ArmyTek Barracuda V2
49 posts / 0 new
DB Custom
DB Custom's picture
Last seen: 3 hours 11 min ago
I just got my second ArmyTek light today, the Barracuda V2 with XP-L emitter and the redesigned smooth head with silver SS bezel. As expected, the heavy matte anodization is simply wonderful! This light has no knurling, no grip aid to speak of at all, relying instead on the grippy tendency of the heavy matte ano. I like it! Smile
The reflector is waaaaaaay deep, like twice the depth of the new MaxToch M24 Sniper I just got. But, alas, the XP-L is not exactly centered and the beam profile suffers for it. And they seem to have glued the thin bezel on, it won’t budge. (yet)
I got this because I’ve always wanted a Barracuda, always loved the finish on these ArmyTek lights. And also because of the constant current driver. I’ve got loads of FET drivers that die as the cell does, so I thought a nice thrower with constant current could come in handy. Well, it’s not all it’s cracked up to be apparently.
They rate it at 1470 LED Lumens for 675M throw, also they state 114,000 candela. I get 1110 lumens in my light box, 72.75Kcd for an extrapolated 539.44M throw. pretty weak, huh? By contrast, the new Sniper at much less monies does 256Kcd for 1012.42M throw. (This with a de-domed XP-L V6 1D, I killed the HI it came with, oops! The Sniper is still stock though, other than the emitter)
ArmyTek did send a single cell tube with rubber cigar grip that is removable, so that’s pretty neat, and it looks pretty awesome in that single cell format with it’s larger long head. Wonder if it’s more efficient on one cell? Hmmmm……
Anyway, I’ll get some pics later and post them up, get a beamshot tonight. And if I get inside, I’ll show that as well. Wink
Edit: Couple of revealing pics
Gotta show the exquisite ano and labeling first
And now a look at the emitter inside the ultra deep reflector
Closer look at the reflector itself…
Pretty sure the machine marks in the reflector are not conducive to a thrower. When I get the bezel off, I’ll hand polish this out in a top to bottom direction, or across the lines, I’ll use sandpaper first and graduate up to the Mother’s Polish that works so well. I’m betting the output and throw will show a marked increase at that point. We’ll see in a couple of days…
Edited by: DB Custom on 12/03/2015 - 17:43
emarkd
emarkd's picture
Last seen: 2 weeks 14 hours ago
My Predator Pro v3 XP-L HI is way under Armytek’s promised specs as well. They’re awesome lights in just about every other way, but they just don’t seem to perform as promised. Not sure what’s going on with that..
djburkes
djburkes's picture
Last seen: 2 years 1 week ago
I just want to see if you can get that sucker open…
marcl
Last seen: 1 year 6 months ago
I have been toying with the idea of picking an Armytek for a while. But I have to say this has put me off. As nice as they are, and they are nice, I would be pretty annoyed to receive a light that was 25% short on the lumens it promised.
Have any of you guys asked armytek about the problem?
Eagles may soar, but weasels don't get sucked into jet engines!
DB Custom
DB Custom's picture
Ordering a watch case back removal spanner wrench from Amazon that goes up to 60mm, 3 point, that should do the trick. Smile
Mitko
Mitko's picture
Last seen: 2 months 2 days ago
Yeah Amrytech have the best anodization that i have seen, unfortunately Barracuda V2 is maybe the most mod unfrendly flashlight in existance
The besel isnt glued, it just have kinda thicker o-ring and lotsa sillicone on the threat…just wait when you start removing the reflector Big Smile …mine came glued to the mcpsb…..insane eh?
The one cell option is great and it should give arround 3-5-3.8 tail amps, after dedome mod, spring and wires its as good as M2x
It could be a good flashlight if it wasnt so hard to get it open and mod cause by default its nothing special realy, yet the ano is great
Another great Armytek V2 thing is its AR glass: lovely
DB Custom
DB Custom's picture
Mitko, is your reflector polished mirror smooth? Mine shows the machine lines from when it was cut, big time, which totally kills decent throw.
And with one cell, it simply won’t do worth a darn. In my light box it CAN show 483 lumens but it will only flash it, then immediately drop to 265. It works fine with 2 cells, gotta figure this out on the one cell thing. Something’s not right.
Also, do you see a parabolic curve to the reflector or do the walls seem cut fairly straight? It’s such a deep reflector it’s difficult to get it to show in a picture…
F.i.l.a.s
F.i.l.a.s's picture
Last seen: 1 day 19 hours ago
Hello,
i had Predator XP-L HI a few days at home. Output was terrible for max, around 600 lumens I guess. PD35 Tac flashed out Armytek although they are such a different flashlights. Sure, throw was much more spotted with Armytek, but the brightness wasnt good. Finally, Armytek stopped working, output went down to zero point and finished. Thats just a small comparison. Great potential of XL-P HI, but a lot wrong with flashlight. Big disappointment.
DB Custom
DB Custom's picture
MOD it! :bigsmile:
Dang sure thing that’s what I’ll do if I have any more issue with it, I’ll put an FET driver in it and make it SING!
Mitko
Mitko's picture
Hm, strange….mine worked fine at 3.6 with a single cell, i actual got 3 on a promo localy ( bought them for 50% of their retail price)
The reflectors came perfect, not even a single machine line or even a single dust particle: i opened it with a number 41 socket wrench which in my case fitted very nice- on 2 of them, the third had a bit smaller ring so i left if for future tunning.. your post actualy surprice me greatly, well i was thinking that Armytek are hard to mod but always have great quality…it seems it aint true, or maybe you have a different revision…or i dont know what exacly
I still got one for myself( i will mod it when i have the time) and will keep it mainly for the anno and the reflector plus its lovely green AR glass
Since yours are kinda different revision lets hope the reflector isnt glued to the PCB- if i didnt saw this myself i wouldnt believe it
DB Custom
DB Custom's picture
I just tried an amperage reading and got 2.31 at the tail with 2 cells, stuck the single cell tube on and tried again and got a whopping 6.19A!!! It stepped down to 5.33A within about 20 seconds after going completely off then blinking a couple of times.
JungleCoffee
JungleCoffee's picture
Last seen: 4 years 1 month ago
...Thanks God. I received my Armytek. They even provide a CREE Color Chart on da banana box.
I love Canada brand !
HERE IS MY BEAUTIFUL DOBYMANN XP-L HI (LimiTeD EdiTion R)
Lovely...
Suum cuique
DB Custom
DB Custom's picture
I put it on the lightbox while taking a tail current reading. It only did 1090 lumens while pulling 6.33A at the tail. Messed up stuff right there, at that tail amperage it should be making 1600 lumens easy. It’s over riding that high current, stepping down quickly. If I put the tail cap on and try it, it flashes a high but immediately drops output.
JungleCoffee
No... You don't understand. Please, check back your tool. I am sure that your tailcap's reader is a poor made in China tester. Trust me... They are Canada'dry professional.
Read the Truth:
"We decided to implement in our products only the best LEDs and cutting-edge electronics made in Japan
and USA to obtain the revolutionary and unprecedented results.
You are able to throw almost all our flashlights from 10th-floor height and submerge them at 50 meters. Why? We’ve just put in such great margin of safety.
10 years no-hassle warranty.
We bust myths.
No more compromises. NO MORE! NOOO MOREE!!!
Forget everything you’ve known about flashlights before.
(God Bless China)
Suum cuique
DB Custom
DB Custom's picture
Sorry, I use a good Clamp Meter with a 12 Ga Turnigy wire for a loop. It’s accurate.
Perhaps you should slow down on the coffee….;)
Mitko
Mitko's picture
Hmm it doesnt seem right, maybe somehting is shorting the driver out
JungleCoffee sounds like someone that had a very bad time with that brand Smile
Keep us updated pls, it seems you have a different V2
JungleCoffee
...I think, they should "slow down" on their bla-bla marketing crap.
Dale? What happen to human kind? How such a huge and ridiculous amount of merchandising bullshit can be just accepted as a standard?
Well. Let's focus on politically correct topic. Led and Flashlight...
SB4 or 5B1? Is the V6 really that better than the V5? Is this possible to fry eggs on 20x 8C3 feed on 300A?
Suum cuique
marcl
Its Friday night and I’ve had a couple of beers and a glass of wine, but this thread has me beat! I’m not sure what’s going on anymore. Jungle coffee is not helping tbings .
DB Custom
DB Custom's picture
I know, right? ANSI ratings and all that, ArmyTek is SUPPOSED to be a top brand. I’ve wanted a Barracuda for a long time but wouldn’t pay full price. Finally, Black Friday gave me the opportunity, and now this. The reflector is just ridiculous, never seen it’s like even in a cheap budget light. The machining lines, ugh. And now it won’t function properly on a single cell either. I don’t know if I should return it or mod it. But the big attraction is in the driver, it’s supposed constant current capability. I guess I’ll talk to the supplier and see what they have to say.
Well, I’m not really into frying eggs on a light, but some of them can de-solder connections so that’s plenty hot to do it!
I like white light, neither blue nor green nor fire orange. That’s just me. Show me that emitter and I’ll stock up on em…
JungleCoffee
Mitko wrote:
Yeah (...)  Another great Armytek V2 thing is its AR glass: lovely
OH yeah... 99% transparency, so you can spot that awesome best in the World finish
33 1⁄3 rpm microgroove vinyl record Reflector style... Throwing crap...
Oh... I guess it's some limited edition vintage stuff...
Suum cuique
Mitko
Mitko's picture
Well, i am looking at the one that left here and its reflector is good( took pics, the best i could)
It seems that either that torch has several levels of quality or just you both are quite unlucky…or maybe yours are the US edition Silly …since you are close to Canada( its birthplace) its suppoced for you to be kinda patient for its disatvanrages…JK ofc Wink
JungleCoffee
Sorry, but your pictures show some low quality surface finish.
As you can notice all around the net, too many people get low quality reflectors (and other issues) from Armytek.
Damn. Look at Fenix product (just 1 example)? A cheap E20 can accept within 5mn a new emitter mod, without any donuts hole and 33 vinyle's style beam.
Well, Fenix, and many others DO NOT package themselves as some HiluxWesternCountry owned manufacturers. Hope you get that point.
I have nothing against Chinese manufacturers. I do not appreciate bullshit bla-bla-figures.
It should not be more than 8% of variations on such range of product.
72,000 Candelas... Jaa ja... not even 50k... 540m OMG! Revolution in AT 40mm head manufacturing process lol 400m with good lens. Thanks
Enough of such bullshit marketing/packaging.
Of course, some may not be agree with my point of view about business... They may prefer bring some, ortografk issue...
Suum cuique
Mitko
Mitko's picture
I just measured it:dual cells, 92 000 cds( dedoming doubles those)
Yeah i took that photoes with my S6, its a phone not a camera so they aint good
Olight Triton got like 90 000 as log as i can remember
For me its main issues is removing the reflector, why the hell it was glued to the mcpcb? helping the cooling prolly?
About your V2s…well, it seems they have issues, maybe a bad batch – if i were you i would return those, especialy if the reflector is that bad
marcl
Well I’m glad you guys got armytek out of my system.
Have you thought of PMing them and asking them to comment on this thread?
JungleCoffee
Mitko wrote:
I just measured it:dual cells, 92 000 cds( dedoming doubles those) Yeah i took that photoes with my S6, its a phone not a camera so they aint good Olight Triton got like 90 000 as log as i can remember For me its main issues is removing the reflector, why the hell it was glued to the mcpcb? helping the cooling prolly? About your V2s...well, it seems they have issues, maybe a bad batch - if i were you i would return those, especialy if the reflector is that bad
...Distributors are getting fed-up to deal with all those issues from AT. Guess what? They rather stock Olight than the so-called Best Chinacanada Flashlight in the World.
When is the last time GoingG. did review their products, 1 year? 2 years years ago?.. Yes, that's correct, they get definitely a better deal with Olight, Fenix or EagleTac. People review good products... Not fancy unreliable stuff.
They adopt a ridiculous cost-saving strategy, distributors start to ban them. Hey? Expensive moreover!
If they were clean, they would not glue so carefully their products (especially last v)
Just make a test:
Email them about ANY basic information regarding their products, they will answer you some ridiculous salesmen bla-bla. They cannot even speak English correctly (and yup! I know what I am talking about, at least I don't pretend to be British or American lol)
Check their website:
WHAT is that???
 We are proud to work for ????
REALLY?
Well> Check this out:
I proudly work for the
(3 months doing coffee and photocopy lol)
Tomorrow, I use the logo on my website and start to sell guess?
Suum cuique
Mitko
Mitko's picture
You know m8, thats how the world is goind nowadays, there is no more IBM or GMC quality ( from 80`s)
Audi you say? Well, didnt Audi( VAG group) cheated their customers lately? tens of millions of autos with a manipulated software
You know, 6 months ago i neeed a profi boroscope for my work( to look after gears in a wind generator) so we took a professional Olimpus and just as an emergency option a 160$ ALi chinese boroscope : Olimpus costed 3800$… after 3 months of casual usage its camera diode stopped( by casual i mean 2-3 times weekly, for an hour or so)….then after 4 moths its joystick failed…..yet, chinese one works perfectly
And Bosch….since i work for a construction company for the last 16 years i know what Bosch “quality” means
So lets dont talk about quality, quality is quite a relative term nowadays
JungleCoffee
Mitko wrote:
(....) So lets dont talk about quality, quality is quite a relative term nowadays
what do you mean by that? Brand means brand (image/symbol/mark) Quality is quality (product). Don't mix everything.
Quality- definition:
the standard of something as measured against other things of a similar kind; the degree of excellence of something.
Let me explain you what it is all about:
Good products from honest and professional people against greedy salesmen crap (talking about nowadays business...)
You are right regarding branded goods. Things have drastically changed since last past 30 years. What used to be symbols of Quality (read>brands) have become money making machine without high quality left (empty)
WHY? PROFIT MARGIN! MORE! ALWAYS MORE,,,thus less and less quality, until we have to eat shit.
But we are already in it:
Don't ask me to accept and agree with bad quality excuses and bullshit packaging in the name of nowadays floating values...
Send a mail to ArmyTek operator... you will understand what means poor nowadays quality...
Suum cuique
marcl
Bosch has a wide spectrum of quality most is crap. IMO household appliances are very poor but the Diesel pump on my Audi is excellent.
I think what jungle coffee is saying is that they pretend their lights are ‘Canadian’ made and of the highest quality, but both are questionable, especially reading this thread.
DB Custom
DB Custom's picture
I sent that pic to the supplier and he double checked his stock. The stock he has in hand looks like that, all of them. It’s the entire run apparently, so it wouldn’t do me any good to return it.
The build quality and anodization is second to none on this light. The AR coated lens, again, superb. Perhaps they had outsourced the reflector and got a bad batch, didn’t catch it? Perhaps an engineer decided this surface finish would be good? I don’t know, but I’ll change it myself and know I have it working the best it can be made to work. My reasoning is, if they couldn’t get it right the first time, why should I wait for them to try getting it right a second time?
I got a Predator from a friend on the cheap, love it. So I found this Barracuda V2 with XP-L emitter on a Black Friday sale and finally got one. A lawyer once told me, “Sometimes you get the bear, sometimes the bear gets you!”
DB Custom
DB Custom's picture
djburkes
djburkes's picture
Lol…got her open
