Recently after seeing some photos of them again I have come back to looking at the eagletac D25 series, for some reason the look of those lights to me have always just
screamed QUALITY.
I’m intrigued by the smaller dimensions specifically of the D25C2 Mini. It’s actually slightly slimmer than many AA lights because it runs 2xCR123 instead of an 18650. So when I found out about 16650’s I became even more intrigued. At 2500mAh (if true) they are nearly the same capacity as the 2600mAh Xtar 18650’s I’ve been running in my other lights.
It uses an XP-G2 R5. Unfortunately it doesn’t appear to be available in a NW version. I’m a big NW fan and nearly all of my lights are NW, I don’t like the bluish or greenish hue of some CW LED’s but I’ve read that some XP-G2 equipped lights were reported to have have a “pure white” tint that may be acceptable to me.
So I have a few questions for anyone who has one of these:
How would you describe the tint of the XP-G2 R5?
Will this battery fit the D25C2? 16650 KeepPower 2500mAh Sanyo UR16650ZTA 4.20V Protected Button Top
Will running it on a Li-ion increase the output above the rated 530 lumens?
“The internal cell is capable of being charged to 4.35V, but the protection circuit is set to 4.20V”
I guess this means even if I had a 4.35v charger these would only charge to 4.2v. So I wonder if these actually have 2500mAh capacity at 4.2v.
Although I prefer protected batteries for my EDC lights (in case of accidental turn on) I also found this unprotected battery from RMM: Efest ICR 16650 2200mAh - Button Top a bit slimmer, but slightly longer. Nothing showing about voltage, maybe not 4.35v?
According to ET this light only works with button tops, and protected battery is highly recommended:
“All batteries must have protruding top button. All rechargeable li-ion batteries (e.g. RCR123A and 18650) should be equipped with internal protection circuit against over-charge,over-discharge, and short circuit.”
So the Efest ICR may not be a good choice because the light doesn’t have any low voltage shut down protection.
Can someone recommend any other 16650’s for this and where currently to buy them?
Another concern is the reported loss of mode spacing on some of the D series lights when running on a Li-ion battery, or is that only an issue on the AA/14500 “A” versions?
