Ordered this 1w GREEN emitter to swap out the 6000k purple Emitter in the SK68 and it doesn’t work…. Did i order the wrong LED or is it a BAD led…I will try a CR123 direct to the MCPCB and see if it really is bad.
Unthread the pill from the front of the light. Then you can either pry the old driver out from the back, or push it out from the emitter side after removing the emitter.
The aluminium pill can be unscrewed, allowing access to the driver. This also allows you to remove the sliding head from the light, as well as check the o-rings, etc
Sorry to see it’s a hollow pill, but … well, it’s a lottery with the SK68 clones
