Test/Review of Charger Micro 18650 Battery USB
This is a fairly cheap usb charger with a very simple and robust design. The body of the charger is in aluminum.
I got it from Gearbest (sku:132117301).
The only packing for this charger was a bag (I got it in a DHL envelope).
Power input is a micro usb connector.
The top of the pack is partial transparent and the indicator leds are mounted on the circuit board below.
Blue is no battery or charging finished. Red is charging.
The charger has a long spring, this allows battery sizes from 65mm to above 70mm (Long batteries may be a bit difficult to remove).
With the charger body of aluminium I was a bit worried about this situation, but the aluminium has some surface treatment that makes it nonconductive. Until this is worn off, the charger works fine.
With unprotected cells there will be a risk when the surface treatment is worn off, but not as much with protected cells (The protection will temporary disable the cell).
The charger can handle 70 mm long battery including flat top cells.
Measurements charger
  • When not powered it will discharge a battery with less than 1uA
  • Below 2.9 volt the charger will charge with 100 to 150mA (Higher current at lower voltage).
  • Above 2.9 volt is use regular charge current.
  • When battery is full it will discharge with less than 2uA
  • If battery drops below 4.10 volt the charger will resume charging.
  • Will not restart charging if a cell is reinserted or power cycled.
The charge curve is a nice CC/CV curve with 100mA termination.
With other capacities the time varies.
No problem with the old cell.
This time I added 1ohm, this is a weak usb power supply and a long cable, as can be seen the charger could easily handle it, but it do try to charge with full current.
M1: 38,4°C, M2: 39,4°C, HS1: 41,3°C
The aluminium construction assures that there is only small temperature differences.
M1: 37,3°C, M2: 39,7°C, HS1: 46,0°C
The charge controller (HS1) is the only thing that generates heat.
The charger starts immediately.
Slowly increasing the battery voltage from 0 volt shows no suprise, at low voltage the charger will use a lower current.
Conclusion
This is a nice small and simple charger that works well. Longer batteries can require a bit of finger strength to get out.
I have only one worry with it and that is how long the isolating surface treatment will last (Shorting a high current battery is not a good idea).
Note: Flat top with the plus pole below the isolation will be safe enough.
Notes
The charger was supplied by gearbest for a review.
Thanks HKJ.
This charger has a nice appearance but negative running through the aluminum body is a killer to me. Just thin, low quality anodizing preventing a dead short.
I would put some plastidip on that part where the + terminal could wear through the anno… Thanks for another great review HKJ!
I like this charger a very much. True, I did notice that protected cell got shorted at anode end while I removed it from the shell. I use small piece of kapton tape covering the edge to prevent it from happening. They should make thumb slot on both side instead of one, so that battery can be removed much easily.
If i see this correct, you could just file away a bit of material to make space for the +pole or are the pfotos misleading?
If that problem could be solved with that, this seems to be a verys nice travel-charger.
You could do that, but there are a few caveats:
If you start grinding away, the first that goes missing is the isolating layer.
The battery may not be removed straight out, i.e. you have to file a wide hole.
The circuit board in the charger is resting against the tube, if you file to much it is not held in place as good any more.
Another solution is to only use flat top batteries.
Interesting little charger…thanks!
Can it be used as a power bank?
No, charger only.
