Thrunite was kind enough to send me a Ti Hi to review.
Specs:*
Model: Ti HI
Thrunite’s main store website links:
Amazon US: Amazon.com: ThruNite
Amazon Ca: http://dwz.cn/1eGTT0
Amazon UK: http://amazon.co.uk/shops/A2DUUB2J3TY3X1
Amazon DE: http://amazon.de/shops/A2DUUB2J3TY3X1…
Amazon FR: http://amazon.fr/shops/A2DUUB2J3TY3X1
Amazon IT: http://amazon.it/shops/A2DUUB2J3TY3X1
LED: Cree XP-HI LED with a lifespan of 20+years of run time
Output and run time: Firefly: 0.08Lm(120hrs), Low: 10 Lm(6.5h), High: 120Lm(30 mins), Strobe:120Lm(1 hr)
Powered by 1 AAA battery (NOT included)
Working voltage: 0.9-3V
Dimension: 70mm*14mm
Weight: 14.3 gram without battery
OP Reflector gives perfect flood.
Titanium alloy body with polished finish.
Waterproof to IPX-8 standard(2M).
Convenient twist switch for one hand operation.
Operation:
Turn On /Off
Easily twist the head to turn on / off the light. Tighten the head for on and loosen for off.
Change modes
When the light is on, turn off the light and then turn it on within 2 seconds to change mode.
Memory function
Keep the light off between 2 to 10 seconds and then turn it on, the light will turn on in the last mode accessed, except for strobe. Over 10 seconds and then turn it on, the light will get back to low mode.
Hidden strobe
Screw on and off the head for 6 times to activate hidden strobe mode.
Review:*
So the Ti Hi is the upgraded version of the Ti3. It is primarily the same flashlight with 2 exceptions. First the body is made of a titanium alloy as opposed to aluminum. The second difference is use of the XP-Hi LED. This from my understanding, is a pretty recent addition to the LED market. This is a factory de-domed LED that is “high intensity”. The Ti3 and Ti Hi share the same modes, lumens, and runtimes and the beams are very close as well. The major difference between the 2 being that the Ti3 has a slightly bluish tint compared to the Ti Hi and that the Ti Hi appears to have a slightly more organized beam with a more clearly defined hotspot. It doesn’t show well on camera, but it is definitely a sharper whiter tone. I’m not sure if this is just a temporary offering, but it adds to Thrunite’s lineup for titanium offerings.
Beam Shots:
Ti Hi Vs Ti3
Ti Hi Vs Ti5
Ti Hi Vs BLF 348
My video Review
