 1A across 4 slots possible?
You can get chargers with 1A across four slots, the usual problem is heat, i.e. the charger and batteries gets warmer.
Some chargers solves that with a fan.
velvetant
I’m still a total newby when it comes to this stuff.
It was your reviews on different chargers that lead me to the VP2 which I absolutely love.
So when I saw the VP4 coming out I was super excited.
RaceR86
RaceR86's picture
Last seen: 4 years 3 months ago
Thanks for the great review! Smile
BLF LED database – collaboration spreadsheet and latest news about where to buy LEDs
http://budgetlightforum.com/node/19342
velvetant
Thanks for the great reviews, past and present.
jlobo
Last seen: 5 years 5 months ago
Great review!!
I know this charger can’t charge AA batteries, but can it test AA batteries?
HKJ
HKJ's picture
jlobo wrote:
I know this charger can't charge AA batteries, but can it test AA batteries?
The charger only shows how much it fill into the batteries. I.e. it can neither test LiIon or AA batteries.
ferongr
ferongr's picture
Last seen: 1 year 1 month ago
Would there be any reason to not buy this, getting a second VP1 instead? I use 18650s almost exclusively and charge them at 0.5A for longevity (and maybe a few more % of power?).
HKJ
HKJ's picture
The main difference is number of channels, you get 4 with VP4 and two with VP1, this gives an advantage to VP4
