little help plz - SF L2T bad switch ? forward clicky with multimode dropin ??
5 posts / 0 new
df2dot
not sure where the best place to post this
so i got my new L2T and i do not have my dropins yet ...
i figured i would test continuity after reading the SF XPG dropin post , well the LP has a forward clicky also when i depress both slighty i get continuity , the L2T after the click has none while the other one does maintain continuity , i tested a reverse clicky it maintain a circuit
this is certainly a bad switch right  ???? i dont have my dropins yet from MF but still, should i wait or email SF
2nd issue - very disappointed to hear forward clickies have issues with multimode droppins
i put the good forward clicky on a two mode light and it would not cycle the modes !!
any advice to fix that
thank you for your help
Edited by: df2dot on 08/14/2011 - 19:17
old4570
I have 3 L2Ts , and none have an issue , - but it can happen ..
Bad switch ?  Could be , If you can check the retainer ring - see if its tight . [ Without a first hand inspection ? ]
 Always remember , the easiest thing in the world to do , is to expel hot air from your lungs and through some vocal chords ..
The resulting sound may , or may not be worth listening too ….
df2dot
ok
i grabbed a couple spacers and clicked it a few more times , it actually came around ... weird. maybe needed a little working in.
thank for the reply , have you found a work around using a forward clicky with multi mode dropins , i am waiting for MF 3 mode xml
thx again for you thoughts
gcbryan
Last seen: 1 month 1 week ago
I'm not sure what your question is? There is no problem (in general) with forward clickies and multi-mode lights. Some people don't like using forward clickies with multi-mode lights because once clicked on they can't change modes without clicking the light off first.
I prefer them but just realize that I have to choose the mode before I click it on (or turn it off when I want to change modes). I like them for the momentary feature.
If you have a bad switch that's another matter of course.
old4570
df2dot wrote:
ok
Im not sure in what regard ..
If its just that its a forward clicky - you might be able to swap in a regular Solarforce L2 switch
If its that some may have a small momentary glitch that changes modes on you as you turn it on - Not really - other than swapping out the drop in or switch ...
