USB Rechargeable LED Light Tube and LED flashlight and Portable Camping Lantern for sale
20cm 2.5W 5-Modes Outdoor USB Rechargeable LED Light Tube
Brand new and high quality;
LED chips, high brightness;
Initial Lumens(LM): 230LM;
Wattage: 2.5W;
Color Temperature: 6500K;
LED Brightness: 10, 40, 70, 100;
Voltage (V): 5V / 1000mAh;
Sheathing Material: ABS, Aluminum;
Product Size: 20x3.5x3.5cm;
Aluminum section case for heat dissipation, guarantee the long lifespan;
Built-in 18650 Li-ion battery 3.7V 1800mAh, use USB cable to charge;
There are 5 modes (High > Mid > Low > Strobe > SOS) that you can be chose;
Easy to take, even you can put it into your pocket;
It can be used in the night stall, maintenance / emergency, climbing / camping, power-cut, concert, trip, and warning, etc. The field of application is very wide.
Package Contents: 1 x USB LED Light, 1 x Strap, 1 x USB Cable, 1 x Manual.
Shop at http://www.onu-mall.com/20cm-2-5w-5-modes-outdoor-usb-rechargeable-led-light-tube-white.html
LT-20+3 20+3LED 350LM IPx4 2-Mode White Light Wrist Type Flashlight
Model: LT-20+3
Material: ABS
Switch Types: Button
Lumens: 350LM
Battery Format: 3 x AAA (not included)
Light Color: White
Run time: 2-4 hours
Whether focusing: no
Waterproof grade: IPx4
High power LED tent lamp can be used to read a book or play cards in a tent
23 super bright LED light bulbs, light weight, small size, can be hung, or in your hand, very convenient
It Can be a flashlight at night, or a lamp; also can be hung on the living room wall
When the lamp is not used, the hook can be placed in the lamp, very beautiful. Can be adsorbed on iron objects
Spray rubber surface, very comfortable
Attention:This product is magnetic, do not have the object or the magnetic effect of the object to be put together.
Shop at http://www.onu-mall.com/lt-20-3-20-3led-350lm-ipx4-2-mode-white-light-wrist-type-flashlight-red.html
Red Warning Night Lamp Portable Camping Lantern for Outdoor Lighting with Carabiner Hook
Compact size : 5.5 x 2.67 inch for travelling and storage;
Feature: high brightness, stable performance, 3 level of brightness adjustment;
Waterproof: IPX4, Max burn time: 50 hours;
Power source: 4pcs AA Batteries (not included);
Light Source: 4pcs white leds and 1pcs red leds;
Throwing beam: 15 meters, Maximum output: 210 lumens ;
It has red warning light and carabiner for outdoor using;
With durable Carabiner design, convenient to carry and use;
Perfect for Camping, Hiking, climbing, Travelling or other outdoor activities.
Shop at http://www.onu-mall.com/red-warning-night-lamp-portable-camping-lantern-for-outdoor-lighting-with-carabiner-hook-magenta.html
Please don't make a separate thread for every product you are selling. Instead list them all in one single thread.
Rules for Commercial Sellers
To be clear, I am not a moderator or administrator.
OK,thank you for your kind remind
