motorcycle driving lights need more output
Hi all have had these little led driving lights on the bike for a while, wondering if they are worth modding or not
And what could be done at present they draw .7of a amp and supposedly have 1000lumen
the bike victory vegas have hid in high beam
little lights
driver /led board
finally the optic 10deg I think
so are they worth it or should I start over.just wanting to pick up the kangaroos earlier.
Bump from me because I dont know but someone else may.
Probably not even T6 , so swopping to XM-L2 U3/U4 or XPL V5/V6 should get you up to 30% lumens boost at the same current.Dedoming should almost double throw.The R120 resistor at the top may,or may not be a current sense resistor,maybe someone else knows.No need for copper star below 3 amps,especially in airflow.It’s a start :wink:
I’ve never reflowed a led before perhaps if I get a pair of xpl hi stars and power with these
http://www.ebay.com/itm/Step-Down-12V-To-3-7V-3A-11W-DC-DC-Buck-Converter-Car-Power-Supply-Module-/310862157837?hash=item4860d4180d:g:B2cAAOxyeR9TL5cZ
Since there is a 12V power source I think you can do an XPH70 with a current limiting resistor and a suitable reflector or optic.
Bring the lights down if you like and we'll have a go at replacing the leds. It'll either work or not work.
Hey lostheplot
There’s a new review of some similar lights at: OZ LED Mini Trail Lights Review - webBikeWorld
I have heard of one where the cast metal broke at the mount, so people are reinforcing that bit with JBweld or equivalent.
I have this (reflector) version but haven’t been able to get the bezel off yet :
Thanks will have a look when home next
Will prob take steve up on his offer to reflow the old ones in the new year.
Meanwhile have orderd 4 x Xmls
Wich i am going to have a play with and some optics.
ended up with this 70 w osram has a tight beam and have splayed the smaller 10w light to the side ,also have bow put hid in hi and low beams,hope I don’t get flashed to much
thanks all for your input
I added some diffusers from fasttech which make the “cree” spotlights amazing daytime running lights.
No condom jokes !
well they stretch like condoms I guess
aren’t your headlights on at all times like ours?
You have certainly stretched those diffusers to fit.
Hows the triple going?
Wish I was heading your way for a holiday but dont see it happening this year. I wont let you forget you offered me a ride. Maybe you could come down on it for the MotoGP later this year? :stuck_out_tongue:
Yes, the headlight is on all the time, these are auxiliary lights.
The triple is going great, it’s all farkled up for touring.
A trip to the island for the MotoGP sounds good.
I know a few local blokes are planning to ride down in October.
