Seller claims these are XM-L2 U3 LEDS. Don’t think they are - I can see the 6 “segments” in the LED and my understanding is that XM-L2 has no “segments”. Also see 3 wires - XM-L2s should have 2 wires.
Can I assume this is an XM-L? Then is it a T5, T6, or U2? Or is it even a CREE? Any help is appreciated!
Hi and welcome LumensGuy. As mentioned the led pictured is 100% not an XML led. Pretty much any cheap light these days on Ebay and from China will not have a Cree led.
The light is a diving light that takes 2 X 18650. The tricky part is it has a magnetic switch at the head (not too worried about the switch, would be happy to just have the replacement be “on” with power.)
I can’t disassemble the “guts” any more than this, assuming it’s glued?
35mm diameter. 33mm height (to base of spring.)
If I wanted to make this flashlight right, how would I do it? Is there a “drop in” available that would just fit? Any help is appreciated, pretty noob to this (trying to absorb info from the forums but there is sooo much!) Thanks again!
Or just edit the title
Now it seems answered with a question and a bunch of answers.
Edit it into a mod question, with some pics of the internals in the start post and others will chime in
