Review - XTAR RC1 Darkwalker
9 posts / 0 new
old4570
Last seen: 1 month 12 min ago
 http://www.xtarlight.com/05-chanpin/p-001-1.asp?styleid=354 : Product Page .
Review was very kindly sponsored by Xtarlight
For review is the XTAR RC1 Darkwalker :
Seriously , for starters - That's a cool name !
2nd , the micro USB port is not one I have seen before . I have a cable for digital cameras , but this one is slightly larger so dont lose the factory supplied USB cable . Xtar has certainly pulled this off well . I can see the RC1 being charged from any USB port , be it a USB to cigarette lighter adapter for charging in the car , or a USB wall adapter , your computer or one of your Xtar chargers with a USB charging connection . Oh heck even a solar panel that does 5v charging . This makes the RC1 seriously versatile as far as recharging goes .
 The build quality is excellent , it is a really well built light . So far I have nothing to complain about , it really is a quality product and one I hope stands the test of time . Lets move onto the forward clicky as it looks like some thought may have gone into making it a little extra trick ! When you press the clicky , there is a little bit of movement and then the light turns on ( sorry it is a forward clicky ) and you press further in before meeting any resistance . What we have , or I have , is a two stage clicky switch , much like the old two stage military triggers from 50 - 100 years ago . So the first stage is for your momentary on ( very little resistance ) , the second stage is for clicking on the light . I really hope this is not just a quirk with mine because it really is trick .
The emitter is really well centered in the orange peel reflector , and the light does look to throw well . Not nearly as flood'y as a XML , it is a little more reminiscent of a XR-E with not quite as tight a beam , but for those that dont like flood , you will probably love this beam profile . I can really see this light working for say a security guard that drives around all night shining his torch into dark places , with USB charging I dont see why the light would not be ready for use 24/7 .
 The machining of the threads , and the fit of the parts is excellent . O rings where they need to be and the threads are factory lubed for really slick operation . The anodizing is just excellent , and shaking the light really hard - there is not slapping around of the battery .
 Now lets talk about the USB charging , I got the light with the battery @ 3.75v .
To charge the battery , turn on the light and plug in the USB plug - it will automatically turn the light off and start charging .
It took one hour to get to 3.89v , another hour to get to 4.10v and an hour latter it was done ( well I checked after another hour ) @ 4.16v measured on completion .
There is a little red light that comes on to let you know that the battery is being charged and when the charging is complete it turns green . Also if you plug in the USB and the light is green , then the battery is not being charged . Pull the plug out , turn on the light and plug in the USB and it should start charging .
To get to the USB port , just unscrew the collar counter clock wise to open and clock wise to close it again . Dont worry , there are two O-rings to keep moisture away from the USB port , one above and another bellow the USB port .
The battery is fully charged so I will get back with some figures for output and current draw ..
Current Draw with factory supplied battery :
Low = 0.190A - 0.196A
High = 1.4A - 1.44A
These figures are what I measured ...
Output ( as close as I can get it )
Low = 60 Lumens
High = 421 Lumens
Throw @ 1 meter
Low = 2200Lux
High = 18000Lux
Left to right :
XTAR RC1 - Solarforce L2 - Thorfire VG-10
The RC1 is slightly longer than my two go to lights , considering the RC1 also charges the battery I think this is a very small price to pay for such convenience .  I simply can't think of a single negative thing to say . Im sure people will prefer this or that , or have an opinion , but to find fault ? I'm sorry , I cant think of anything to fault . Some one at XTAR set a design goal , a function goal , and the RC1 does what it was designed to do exceedingly well .
I am impressed by the XTAR RC1. In the past I had no experience with a USB charged light , nor did I see the need in one . But after having experienced the RC1 I can see a multitude of situations where the RC1 would make perfect sense . The convenience of being able to charge your flashlight almost anywhere from a multitude of sources is simply brilliant .
Two stage tail clicky ( by design or happy accident ? ) I love it either way !
High and low modes - I can live with it , 1.4A on high and 0.190A on low - I can live with it .
Forward clicky - I dont care , I know some people do - I just dont have a preference any more .. ( Its not rocket science )
USB charging - It works , and its not painfully slow .
The overall quality is excellent ,
Wow , this is a very nice flashlight and even if you were to hate charging VIA the USB port , this is such a nice flashlight and you could just pull out the battery and pop in a fresh one if the USB offends you . I am really looking forward to reading other reviews on this light , to see what other people think of it .
Bottom line is , would I recommend this light = YES ..
If the sample I have is the standard of all lights leaving the factory , I think new owners are going to be very impressed .
10 out of 10 Xtar - The RC1 is excellent !
 Always remember , the easiest thing in the world to do , is to expel hot air from your lungs and through some vocal chords ..
The resulting sound may , or may not be worth listening too ….
Edited by: old4570 on 07/01/2015 - 20:10
M4D M4X
M4D M4X's picture
Last seen: 8 hours 59 min ago
nice pictures!
this light would be nice to be compared to the Olight R20 and the Manker Rambler…
pretty the same concept Wink
which i like btw!
already member of M4DM4X.com ?
the best deals are waiting for YOU!
BIG THANKS for helping me by using my REFLinks
before you buy elsewhere mail me: MARTIN@M4DM4X.COM - i will try to save you money!
old4570
M4D M4X wrote:
nice pictures! this light would be nice to be compared to the Olight R20 and the Manker Rambler... pretty the same concept Wink !http://i1148.photobucket.com/albums/o562/Martin_Rathmanner/Manker%20Ramb...! which i like btw!
There does seem to be a few about ..
Rolz
Last seen: 1 week 4 days ago
Nice review of what is a very good torch it seems. Thanks for the review Smile
I still really like the design of the Solarforce L2 in the middle of one of the photos. One of my favorite designs.
jacktheclipper
jacktheclipper's picture
Last seen: 19 hours 46 min ago
Thanks for the review old4570 .
bugsy36
bugsy36's picture
Last seen: 7 months 1 week ago
Thank you for the review! I do not think that the switch is an accident as the BK50's I have had and the BK12 have both had that. Honestly I thought I was getting cheap lucky. Apparently not Smile
It's the simple things that we take for granted that cost us the most
Ευκαιρία λέει πιάσε με από το μέτωπο γιατί μόλις έχω περάσει δεν θα με πιάσειs
old4570
It is sweet ! ( two stage forward clicky )
ahirshy
Last seen: 3 years 2 months ago
Hi mate, your great review and 10/10 score has made me add this to my future-buy list. That future is always fast approaching when it comes to new lights!
One thing that worries me though is your assessment of the USB port being non-standard. Are you definitely certain of this?
XTAR's announcement blurb states "Micro USB charging port – Compatible with all USB wall adaptors or any USB power sources". I would find it very puzzling why they would use some proprietary USB-like shape when standard micro-USB is so well established and would bring the manufacturing price down. XTAR aren't Apple after allLaughing!!
Not to doubt your expertise in anyway (obviously I don't know if you're tech-savvyEmbarassed) - are you sure the camera's to which you are comparing are not mini-USB:
Many thanks again for the effort, it's much appreciated.
Keep shining,
Hirsh
old4570
So its a Micro USB , again not familiar to me , as this is the first device to use one ... Of this particular shape ..
Guess there is a first time for everything ..
Good call ahirshy
