Can anyone step up for an AA/2AA only BLF budget flashlight?
318 posts / 0 new
DavidEF
DavidEF's picture
Last seen: 2 days 19 hours ago
bugsy wrote:
Yes, for example lights like Nitecore P12, Thrunite TN12, and Fenix PD35 use forward tail switch with side eswitch.
I’d like a budget light that used the A6 direct drive driver with SMO reflector, forward tailswitch, and side eswitch to blow away those other lights.
Okay, I’m still a newbie, so, what advantage do you get with a forward switch in the tail versus a reverse switch or no switch at all, on e-switch lights?
- The YKK Philosophy
bikenber73
bikenber73's picture
Last seen: 10 hours 43 min ago
I wonder if Simon/Convoy would build a 1 X 14500 / 2 X AA light. I would like a well made, affordable, 2-3 mode, no blinkies, maybe an XPG2 or XPE2  light.   Shadow made a cool looking Mini TC6  that I never got around to purchasing.
lichan
I recently got a Jetbeam WL-S1. My every day pocket carry is a Single AAA light but the Jetbeam is very versatile. It can use CR123a, RCR123, 16340, Alkaline or NiMH AA, 14500 (without carrying an extra battery tube) but what I use in it is a lithium ion that combines the diameter of a CR123a and the length of the AA, a 16500 purchased from eBay. With this battery and its larger head and reflector, it approaches the BLF A6 SE 18650 power and will still fit well in a loose pocket.
MountainKing
bikenber73 wrote:
I wonder if Simon/Convoy would build a 1 × 14500 / 2 X AA light. I would like a well made, affordable, 2-3 mode, no blinkies, maybe an XPG2 or XPE2  light.
Now that is a great idea! Maybe we need a custom blf driver though:)
Never ever forget and forgive. Niwal**er new kid on the block trying to act tough.
http://budgetlightforum.com/node/24847
Do not support this brand.
DINODIRECTSCAM COMPANY. DO NOT BUY
http://budgetlightforum.com/node/11324?page=2#comment-254983
presterjohn
Last seen: 2 years 10 months ago
bikenber73 wrote:
I wonder if Simon/Convoy would build a 1 × 14500 / 2 X AA light. I would like a well made, affordable, 2-3 mode, no blinkies, maybe an XPG2 or XPE2  light.   Shadow made a cool looking Mini TC6  that I never got around to purchasing.
That would certainly be a cost effective and popular choice. A slimmed down S2+ using an 1 × 14500 / 1 X AA + extension tube option would be excellent.
chuckhov
Last seen: 1 year 9 months ago
power911 wrote:
I personally like drivers that support both 14500 and nimh
The joy of pocket rocket without worry over hard to find batteries
Me too!
-Chuck
Pregulla
Pregulla's picture
Last seen: 11 months 3 days ago
The problem with forward clickie is that switching modes is a bit awkward with it. When you have 2 switches, you can have the momentary on at the tail switch (that is advantage for some), and switching modes with electronic switch.
I am personally fine with reverse clickie or e-switch only.
djozz
djozz's picture
Last seen: 8 hours 14 min ago
chuckhov wrote:
power911 wrote:
I personally like drivers that support both 14500 and nimh The joy of pocket rocket without worry over hard to find batteries
. Me too! -Chuck
I like that very much too, but if the 14500 compatibility stands in the way of a good AA boost driver I prefer a light without 14500 option.
I have many li-ion lights and love the possibilities and output. But I hate that I can never give one away without decent batteries, a charger and the full safety story on li-ions Tired  Last week I modded an AA zoomie with a dedomed XP-E2, and for a change I left the stock notsohigh-low-blinky AA boost driver in. And I was pretty happy about that, the performance had become way better with the dedomed R3 bin led, I gave it to a friend for his birthday (just like that, without a story at all).
bugsy36
bugsy36's picture
Last seen: 1 week 1 day ago
bugsy wrote:
Yes, for example lights like Nitecore P12, Thrunite TN12, and Fenix PD35 use forward tail switch with side eswitch. I'd like a budget light that used the A6 direct drive driver with SMO reflector, forward tailswitch, and side eswitch to blow away those other lights.
Different driver design required.
DavidEF wrote:
Okay, I'm still a newbie, so, what advantage do you get with a forward switch in the tail versus a reverse switch or no switch at all, on e-switch lights?
David...for me...momentary "on". The drawback is how modes get changed without the e-switch. Essentially you half-press from "off" til you get desired mode then either switch "on" or use momentary. E-switch makes much easier and user-friendly. Without an e-switch...probably a pita for most but I am accustomed to it because all of my "work" lights are forward clicky..even my A6's that I use at work.
It's the simple things that we take for granted that cost us the most
Ευκαιρία λέει πιάσε με από το μέτωπο γιατί μόλις έχω περάσει δεν θα με πιάσειs
DavidEF
DavidEF's picture
bugsy36 wrote:
bugsy wrote:
Yes, for example lights like Nitecore P12, Thrunite TN12, and Fenix PD35 use forward tail switch with side eswitch. I’d like a budget light that used the A6 direct drive driver with SMO reflector, forward tailswitch, and side eswitch to blow away those other lights.
David…for me…momentary “on”. The drawback is how modes get changed without the e-switch. Essentially you half-press from “off” til you get desired mode then either switch “on” or use momentary. E-switch makes much easier and user-friendly. Without an e-switch…probably a pita for most but I am accustomed to it because all of my “work” lights are forward clicky..even my A6’s that I use at work.
Thanks, I think I understand now. For me, a reverse clicky is fine and just e-switch is better. No need for two switches on any of my lights! Smile
ohaya
Last seen: 2 years 1 month ago
Instead one driver that supports both aa and 14500, why not have two heads with different drivers, and we can order with either or both heads.
sb56637
sb56637's picture
Last seen: 5 hours 19 min ago
I very much like the 1xAA format, in fact it’s what got me hooked on flashlights.
I would be the first to buy a custom BLF 1xAA light if it happened.
SawMaster
My ‘bug-out’ gear is AA powered or compatible so I could use something like this, and it would be a very good ‘gift light’ for non-flashaholics too. 14500 compatibility would be nice but not a deal-breaker. L-H or L-M-H would be all I need, L could be moonish but not too low. Priced right, I’d be up for a few or more.
AA is a world-wide standard, no matter where you go these are readily available, which can’t be said of many cell sizes we’re used to.
Phil
esrevenge
Last seen: 3 years 9 months ago
Im a big AA and 2xAA light fan.
I like them for ease to get batteries for and to use with eneloops.
phosphor
Include me, as well, the AA camp....would be very interested in a 2xAA.
Tumbleweed48
Last seen: 6 hours 31 min ago
There were some very good EOS 1xAA drivers available for a while from Int-Outdoors, but that supply seems to have dried up. I’ve modded three of my old Fenix L1P carcasses into very useful 3-mode lights. Those drivers would tolerate 2xEneloops in good humour, but over-volted at the sight of 2 alkies – and went plumb haywire with 2 lithium primaries. I only have a couple of those drivers left; I wish I could source some more.
Of the current crop of 1xAA’s out there, the one I’m lusting after is the Lumintop ED15. Very impressive run times. It might make a good BLF candidate, with a neutral emitter of some sort.
MRsDNF
MRsDNF's picture
Last seen: 22 min 45 sec ago
sb56637 wrote:
I very much like the 1xAA format, in fact it's what got me hooked on flashlights. I would be the first to buy a custom BLF 1xAA light if it happened.
BLF members rule number 1.
All late comers to the end of the line. Tongue Out
DanielM
DanielM's picture
Pulling rank huh? :bigsmile:
Old-Lumens wrote:
I love modding, but I don't have much use at all for flashlights in general.
Fritz t. Cat
Fritz t. Cat's picture
Last seen: 1 year 6 months ago
I don’t like them, because it is too easy to run down a 14500 battery. Some expensive drivers try to keep track of what voltage type the cell is, but I can’t see that being reliable. I suppose it would avoid having to carry one more light sometimes, though.
Flashlight designers should look at lighthouses and pottery.
这些谁设计的手电筒应该看灯塔,以及在陶器。
Wrathbringer27
Wrathbringer27's picture
Last seen: 1 day 23 hours ago
pleas let it be something that can run on single or double AA! I love the 14500 format too!
Words can be broken,
so can bones.
djozz
djozz's picture
It would be awesome if we could provide the whole package, as with the new K6: design the light and design the AA boost-driver with Attiny and BLF-firmware.
But who will be 'we' ??
'We' is someone with a lathe who can make a goodlooking host as an example for a manufacturer to copy, that is compact (compact is what AA size is about IMO) but still uses some standard parts, like 16-17mm switch board with small Omten, 14x8mm tail cap, and a 17mm driver, perhaps with a 18mm reflector like the Ultrafire C3 (the C3 is my personal favorite AA flashlight shape, but it has many -easily resolved- design flaws, so it should not be literally copied) or even the standard 20mm reflector that is also in the BLF-A6 (giving it a head diameter that is a bit wider than 'tubestyle).
And 'we' is also a gang of driver fiddlers who go ahead with the Attiny13 boost driver project and make firmware for it with nice modes.
And 'we' is someone with good contacts with seller and manufacturer to make the production and sales happen.
vēer
vēer's picture
Last seen: 6 months 3 weeks ago
Hehe, two heads you say :D? AA regular one and 14500 wider and deeper reflector for throw?!
bikenber73
I PMed Simon to see if there was a possibility of a Convoy AA light in the near future. If he can give us one with a few choices like he does with the 18650 lights than that might be an easy, affordable solution. I am not sure if he will get back to me though; he has been AWOL for a while.
ohaya
There’re a couple of reviews that just popped up this morning for the Manker T01. That seems close, but it’s a side switch only.
djozz
djozz's picture
ohaya wrote:
There're a couple of reviews that just popped up this morning for the Manker T01. That seems close, but it's a side switch only.
(warning: personal opinion coming up) I like everything about the Manker T01 except the styling: too MadMax for me, and I dislike grey too. And although I love its wide reflector for its performance, for a BLF-AA I think it is too big. (we should lend the Manker driver design: 500 lumen OTF from a single NiMh battery is a great achievement, just the UI is awkward)
vēer
vēer's picture
Wow, that T01 does look very good!
grayski74
grayski74's picture
Last seen: 10 months 2 days ago
A Convoy S6 style AA light would be great; its the kind of thing I am after (hence my use of a Thorfire TG05 currently).
Narrower, and shorter than the S6 obviously.
With the driver performance of the Manker T01 driver, if possible. Smile
Although I would be perfectly happy with just 500ma going to the LED on Max..
bikenber73
That Manker T01 with an optional extension might just fit the bill!
Fritz t. Cat
The only good looking AA lights I can think of are the Sipik SK-58 and a 2 x AA that looks nice but came with very cheap works. There is a type of 1xAA light with similar shape to the SS-5039, but it isn’t nice. I can’t say why except that the metal is too thin and the surface too smooth.
THAO916
Last seen: 3 years 8 months ago
I think a modded hugsby xp11 or 12 would be nice, Tom E’s modded TG06 would fit the bill and last but not least a BLF version of the olight s15 would be great too.
