NITECORE EC4 Review (2x18650,1050Lm,XM-L2)
26 posts / 0 new
FlashLion
FlashLion's picture
Last seen: 2 years 3 months ago
The EC4 is a new flashlight from Nitecore's Explorer series lights.
It comes with new ideas for body design and manufacturing. The EC4 is the first flashlight which is manufactured by Die-Cast process,allowing higher standards for density of the aluminum body and heat transfer efficiency.
According to Nitecore the new EC4 is-
200% the strength of an ordinary flashlight that consists of 3 separate parts;
The strength of the Die-cast body is allowing smaller dimension of the flashlight,respectively less weight.
Better cooling performance,thanks to the Uni-body aluminum construction.
Nitecore EC4 is powered by two 18650 batteries,side by side,electrically connected in series(or 4 CR123A).
For a better functionality,the EC4 is equipped with a standard 1/4" tripod mount point.
The big ring is actually the screw which does lock the tailcap in place.
Another novelty is the external finish of the aluminum.
Only the tail-cap screw is anodized.The rest of the body is Stoving-Varnish treated.
The surface is black/dark grey color,noticeably matte finish.
According to Nitecore,this type finish has great parameters for wear,corrosion,chemical resistance,impact resistance and hardness.
I can't comment on these points,because I don't do this type of tests.
18 cooling fins (nine on each side) ensure high heat transfer from the LED to the ambient air.
Unlike any other flashlight,here all of the cooling fins are positioned alongside the head.
Comfortable grip. There's no much grooves,or knurling,but thanks to its shape with flattened sides,the EC4 is easy to stably hold in the hand.
Size comparison-Left to Right
Nitecore EC4, Nitecore SRT6, ThruNite Lynx, Olight M22, Klarus XT11(2014)
The EC4 and the M22 have identical head diameter.
(Hint-the M22's diffuser fits perfectly on the EC4's head)
Weight with batteries:
Nitecore EC4 260 gr
Nitecore SRT6 197 gr
ThruNite Lynx 257 gr
Olight M22 193 gr
Klarus XT11 186 gr
Standard for Nitecore carton box.
All important info printed on it.
Really interesting and appreciated is the sectional view of the flashlight.
Great chance to learn what parts contains the EC4 and how they are assembled.
Accessories- good holster and lanyard.
You will find also well written user manual and warranty card.
The holster is big enough for the EC4.There is a velcro tape on the back.
The flashlight can be inserted in both directions(head or tail down).
Matte stainless steel bezel.Not crenelated,which makes it more friendly for pocket carrying.
Ultra clear glass lens-toughened mineral glass with anti-reflective coating for good light transmittance.
Cree XM-L2 U2 LED. Perfectly centered.
A specially designed aluminum reflector with smooth reflective surface.
The glass lens is very clean and transparent.
Anti-reflective coating in purple color.
Lets take a closer look at the Dual switch.
Two electronic push buttons with a silicon cap,separated in two zones by a small bridge.
The button with the four lines is for mode selecting. The other is for ON/OFF,as both of the switches have additional,hidden functions-directly activating Turbo,UltraLow and Strobe mode.
User Interface
I am impressed with the user interface and operation with the dual switch.
This is the best user interface I've tested and suits my way of using the flashlight,just perfectly.
Five brightness levels,plus 3 flashing modes.
Clicking the ON/OFF button activates/deactivates the light. Press and hold it for a second to activate Moonlight mode,directly from Off.
If you press and hold it,while the light is ON,this will activate the Blue indicator light under the button.Will turn the light Off,as well.
There is no memory for the indicator light. If you need the indicator light for easier locating the flashlight,you have to activate it manually,every time.
Click on the right picture to see the full user manual that comes with the flashlight.
The second switch(with the four lines) is for mode selecting.
Press it to select among UltraLow-Low-Mid-High-Turbo modes,while the light is ON.
Press and hold it to activate Strobe mode. Press and hold again to activate Beacon and again to activate SOS mode.
Short press will return the constant light mode.
If you press and hold the switch for a second,while the light is OFF,this will activate Turbo mode directly.
Double click(the mode switch) starts Strobe mode immediately from OFF.
There is memory for the last used mode,except the 3 flashing modes.
The mode memory is extremely quick and does not require any special timings for ON/OFF to make it work.
If you leave it on High mode,it will start on High mode,no matter how quickly will turn it ON/OFF.
The UI is quite easy to remember and use. I did not find any trouble using it in real life situations.
Quick and accurate response from the driver.
There is one more function of the mode switch. If you press it briefly,while the light is OFF,the blue indicator light will show the level of the batteries by simple blinking.
Three flashes indicates battery voltage over 50%.
Two indicates battery voltage below 50%.
One flash means the batteries need to be replaced.
There is also switch locking option. Press and hold both switches together,for over one second to turn the light Off and lock the switches.
To unlock,press and hold both switches again,for over one second.
I feel the switches well in my hand.Easy access to both switches.
My fingers are thin,though and in my opinion people with bigger fingers may find the buttons smaller than needed and also may have to press them with a nail. The buttons are almost on the same level with the aluminum around them.
The separating bridge works well for me and I am pressing the right switch every time when I have to.
A closer look.
A closer look at the Stoving-varnish finish and the grooves forming squares.
The cooling fins. You can see how smooth are all edges thanks to the die-cast process of making the flashlight's body.
All edges at the tail are very smooth,well rounded,too.
Good care to detail.
A thick rubber(probably silicone) gasket ensures excellent water-resistant sealing.
The EC4 can tail-stand not only on a table.It can be quite stable on different surfaces.
There is no protruding switch at the tail.
The thick ring at the tail end is a big screw. You can see the threads at both sides of the battery tube.
There are threads only on the surface between the batteries.
Two protected batteries fit pretty well in length and width.
No battery carrier.
Great care to the electric part of the flashlight.
Each of the two springs is doubled by a second,smaller spring.This ensures higher efficiency thanks to less losses in the springs(less resistance,easier current flow).
The driver board.
There is a physical reverse polarity protection. Flat top batteries can't be used directly.
There are stickers showing the right direction for inserting the batteries.
A very close look at the thick sealing rubber gasket.
Smooth aluminum reflector. Cree XM-L2 U2 LED.
1050 Lumens max output. 26000cd peak beam intensity(30kcd,measured by me at 3 meters).
The light from the EC4 is clean Cool white light,with no visible greenish or bluish tint.
The beam profile consists clearly defined hotspot and corona with good smooth spill.
As almost any actual flashlight,a smooth reflector is used for better focusing the light,aiming maximum distance of throw.
This sacrifices some of the beam smoothness,but beam is still quite good in normal use(not on a white wall).
Run-time Performance
Thanks to the dual battery design resulting in high total voltage, Nitecore EC4 performs impressively well.
Two 18650 batteries in series(or 4xCR123A) provides enough energy for stable output.
The output on all modes is constant,even on Turbo mode.
Unlike the single cell flashlights,the EC4's Turbo mode comes on the same output after every restart.
I did a few tests with different batteries.
I tested the output on Turbo mode,while the flashlight was cooled by small 8cm fan and also without cooling fan.
Room temperature ~25 degrees Celsius.
Three tests-With the cooling Fan on max airflow,with the Fan on very Low rpm,with no cooling.
According to Nitecore,the EC4 features Advance Temperature Regulation.
Unfortunately,I did not manage to activate it,or at least I don't see it,as I expected to be.
With maximum air cooling(simulating using the flashlight at places with cold climate,or in the cold seasons),the EC4 performs impressively.
The output starts from 1140 Lumens. 30 seconds later the output is 1067 Lumens.
The EC4 is maintaining just over 1000 lumens,through the whole battery discharge.
Checking the flashlight for overheating,I was impressed to find that the EC4 stays cool,even at this high output.
The second test with minimum air cooling,shows similar performance.The same time of discharge 98 minutes,nearly constant output.
Just 10 or 20 lumens less at some moments,due to more heating.
During the test the EC4 was warm,not too hot.
The third test was especially to test the ATR temperature control. No any kind of cooling was used. Static flashlight pointed at the light sphere.
I expected some kind of gradual step down as seen in the headlamp HC50,but here such step down does not exist.
The flashlight got very hot and I stopped the test after 10 minutes to prevent overheating. Lumen output 975 lumens at the tenth minute.
The flashlight may resist the heat,but it's recommended to keep the temperature of the batteries in normal range.
Batteries used in the tests- Keeppower 3100mAh,protected.
(Low voltage protection tests- Keeppower 3100mAh, Sanyo 2600mAh protected)
Only the first 15 minutes
My lumen measurements:
Fully charged Keeppower 3100 batteries.No cooling.
30 seconds after activation.
Turbo 1050 Lm
High 600 Lm
Mid 280 Lm
Low 114 Lm
UltraLow 1 Lm
Pretty well spaced brightness levels. A 50 lumen mode would be also useful,but one more mode may overload the UI.
I don't detect any sign of PWM on any of the modes,with the oscilloscope I use.
But,after using the flashlight for some more time,I can detect some noise(not sound) in the light on UltraLow and Low when watching a PC cooling fan. I can't confirm this is a PWM,because the oscilloscope,just doesn't see it. It's definitely not the usual pwm,maybe more advanced one,combining multiple signals... I don't have enough knowledge in electronics,so better not trying to guess...
The flickering should not be visible in normal use.
The Nitecore EC4 features also a Low voltage protection. To be sure it will kick in on time,the two batteries must have identical voltage.
If not,the low voltage protection of the battery with the lower voltage will kick in,before the EC4's LV protection.
In my tests,the EC4 did not show any indication by the blue indicator light,or by flashing main light,that the batteries are empty.
The low voltage protection turned off the light without any warning.
I did not test with unprotected batteries. I prefer to use protected batteries,for a little more safety, also recommend using protected batteries,especially in this flashlight.
Thanks to the efficient driver electronics and dual battery power source,the current draw on Turbo mode is just 1,7 Amp. High drain batteries are not needed for a good output. Any battery with a quality cell should be fine.
Nitecore EC4 has only electronic switches.There is no physical switch to fully disconnect the power to the driver circuit. When OFF,the flashlight is actually in Standby mode,which takes ~350µA from the batteries. This value is much higher than the value in all other flashlights I've tested. If you plan not to use the EC4 for very long time,it's recommended to take out the batteries,preventing over-discharging. Lock out the tailcap is not possible.
Beam shots
1 meter, 1/20sec
1 meter, 1/250sec
5 meters
1/6sec
5 meters
1/50sec
The Nitecore EC4 covers most of my expectations.
There are only a few weak points that could be improved in future models.
I found the EC4 quite comfortable in use,great constant output,good beam,fantastic user interface.
All these things makes the EC4 one of the best flashlights I have tested/reviewed and it definitely will become one of my most used lights.
The tripod mount thread makes it a good choice for a camping light,home work,or any other repair work.
Strong points- Build quality;Fresh ideas in the design; Tail-stand possible; Tripod mount option; Great fit in hand; High maximum brightness; Constant output on all modes;Well spaced modes; Great user interface; Quick access to Turbo,UltraLow and Strobe; Instant mode memory; High efficient driver; Deep smooth reflector results in great distance of throw; Impressively well maintaining the heat,while using on Turbo mode in cool ambient temperature;
Weak points-The dual switch may be uncomfortable for people with big fingers(depending on the way of pressing it); No output step down to prevent overheating; Very high Standby current consumption; No tailcap lock-out option; No warning from the indicator light,when the batteries are empty; The finish just does not look as good as quality anodization;
Thanks for reading!
Hope you found my review quite informative and helpful.
If you like my work,please post a comment below.You feedback is always highly appreciated.
- Thanks to Nitecore for providing the EC4 for test and review! -
Edited by: FlashLion on 08/18/2015 - 06:47
Wrathbringer27
Wrathbringer27's picture
Last seen: 5 hours 46 min ago
Nice review!! But your thrunite caught my attention heh
Words can be broken,
so can bones.
KeepingItLight
KeepingItLight's picture
Last seen: 5 hours 33 min ago
Outstanding work! Your review is top-notch.
I understand your point about tint artifacts in actual usage. You are saying that the green corona and purple spill that XM-L2 emitters are known to produce do not show up in normal flashlight usage with the EC4. In your white-wall shots and beam shots, however, I am able to see them clearly.
The EC4S model, which features the neutral-white Cree MT-G2 emitter, is due anytime now. It will be very interesting to compare it with the EC4.
xxx
xxx's picture
thanks for review flashlion
very nice, and great photos there
ryansoh3
ryansoh3's picture
Last seen: 1 month 1 day ago
Very nice review, thanks!
I really like the form factor, some good innovation in terms of flashlight design.
Too bad the standby current drain is quite high, hopefully this will be fixed in the next iteration.
With some quick calculations, it seems like the light will drain a 3000mAh cell in just under a year. (350 days)
I’d love to see owners of the EC4 report on how the finish holds up to everyday use.
BLF ≠ B-grade Flashlight Forum
Rolz
Last seen: 1 week 1 day ago
Excellent review with lots of high quality photos which really assist with appreciating the quality of the torch. Thanks for posting I enjoyed reading it. Smile
saypat
saypat's picture
Last seen: 5 hours 49 min ago
I read another review where the reviewer kept saying how little this light weighed. And yet, with cells, this light is heavier than all others listed! Do those other lights utilize one or two cells? Confused here.
anxiously awaiting the EC4S…
Henk4U2
Henk4U2's picture
Last seen: 56 min 35 sec ago
+1) If it had an on-board charger it would be the ideal all-round light in the household of a recovering flashaholic (doctors prescription: 1 light only!).
You are a flashaholic if you are forced to come out of the closet, to make room for more flashlights.
Trevi_lux
Trevi_lux's picture
Last seen: 4 months 19 hours ago
At first, it does not attract me much. But the interface got me interested by it and ask for a unit.
It’s just great, much lighter and adapted to the hand than you might think seeing on the web. Perfect balance, strength, endurance and very good runtime. Perfect for a weekend without extra batteries.
I will make a little review nextly.
Thanks for great job FlashLion (Pics are really Nice, nice…) .
kronological
kronological's picture
Fantastic, informative review.
Hope to hear more from someone on the coating they are using.
Thanks!
No one, after lighting a lamp, puts it away in a cellar nor under a basket, but on the lampstand, so that those who enter may see the light.
My Reviews: Ma
BanglaBob
Last seen: 4 months 5 days ago
Nice review, terrific photographs (as we have come to expect from you, FlashLion) Big Smile
Just looking at your images makes me want to buy one!
Lights out! That's when things get interesting...
Paul321
Paul321's picture
Last seen: 2 days 17 hours ago
Thanks for the review. Well worth reading,
Many casting grades of aluminum do not anodize well, that is most likely why this light is coated.
I am also interested how durable the coating is.
Paul-
seasam
Last seen: 3 years 3 months ago
nice review, great pics Beer
my only negative comment is that you are swaying me to pick one up with your post Tired
tatasal
Last seen: 20 min 38 sec ago
Excellent review…
FlashLion
FlashLion's picture
Thank you all,for the comments!
FlashLion
FlashLion's picture
The Lynx has the best beam of all five lights on the picture and the option for user defined modes is unbeatable option.
What is stopping it,to be one of my most used flashlights is the tailcap-it’s quite bulky and heavy.
saypat wrote:
I read another review where the reviewer kept saying how little this light weighed. And yet, with cells, this light is heavier than all others listed! Do those other lights utilize one or two cells? Confused here. anxiously awaiting the EC4S…
All flashlights on the picture,except the EC4 are single cell flashlights.
I don’t have other similar lights to compare-another double cell light I have is the Catapult V5,which is massive,more than half a kilo flashlight…
A Keeppower 18650 weights ~46 grams.
Here is the weight of all flashlights,without batteries:
Nitecore EC4 168 gr
Nitecore SRT6 151 gr
ThruNite Lynx 211 gr
Olight M22 147 gr
Klarus XT11 140 gr
KeepingItLight
The Nitecore P36 and Fenix TK35UE both are 2x 18650 models running the MT-G2.
According to the data published by their manufacturers, the empty weight for both is substantially more than the Nitecore EC4. The P36 checks in at 252g, with the TK35UE weighing 265g. Compare this with a dry weight of 171g for the EC4.
Due to its lower mass than these other models, I have speculated that the EC4S will not be able to sustain high output any longer than the EC4 can. But this is only speculation. I have no information regarding the actual lumen counts that will be offered in the EC4S.
I have the P36, and like it quite a lot. It has 10 constant-brightness levels, and an innovative mode dial that makes selecting one a breeze. On level 7, running on 3400 mAh fuel, it will give you a flat, well-regulated 850 lumens for 3 hours. Of course, with a new model like this, there is no track record of reliability yet. The worst I can say about the P36 is that is has a significant current drain when the power is off. You can lock it out, however, by unscrewing the tail cap one full turn.
The TK35UE also looks very good. It has a slightly floodier beam, and excellent regulation. Unlike the P36, it offers little or no tail standing. If you compare the outputs of the P36 and TK35UE on the runtime charts in the respective reviews by Selfbuilt, you will see that the P36 flickers just before reaching cutoff. I have witnessed this with my P36. The flickering shows up in the runtime charts as a bunch of rapidly oscillating up and down jumps. The TK35UE has none of this.
This flickering is of little consequence, however, because the flashlight has much earlier dropped-down from whatever high-output mode is running, and the light is minutes away from cutting off completely.
Ronin42
Ronin42's picture
Last seen: 7 months 2 weeks ago
First very good review
Second I am a big fan of Nitecore
Third the Nitecore 2×18650 is my favorite light (the p36)
But lets call a spade a spade.
Nitecore cast this light for one reason and one reason only, to save money all the rest is marketing.
The only reason I can see to put 8.4v-12v into a 3.3-4.2v emitter is they wanted to keep the series format (why) they already did the engineering? or to be able to drop in the MT-G2 (my prefered emitter)? I dont really know but I think it a strech to say this is a high efficiency driver. I am sure there are worse, but all that extra voltage has to go somwhere?
It almost looks like the EC4 is a compromise for their EC4S (as some point) I can see nitecore releasing a lower cost/price 2×18650 MT-G2 light Smile
The only nitpicky thing about your review is, you said “No output step down to prevent overheating” I am very sure that is why Nitecore builds their “ATR” circuit into a lot of their lights (including this one) I can tell you that as much as I want nitecore to use a light hand on regulating their lights the P36 will get “hot” if used (WOT) on non cold days.
Regarding the P36 (2000) vs the TK35UE (1800) the first step down on the P36 is 1500 lumens where it is 750 for the TK35UE. In fact the P36 then goes down to 1100, 850 it is not untill the 4th step down that the P36 drops to 600 lumens. My point being it looks like the TK35UE really is 1800 usable lumens on paper.
(“It’s good that most people can’t remember their previous lives. Otherwise
things would be a lot more complicated than they already are.”
Ajaan Lee Dhammadharo)
KeepingItLight
Ronin42 wrote:
Regarding the P36 (2000) vs the TK35UE (1800), the first step down on the P36 is 1500 lumens where it is 750 for the TK35UE...
It is interesting to speculate what the EC4S will offer. Its cousin, the EC4, has 5 output levels. The manufacturer's ratings (in lumens) for the EC4 are: 1, 80, 240, 520, and 1000. Spacing is not too bad, but it might be nice to have another level, around 25lm, squeezed in there. Something like 1, 25, 100, 240, 520, and 1000 might be ideal.
What will happen if the EC4S goes for big output? The P36 drives the MT-G2 to a nominal 2000lm. What mode spacing would Nitecore offer if it drove the EC4S to a similar level and used a similar interface, i.e., one that has only five output levels? Whatever answer you give, the spacing would not be nearly so nice as the EC4.
That's the problem faced by the designers of the Fenix TK35UE. To make things worse, the Fenix designers limited themselves to only four output levels. For the TK35UE, they chose (in lumens): 25, 250, 750, and 1800.
This is one place where the Nitecore P36 really shines. Its ten output levels—as rated in lumens by its manufacturer—are: 2, 20, 80, 210, 380, 600, 850, 1100, 1500, and 2000. This is very nice, even when you factor in Selfbuilt's lower estimate of 1850 lumens for the output on maximum. The key to this is Nitecore's mode dial. Selecting output levels could not be easier.
For what it's worth, all three flashlights, the EC4, the P36, and the TK35UE, decline from their maximum output level in a matter of minutes. More interesting is the output levels they can maintain—without stepdown—over a period of hours.
I am eagerly awaiting the EC4S. It is decidedly more coat-pocketable than the P36, and it might even be small enough for EDC if stowed in my daypack.
Wrathbringer27
Nitecore EC4 168 gr
Olight M22 147 gr
Klarus XT11 140 gr
The thrunite is discontinued right? That’s really sad Sad Any where I could get one?
so can bones.
FlashLion
FlashLion's picture
Some outdoor beamshots.Enjoy!
Three flashlights with pretty similar throw.
10000 ISO,because of the huge amount of insects,flying around.
Distance ~75 meters
...and something even more interesting.
I call it...FlyPainting Smile
beaconterraone
beaconterraone's picture
Last seen: 2 weeks 5 days ago
Anyone hear anything new about the EC4S (neutral white version)?
akhyar
akhyar's picture
You can check @Flashlion blogspot on his mini review and beamshots for thr EC4S
beaconterraone
Thank you. I’m most interested in release date. Silly
akhyar
akhyar's picture
Indeed. Relase date and street price :bigsmile:
tarver
Last seen: 3 years 4 months ago
do these lights have DTP ? what kind of star are the LEDs on ?
thx in advance
