hello everyone. I am about to buy a protected battery for the blf a6 (my first 18650 flashlight) and i am between NCR18650B, ICR18650 - 30B, UR18650ZY and ICR18650 - 26FM and i want to ask if they can handle the current for the turbo mode (especially the first cell). Any other suggestion?
Well, if it were me, I would be buying UN-Protected batteries. And that is bacause now I have learned how to manage them. I use quality chargers, Xtar and Nitecore, and I ensure they cannot short-circuit.
Do not skimp on buying your charger. A quality Li ion charger is important for you safety.
But for a protected one, the NCR18650B battery will do nicely for you. That should provide plenty of amps for that flashlight.
The BLF A6 has built-in over-discharge protection IIRC, and therefore does not need a protected cell. It also performs better with cells meant for high current draw and some protected cells will not deliver that level of output. For this light a hi-draw un-protected cell will give you best performance but it will work on any that will fit. Which some protected cells will not fit; that can apply to many other lights so it’s not a shortcoming of this one in particular.
Others can give specific recommendations but I’m happy with my IMR 2500 Efest’s, a slightly noticable difference from the Samsung ICR 32A’s I had been using.
IF I where going with a protected cell, I would choose one with a sanyo NCR18650GA inside.
For example the KeepPower 18650 3500mAh has a NCR18650GA inside.
The Sanyo NCR18650GA is a 10A capable cell with a high capacity.
I use one with a Fet driver (the same one as in the BLF A6) and around 5A.
You don’t need a protected battery.
I think Samsung 30Q, LG HE2/HE4, LG HG2 are the best candidates for BLF A6.
Also, if you want more capacity there are SANYO GA and LG MJ1.
same driver in a custom modded AS31 that TomE built for me and with the Samsung 30qs He was getting aroundOhh – that was on a HE2 @4.21v, 5.09A tail reading…. The HE2 is bout the same as a 30Q, of course a GA cell will be less – think I posted #’s on that tooE built for so just what was recently shared with me and o am passing it on hopefully it will help.
I recall someone cautioning that the protected cells may have their protection tripped by the high-amp draw.
Not a problem, but if your light goes to zero all of a sudden, reset the protection on the cell.
Please, he asked for a protected cell, let’s not all try to push him to unprotected cells
I have used both kinds in the A6, and max output will be somewhat higher on, say, a 30Q but not so noticeably to rule out a protected cell (and spring bypass shall be applied for the high discharge to be fully available). A protected cell with a good discharge capacity will get you satisfied just as much, and gives peace of mind.
