Ugh, I've been dreading having to post this stuff for a looong time. I've lost the itch for the flashlight hobby quite a long time ago. I haven't been on this site, although seeing some of the new stuff I'm certainly tempted, and I will certainly be back (hoping to build some DST's over the winter). I just gave up on building lights for other people.
12/28 - Added new hosts and lowered prices of L2T's and clips. I just want these to go to a good home and be out of my house!
LIGHTS / HOSTS
$12 each - (2) SOLD Solarforce L2T, original non-tailstanding - Bought them to build lights for police officers and ended up not doing it. Ordered from solarforceflashlight-sales, opened them all up to inspect, put back in packaging and taped back up. All in new condition.
1.) SOLD $20 SRK - Original Sky Ray King w/ 3 x XM-L. Switched swapped out with blue LED switch (kind of crappy) which is illuminated when head is tightened. Have original switch but not the button cover. Cool white, original torrid driver.
2.) Gave to a friend $10 Convoy M1 - Scratched and chipped, reverse clicky, 3 mode L-M-H (I believe 5-30-100), XM-L neutral white, 3.2 amps, OP reflector
3.) SOLD $10 Convoy M1 - Scratched and chipped, forward clicky, custom H-L firmware (no memory, comes on in High, quick off-on to access low, XM-L2 neutral, 2.8 amps, OP reflector, access to MCU if you want to reprogram
4.) SOLD $10 Convoy M1 Host - Mint, unbranded, stainless clip, reverse clicky, original hardware w/o driver or LED (can include driver/LED listed below). Not the latest version, so no matte surface.
5.) SOLD $3 Ultrafire C3 - XP-G cool white, no clue what lumens, badly scratched tailcap, AA or lithium, OP reflector (one of the first lights I upgraded, no use for it anymore)
6.) SOLD $2 Black Cat HM-01 - AAA, really old, no clue what emitter, cool white, a decent keychain light with surprising throw
7.) SOLD $7 UniqueFire UF-2200 - Works intermittently, don't feel like diagnosing, reverse clicky, XM-L cool white, uses 26650 but includes aluminum 18650 spacer, SMO. Will include new 105C driver
8.) SOLD $18 Ultrafire UF-T50 SMO, cool white XM-L, custom firmware with 3 levels and ramping (hold to ramp up and down, double tap to go up one mode). Has some visible PWM and audible whine at mid levels, but not bad. Magnetic tailcap, no pocket clip. Not sure about parasitic drain when left off for a long period of time, never tested.
9.) SOLD $20 Ultrafire UF-T20 SMO, cool white XM-L, custom firmware with 3 levels and ramping (hold to ramp up and down, double tap to go up one mode). No visible PWM and no audible whine, but ramping down to the bottom makes it so the emitter barely lights up. If you then turn off and back on, emitter doesn't illuminate at the lowest level, have to switch up to low mode or ramp. Magnetic tailcap, pocket clip, includes spacer to use 14500 instead of 16350. 16350 not included. Not sure about parasitic drain when left off for a long period of time, never tested. Access to driver to reprogram (have to desolder switch pin off MCU leg)
10.) SOLD $5 Ultrafire C20 in parts. Took driver out with plan to replace with 105C w/ custom firmware, lost interest. No LED. No picture, but can get one if you want.
IF BUYING A HOST
$2 each - 3.04A NANJG 105C. Will include capacitor if you want to do off-time
$5 each (6) XM-L2 T6 3C on 16mm Noctigon
RANDOM
$3 each - (4) Solarforce Stainless belt clip
$7 - (1) HD2010 DX Aspheric lens and Vestureofblood adapter as found here - https://budgetlightforum.com/t/-/22597
SOLD $6 shipped for a pack of 10 2AA to D (parallel) adapters just like these - http://www.ebay.com/itm/5x-AA-to-D-Size-Battery-Converter-Adapter-Case-2A-AA-D-change-/381109696544?hash=item58bbe87820
$5 shipping for any item/qty in the USA only. Shipping is going to be a pain, and I'm going to try and charge what it will actually costs me.
If the prices are out of line just let me know!
PM me if interested.
- Jon
