MiniReview: ThorFire Upgraded C8s
13 posts / 0 new
unknown00101
As you’ve probably already read, ThorFire’s upgraded C8s was recently released. Several BLF members have already done a great job detailing the upgrades and overall flashlight. So I will just add a bit and reinforce some of what has already been said.
Freefly’s Addendum: http://budgetlightforum.com/node/45901
ReManG’s Review: http://budgetlightforum.com/node/45868
Tailcap upgrades:
A while back I bypassed the driver and tailcap spring on almost every single flashlight in my possession. That included the older Thorfire C8s threaded pill version.
Tailcap current (Amps):
Mode ThorFire C8s Bypass V2 ThorFire C8s Stock V3
Moon .02 .02
Low .09 .09
Medium .80 .792
High 3.20 3.18
Measured with a 30Q at 4.17v there is very little difference between the two. It appears to be the same driver in both versions. Spring bypass seems to do very little here.
All throw measurements are lux values taken at 7ft and calculated back to 1 meter (Rounded to the nearest hundred). Ceiling bounce numbers are just simple lux measurements of various lights to compare relative output.
The C8s stands up very well in the variety of lights. The output and throw of the new C8s is comparable to the notably larger X3. The new C8s also destroys the rather outdated XML Convoy C8, doubling the throw with a significant increase in output.
This is the older threaded pill ThorFire C8s version:
The upgraded ThorFire C8s:
The copper mcpcb thermal pasted onto the shelf. There is a small divot in the integrated shelf (little anodized spot in the center).
The underside of the integrated shelf.
Simply put, the upgraded ThorFire C8s is a very nice flashlight. It is the best C8 I own, with the older threaded pill C8s coming in second. I like the upgrades to the tailcap very much. I never really noticed how recessed the old tailcap clicky was until I got the upgraded version in my hands. The switch is quite substantially easier to access now. Great job ThorFire. Smile
I’d like to see perhaps an XPL-Hi version, and/or tint options as possible future upgrades/enhancements.
Edited by: unknown00101 on 04/07/2016 - 01:16
ReManG
Great review, glad you had the previous model with the threaded pill for comparison. Good to see the driver was the same.
Thanks!
ALL of my links are non-affiliated for your pleasure...
My Reviews
Lithium Ion Battery Safety 101
The Miller
The Miller's picture
Last seen: 2 months 1 day ago
nice to see them C8s all four in a row
And I learned a new word “divot”
So thanks for the review and the education!
KeepingItLight
KeepingItLight's picture
Last seen: 14 hours 50 min ago
Great pics. Nice review.
Thanks for the teardown and comparison with the previous C8s.
Killforfood
Killforfood's picture
Last seen: 2 years 1 month ago
It’s a commonly used Golf term to describe the hole in the turf that the golf club tears up. There’s always a sign that says “Replace Your Divots”.
You could lay pipe in my divots. Facepalm
Nice review unknown00101
This looks as good or better than a Convoy.
I believe I’ll get one to compare.
CPF to BLF Convert
RobertB
RobertB's picture
Last seen: 1 hour 6 min ago
I have both the Thorfire C8S and ME’s Convoy C8 de-domed. Adding the de-dome service from Richard puts it in the same price point as the Thorfire C8S. The de-domed C8 throws a touch further, and is a much warmer tint. Plus, for another $2.5, you have the option of guppydrv firmware.
I do really like the new tail cap on the C8S, so it now lives on the Convoy!
de-domed C8 on the right
Convoy with the Thorfire tail cap
Killforfood
Oooh Cool! I just had a Lego Land moment. I was wondering if my Convoy battery extension tubes will fit the ThorFire C8 and you just answered my question with that tail-cap swap. By the way, that tail-cap looks like it was made for the Convoy.
I prefer the de-some tint. Spot looks nice as well.
CPF to BLF Convert
cncyana
thank you for the review!
I like that new knurled Thorfire tailcap too. It is a good upgrade to have.
If we’re thinking about next-gen mods, I’d like to see a 20mm driver shelf for the GXB20 driver – a single lithium XHP50 driver. Also a 21mm bore for the latest hi-drain Samsung battery. I would love for Thorfire or Convoy to make one!
Life’s Questions/Answers here: http://www.answersingenesis.org/home/area/qa.asp “So then, each of us will give an account of himself to God.” Romans 14:12
Dusty
Last seen: 2 days 2 hours ago
The c8s I received in November has a 19mm driver, different from the older c8s (and the ones I see in these reviews, with the new tailcap), and regular c8 models, with a 17mm driver. The actual shelf is closer to 19.5mm on mine. I haven’t seen any new posts on this for a while, so I don’t know if it was a production change, or a fluke.!C8s photo 1207161158_zpsho6aet3e.jpg!
Brian
khas
Last seen: 1 hour 12 min ago
I received two from this seller on Aliexpress, one late March and one mid April both had a 19.6 mm driver.
Dusty
Glad to see it wasn’t just me. Mine came from Thorfire Direct on Amazon. cncyana, is halfway to his goal. Honed to his preference (considering his screen name), would leave the tube pretty thin, but maybe do-able. It certainly does give me ideas for the + 4 of these I have (only 1 with the larger, driver). These really are the bomb for $14 or less. Thumbs Up
Brian
cncyana
Thanks for the info guys.
DB asked J-Dub about a 20mm bore C8 from Convoy – don’t know the outcome to that question but I think the tube will indeed be pretty thin, especially at the o-ring grooves and clip grooves on the tube itself.
Convoy will need to make the tube, and thus the tailcap, larger in diameter – which is pretty much a total remake of the host. A task not likely to be adopted by Convoy, especially since the 20mm and 21mm diameter batteries are not very popular yet.
Our only hope at the moment may be the upcoming C8-sized host that Texas Lumens is working on. I say “C8-sized host” since it will probably look nothing like the Chinese C8.
cncyana
Another question. I notice some C8 tailcaps are rather long, thus making the whole light longer.
I assume this is due to those tailcaps having the pogo-pin contact instead of the standard spring?
Thank you in advance for your answers.
