I have only found drivers on/off, or rgb with pilot to set all the parameters, colours and brightness.
But I would like something like IKEA has - switch with 2 modes: dimmed to 10-30% (so it could be on as a backgorund light), or 100% - for cooking.
Do you know if I can find any driver like that “ready to go”, just plug in and use?
I’m not sure if this is the right forum… I hope so
Why stick at two modes? or mess about with drivers, as you said you want something quick and easy.
Just use a readily available dimmer switch from your local electrical wholesalers or DIY store, easy to install and you can set whatever brightness you want
