Test/review of AW IMR16340 15C 550mAh (Red) 2016
6 posts / 0 new
HKJ
HKJ's picture
Last seen: 2 min 13 sec ago
DSC_5307
Official specifications:
  • 550 mAh Capacity
  • Nominal Voltage 3.7V
  • Lowest Discharge Voltage : 2.50V
  • Diameter 16.00mm
  • Length 34.00mm +/- 0.1mm
  • Max. discharge 8A
  • Size for reference CR123A
  • Working temperature -10 to 60 Degree Celsius
AW%20IMR16340%2015C%20550mAh%20(Red)%202016-info
CR123 sized LiIon batteries that can deliver a lot of current.
DSC_5306
DSC_5308 DSC_5309
DSC_5310
DSC_5311
AW%20IMR16340%2015C%20550mAh%20(Red)%202016-Capacity
The discharge curves looks very goo, the batteries are rated for 8A and had a perfect curve at 7A, but has trouble at 10A. This looks good.
AW%20IMR16340%2015C%20550mAh%20(Red)%202016-Temp-5.0
AW%20IMR16340%2015C%20550mAh%20(Red)%202016-Temp-7.0
As usual with these small batteries the discharge is done before I can register much heat on the battery can.
AW%20IMR16340%2015C%20550mAh%20(Red)%202016-Temp-10.0
AW%20IMR16340%2015C%20550mAh%20(Red)%202016-CapacityTimeHours
AW%20IMR16340%2015C%20550mAh%20(Red)%202016-Energy
AW%20IMR16340%2015C%20550mAh%20(Red)%202016-PowerLoadTime
AW%20IMR16340%2015C%20550mAh%20(Red)%202016-TripCurrent
AW%20IMR16340%2015C%20550mAh%20(Red)%202016-Charge
Conclusion
This 16340 battery looks to be a good high current battery.
Notes and links
The batteries was supplied by aw-akku.de for review.
Comparison to other LiIon batteries
Edited by: HKJ on 09/05/2016 - 13:17
djozz
djozz's picture
Last seen: 1 hour 47 min ago
Nice one, I can use these in my direct drive EDC. Thanks for testing!
Btw, these are not listed on aw-akku.de atm.
akhyar
akhyar's picture
Last seen: 11 months 4 days ago
Thanks for the review.
Time to stock up this AW to replace my older protected AW
MattSPL
Last seen: 1 year 4 months ago
Anybody know where I can buy these? In Europe preferably.
Thanks.
HKJ
HKJ's picture
Try the website I have put in the info box as supplier.
MattSPL
Thank you
