Tecxus AA 2700mAh (Silver-Maroon)
Official specifications:
Nominal voltage:: 1.20V
Open circuit voltage: >=1.40V after 16h/0.1C charge
Nominal capacity: 2700mAh at 0.2C discharge to 1.0V after 16h/0.1C charge
Minimal capacity: 2500mAh at 0.2C discharge to 1.0V after 16h/0.1C charge
Weight: 33g +/-5g
Int. resistance: <25mOhm @ 1kHz
Fast charge: 2.4h at 0.5C (1350mA)
Storage temperature: –20°C ~ 40°C
Operating temperature: –10°C ~ 45°C
Cycle life: >300 cycles
Maximum temperature raise at different discharge currents: 1A:+1,1°C, 2A:+3,5°C, 3A:+6,5°C, 5A:+12,5°C, 7A:+18,7°C, 10A:+1,8°C
Some high capacity NiMH batteries.
The discharge curves tracks nicely.
Conclusion
Compared to the other tested brands of 2700mAh these cells has slightly more capacity at lower current, but voltage is also slightly lower.
Notes and links
Compare to other AA/AAA batteries: Alkaline/NiMH/Lithium
