Review and teardown of an V-TAC LED Bulb model: VT-1864
9 posts / 0 new
martosound
martosound's picture
Last seen: 10 months 2 weeks ago
Hi, everybody!
I’m from Bulgaria. There is an V-TAC LED bulb brand on the market. I have bought several LED bulbs before two years. The price then was 6 EUR for VT-1864 model.
Parameters of the bulb are:
100-240V, 50/60Hz, E27, 12W, 1055Lm, 4500K, 200°, 72mA
The weight of the bulb is 160 grams.
I have measured parameters below with a PEREL E305EM5 Energy Meter
Cold Bulb 231 V 0.06 A 11.6 W cos θ=0.84
After 1 hour of work 233 V 0.06 A 10.7 W cos θ=0.76
I have measured the flicker of the bulb with a TEMD5510FX01 photodiode and Philips Oscilloscope PM3215.
Percent Flicker = 50% – quite a few.
The illumination, which I have measured by MASTECH MS6610 lux meter with a distance of 2 meters from the bulb is 100 lux.
The light is neutral white, corresponds to 75 watts incandescent bulb and the room is illuminated well..
I have measured the temperatures of the LED’s Solder-Point Temperature and bulb housing with a thermocouple K type.
Ambient Temperature – (Ta) = 17°C
Solder-Point Temperature – (Tsp)
Temperature of the Housing of the Bulb – (Th)
Work Time 15 min. 30 min. 1 hour 2 hours 3 hours 5 hours
Tsp 63°C 76°C 83°C 85°C 86°C 88°C
Th 43°C 55°C 62°C 64°C 66°C 68°C
Ta 17°C 17°C 18°C 19°C 20°C 20°C
There are 27 LEDs type 2835 on the Metal Core PCB. Every LED is made from 2 chips serially connected. The LEDs are connected in three parallel groups. Each group consists of 9 LEDs connected in series. Voltage is 54.5 V , Current is 187 mA in cold LEDs.
This is the aluminium housing covered with ThermoPlastic.
Bulb’s socket – E27 EDISON Screw.
Plastic cap on the bulb.
Top of the LED Driver. Two electrolytic capacitors are 105°C, Low ESR.
Bottom of the LED Driver. The IC on the PCB is BP2325А. The BP2325A is a high precision non-isolated buck driver with active PFC, specially designed for universal input offline constant current LED lighting.
Conclusion:
The bulbs work well for two years without any defects and problems. Heating of LEDs is within limits. No reduction of the power of light. I think this is a good and usable bulb.
Edited by: sb56637 on 09/02/2017 - 12:43
djozz
djozz's picture
Last seen: 19 hours 24 min ago
Thanks for the informative review martosound, I do not know the brand but I appreciate household bulb reviews on BLF very much.
Mitko
Mitko's picture
You`d better dont know it, i presume its a product advertise
As an engineer is a construction company i tried working with those/them, here is the E14 example of theirs
Thats just after 20mins of work in open air
And ofc they are duying like rabbits, we do actualy used those in a church that we were reconstructing, in first 6 moths we had above 50% death rate…i alarmed their head office about that issue, yet the problem stayed till we swapped them with Osrams
Their Ra and especialy R9 is awful too
Avoid that brand at any cost…at least for now till they learn how to do things right
mstar19
Best LED lighting is manufactured by Titan LED in the USA. No one can compete with the quality.
djozz
djozz's picture
Oh yeah Party
raccoon city
raccoon city's picture
Last seen: 12 min 50 sec ago
I've never even heard of Titan LED!  :FACEPALM:
mstar19
In the LED world, Titan versus the competition is like the difference of a 720 TV versus a 4K TV. No one can compare to Titan. If in Minnesota, call me at (612) 578-2352!
light-wolff
Last seen: 1 month 5 days ago
mstar19 wrote:
…, Titan versus the competition is like … 720 TV versus a 4K TV….
So Titan is 720 and the competition is 4K?
BlueSwordM
BlueSwordM's picture
Last seen: 1 week 6 hours ago
No, the opposite.
Titan is 1440p, and the competition is 720p/1080p/1440p/2160p.
Titan LED is like Lumenpulse, but with usually lower warranties and less high CRI options, along with less… overkill heatsinking options.
And like Lumenpulse, unless you have deep pockets, or are a company, steer away from them.
