Test/Review of Vapcell IMR14500 700mAh (Yellow)
Official specifications:
  • Product: Vacell 14500 700mAh
  • Model: IMR 14500
  • Size: 14.0*49.0mm
  • Nominal voltage: 3.6V
  • Charge voltage: 4.2V
  • Typical Capacity: 700mAh (0.2C discharge)
  • Min capacity: 650mAh (0.2C discharge)
  • top: Flat top/button top
  • color: yellow
  • weight: 25g max
  • Internal Resistance: <80mOhm
  • Standard Charge: 0.5A, 4.20 ± 0.05 V, CCCV 100mA cut-off
  • Continuous maximum charge current: 2A
  • discharge cut-off voltage: 2.5v
  • Continuous maximum discharge current: 4A
  • Operating environment: Charging, 0°C ~ 40°C, Discharging, -20°C~55°C
  • Storage environment: -20°C~55°C, storage >3 months: -20°C~45°C
The AA sized high current LiIon from Vapcell.
Nice looking discharge curves, the cell performes well with nearly constant capacity up to 3A, but 5A is to much.
Conclusion
A good performing cell with both fairly high current and capacity, but the chemistry type used has a slightly low voltage at high currents.
Notes and links
The batteries was supplied by Vapcell for review.
Comparison to other LiIon batteries
putting this on my list of cells to get. Thanks and good review as always
