Enercig 18650 2100mA (Gray)
Official specifications:
Typical capacity: 2100mAh
Minimum capacity: 2000mAh
Nominal voltage: 3.6V
Standard charge: CC/CV, 0.2C, 4.2V
Standard discharge: CC, 0.2C, 2.5V
End of charge voltage: 4.20V +/- 0.05V
End of charge current: 0.02C in CV mode
End of discharge voltage: 2.50V
Quick charge current: 4000mA, 2C
Pulse charge (Max): 12000mA, 6C bis 4.15V
Continuous maximum discharge current: 30000mA, 15C
Max. discharge current Vs. time: 30-40A > 80 seconds, 50A > 40 seconds, 60A > 30 seconds, 80A > 15 seconds, 100A > 8 seconds (Temp limit 80°C)
Initial impedance: 7 - 15mOhm
Weight: Approx: 45.5 +/- 1.5g
Operating temperature: Charging 0°C 45°C, discharging –20°C 60°C
Storage temperature: –5°C ~ 35°C
Cycle life: >300 cycles at 0.5C charge/discharge.
This is very high current batteries.
Very good discharge curves, the two cells tracks perfectly and capacity is nearly constant up to 20A.
Even at 30A the temperature raise is acceptable, but they do get hot.
Conclusion
For anybody that want to play with 30A or even more from a single cell, this is the cell, but the capacity is a bit limited.
This is a very good high current cell.
Notes and links
The batteries was supplied by ENERDan for review.
Compare to 18650 and other batteries
