Astrolux S1 (BLF A6) measurements
29 posts / 0 new
maukka
maukka's picture
Last seen: 1 day 4 hours ago
UPDATE 31.1.2016: added color rendering graphs and new lumen measurements using a diy 30 cm integrating sphere
UPDATE 28.1.2016: updated the beamshot and spill cie graphs with more accurate measurements and differentiated between the hotspot corona and the outermost spill corona, faster sampling rate (2 sec) on the Turbo stepdown graph
UPDATE 27.1.2016: added info about runtimes and temperatures to the end
Astrolux S1 is better known as the BLF Manker A6 (Special Edition). The rebranded version is supposed to be identical to the A6 that was put together by BLF forum members. It has an advanced driver with extensive functions. Read more about the firmware and operation at http://toykeeper.net/torches/blf-a6/final/blf-a6.txt
The Astrolux S1 differs from the original in that it comes with a 18350 battery tube to shorten the light. The aluminum finish is excellect for the price (currently $30). A lanyard and a non-reversable pocket clip are included as well as two extra o-rings for the 18350 tube. There’s also a spare tailcap switch.
S1 weighs 76 grams with the 18650 tube and 55 grams in the 18350 form. Dimensions are 121/88,2 mm x 24 mm.
The light has a claimed output of 1400-1600 lumens in direct drive turbo. This can be achieved with a spring bypass and using high current 18650 batteries. I only managed about 1000 in the stock form with the batteries I had on hand (Eagtac 3500 mAh, Sanyo NCR18650BL, LG MH1). Turbo mode steps down to High 2 after 45 seconds.
The rubber switch is located in the tailcap. Deep press activates and shuts down the light and half presses (taps) switch modes. Longer half press cycles the modes backwards. In total there are 4 or 7 modes depending on how the user has programmed the light.
In group 1 the modes are Moonlight – Low – Medium 1 – Medium 2 – High 1 – High 2 – Turbo. In group 2: Low – Med – High – Turbo. Special modes (10 Hz strobe, battery check, biking flasher) can be accessed from the moonlight mode with a 0,5-1,0 second tap (cycle backwards). I accidentally named the lowest mode firefly and not moonlight in the images, I’ll fix it later.
The emitter is Cree XP-L with a choice of three tints: 1A (6500 K), 3D (5000 K), 5A (4000 K). The light I tested is the 3D variant.
The beam angle is 78° with a hotspot of 22°. Color temperature is noticeably cooler in the spill area and greenish around the hotspot. I wouldn’t call the beam beautiful tint wise, but the hotspot isn’t too bad.
There is PWM in all modes but turbo, but it is not visible even to the most sensitive people. The switching frequency is high and the output doesn’t drop to zero as is the case with traditional PWM. So no worries there.
Because of high frequency and narrow modulation PWM is invisible to the eye even in moonlight mode. Top: absolute (DC coupling, horizontal center line 0 lumens), bottom: zoomed in (AC coupling)
See all the scope screenshots here:
http://imgur.com/a/xsere
18650 battery, Astrolux S1 (18650 tube), Eagletac D25LC2, Zebralight H600Fd III
18650 battery, Astrolux S1 (18350 tube), Eagletac D25LC2, Zebralight H600Fd III
Measurements
Please note: lumen measurements are only rough estimates
My diy 30 cm integrating styrofoam sphere has been calibrated using a Fenix E05 on high with manufacturer’s claim of 85 lumens. Verified with an Olight S10 that has been measured with a Labsphere FS2 integrating sphere by valostore.fi. Results may be more inaccurate with especially throwy or floody lights.
For spectral information and CRI calculations I have an X-rite i1Pro spectrophotometer with HCFR for the plot and ArgyllCMS spotread.exe for the data. For runtime tests I use spotread.exe with a custom script and a i1Display Pro because it doesn’t require calibration every 30 minutes like the i1Pro.
Explanation of abbreviations
CCT = correlated color temperature, higher temperature means cooler (bluish)
CRI (Ra) = color rendering index consisting of 8 different colors (R1-R8), max value 100
CRI (R9) = color rendering index with deep red, usually difficult for led based light sources, max value 100
TLCI = television lighting consistency index, max value 100
x,y = coordinates on a CIE 1931 chart
Spectral distribution
Color rendering (Turbo)
See explanation here: http://budgetlightforum.com/node/44570#node-44570
Tint
Different brightness modes
Tint towards the edge of the spill and corona.
Runtime (Turbo & High 1)
The light steps down to High 2 after 50 seconds, so I didn’t measure High 2 separately.
Zoomed in
First two minutes on turbo.
Temperature
The light gets quite hot in Turbo/High 2. When running without a fan I measured 54°C on the head at 5 minutes and 62°C at 10 minutes. Grip was 53°C at 10 minutes. I consider anything over 50°C uncomfortable to hold with bare hands for more than a couple of seconds.
After turning on a fan at 12 minutes, the head dropped under 50°C in 3 minutes while the grip temp had decreased down to 44°C.
Thermal imaging of the first 5 minutes
https://youtu.be/fdAU7SE2-sU
Edited by: maukka on 01/31/2016 - 09:34
bugsy36
bugsy36's picture
Last seen: 2 weeks 2 hours ago
I am liking your tests. Thank you!
FYI....get a Samsung 30Q and bypass the spring and that light will be a different light
It's the simple things that we take for granted that cost us the most
Ευκαιρία λέει πιάσε με από το μέτωπο γιατί μόλις έχω περάσει δεν θα με πιάσειs
Rolz
Last seen: 19 hours 27 min ago
Really impressive review. Thanks for posting.
keengeorge
Last seen: 11 months 2 weeks ago
Good Day maukka, Smile
Great review with Very useful measurements.
Thank you Very Much,
George
djozz
djozz's picture
Last seen: 18 min 51 sec ago
Thanks for another great set of numbers, on a well-known light Smile
EyeballFryer
maukka – I love these CRI and color temp tint charts you’ve been doing. I would like to see measurements on more neutral white lights and also cool white lights, just to see how they compare. Maybe you can compile the charts into some kind of database that people can look up.
Andyman
Thanks for the informative review! Just got mine a few days ago too, and I’m very impressed. Looking forward to trying a spring bypass (it’ll be my first – might practice on a cheaper light first…)
akhyar
akhyar's picture
Last seen: 1 month 1 week ago
Thanks for a very excellent review
maukka
maukka's picture
I will compile all the measurements in to tables and graphs at some point.
Here’s the tint graphs for Eagletac D25LC2 Nichia and Zebralight H600Fd III that are neutral:
And a couple more lights in the same graph:
chuckhov
Last seen: 1 year 9 months ago
I understand most of it, but just what does D50 – D55 mean? – Duh… Smile
Love your posts! – Thank you!
-Chuck
maukka
maukka's picture
They are simulated daylight illuminants. More info: https://en.wikipedia.org/wiki/Standard_illuminant#Illuminant_series_D
chuckhov
Thank you. – Looks like I have a lot to learn Wink
-Chuck
sixty545
Last seen: 4 months 3 days ago
Impressive testing!
Can you tell which instrument you used for color measurements?
maukka
maukka's picture
Sorry, forgot to add information about the measurement devices used.
sixty545
maukka wrote:
Sorry, forgot to add information about the measurement devices used. For spectral information and CRI calculations I have an X-rite i1Pro spectrophotometer with HCFR for the plot and ArgyllCMS spotread.exe for the data. For runtime tests I use spotread.exe with a custom script and a i1Display Pro because it doesn’t require calibration every 30 minutes like the i1Pro.
Thanks, i1Display Pro seems to be affordable, found it at 200$.
I guess you just shine the light into its diffuser, from a distance?
maukka
maukka's picture
Exactly. The i1Display Pro is a colorimeter, ie it has three light meters with filters inside. It is not as accurate as a true spectrophotometer but for output testing it is fine. Although if you don’t need a colorimeter for monitor calibration but just for runtime or lux measurements, I would probably just get a loggin lux meter like Extech HD450 that is comparable in price but easier to use (no 3rd party software required). But then again, with the right software the i1Dispay Pro can roughly estimate color temperature too.
MountainKing
Oh we just found BLF-selfbuilt Silly
Thanks for this review man.
Never ever forget and forgive. Niwal**er new kid on the block trying to act tough.
http://budgetlightforum.com/node/24847
Do not support this brand.
DINODIRECTSCAM COMPANY. DO NOT BUY
http://budgetlightforum.com/node/11324?page=2#comment-254983
sixty545
Exactly. The i1Display Pro is a colorimeter, ie it has three light meters with filters inside. It is not as accurate as a true spectrophotometer but for output testing it is fine. Although if you don't need a colorimeter for monitor calibration but just for runtime or lux measurements, I would probably just get a loggin lux meter like Extech HD450 that is comparable in price but easier to use (no 3rd party software required). But then again, with the right software the i1Dispay Pro can roughly estimate color temperature too.
Something for you, Djozz ?  are you reading this?
maukka
maukka's picture
More info on runtimes and temperature at the end of the first post.
MRsDNF
MRsDNF's picture
Last seen: 4 hours 38 min ago
Excellent testing info. Thanks.
maukka
maukka's picture
I updated the beamshot and spill cie graphs with more accurate measurements and differentiated between the hotspot corona and the outermost spill corona.
maukka
maukka's picture
With an updated integrated sphere (20 cm styrofoam sphere many people seem to be using) I measured 1076 lumens out of the S1. This is a 14 % difference to the earlier measurement of 945 lumens where I used a styrofoam box. Same battery (Eagtac 3500 mAh) was used.
With less bright lights in my other reviews the difference is only about 3 % across the board, with some exceptions on some really floody lights (DQG Fairy). This is mostly due to similar beam profile to the Fenix E05 AAA that I use to calibrate my readings. I will update all the tables after some more experimenting. I also got a 30 and 40 cm spheres to test.
maukka
maukka's picture
Added color rendering information to the OP. See explanation here: http://budgetlightforum.com/node/44570#node-44570
maukka
maukka's picture
Tried the 30 cm styrofoam ball and got some more measured lumens, 1095 to be exact. This is 1,7 % higher than with the 20 cm sphere.
Some comparisons with different integrating spheres I’ve tried.
The 30 cm sphere has a sanded (1200 grit paper) inner surface. On both spheres the measurement is done on the surface. Thanks to djozz for the idea here http://budgetlightforum.com/node/39409
In my sphere the flashlights rests on top of a transparent plastic sheet level with the inner surface.
Nicolaas
Last seen: 4 months 1 week ago
Maukka: Thanks for the impressive tests. Your report is so clearly written and the graphs are so easy to read that even I can understand them. Wink
Very thorough and easy to use, an absolute pleasure to read, please so more, MOAR!
Grtz
Nico
maukka
maukka's picture
Got some Efest 18350s to test with the shortie tube. Here’s a runtime graph.
Didn’t verify lumen output compared to the 18650 tube & Eagtac 3500 mAh yet but I’d estimate it is similar at about 1100.
maukka
maukka's picture
Measured the lumens with the Efest 18350 and it is essentially identical with the Eagtac 18650. 1050 lumens on the 18350 vs. 1090 on the 18650. Also tried the new Samsung 30Q (flat top…) and only got 1004. I haven’t done the spring bypass and the Samsung doesn’t even have 1 full cycle on it yet so the output might change.
I’m really liking the smaller 18350 size and will leave that on for edc.
KaiserSosa
KaiserSosa's picture
I concur that the Astrolux S1, especially in the 18350 config is an EDC dream.
I also love my tiny Olight S1 at 500 lumens….but for just a little more pocket real estate, you can get 1000 lumens…just wow !
Had this little pocket rocket last night when the timer field lights went out unexpectedly at my son’s baseball practice.
This little pocket rocket lit up the WHOLE place…and made a serious statement.
A flashaholic just lives for those moments…….lol
kamote1half
Last seen: 3 years 3 weeks ago
I would agree with you. The option to choose dual modes and to turn the momery on or off is the biggest advantage of this light. This is the light I have been looking for! Thanks to everyone behind this light.
Ready. Set. Light.
