I was on the Texas Instruments page, looking for something, when a small banner about this boost IC rolled across the bottom edge of my vision. It claims to take input from 0.5V to 4.4V and output from 1.8V to 4.0V with a current rating up to 1.5A at 1.8V input! It has a power-saving mode that kicks in when it has a light load, so it will maintain efficiency at low outputs. It also claims to completely disconnect the load side of the circuit at shut down. I don’t know anything about boost IC’s to know whether any of this is unique or better than boost circuits we see on currently available drivers. I’d still like to see a high-current programmable boost driver developed some day. I don’t know of any currently available boost drivers that can put out 1.5A or better at 3.3V output from a 1.8V input. Here’s the product link: http://www.ti.com/product/tps61021a?HQS=pwr-alps-bcs-tps61021-btipp-pf-null-wwe Can anybody tell me whether this is a big deal or not?
I can attempt to answer some of your questions with the knowledge I've picked up over the years working on a project of mine.
First, voltage droop from cells is an important consideration. When these boost IC's are tested by the manufacturer they are connected to a benchtop power supply that is able to supply any required wattage without interruption. This is not the same with batteries. Individual cells suffer 'voltage droop' when put under load, which is why a cell measured at rest may be 1.5V but when measured at 1A current drain shows 1.1V.
- Alkaline: http://www.powerstream.com/AA-tests.htm (1.5V @ rest; 1V @ 2A draw)
- NiMh: https://budgetlightforum.com/t/-/7988 (1.35V @ rest; 1.2V @ 2A draw)
- Lithium: https://budgetlightforum.com/t/-/20614 (1.6V @ rest; 1.3V @ 2A draw
With that in mind, 1.8V input voltage is not a good choice. 1.2V input is more realistic so let's assume that.
Wattage is the best measure for calculating power utilitization. Watts = Volts * Amps. Using your example scenario:
1.5A * 3.3V = 4.95W output wattage
4.95W / 1.2V = 4.125A input current
So to get 1.5A @ 3.3V input from an Eneloop you need to pull 4.125A. This ignores a very important variable: efficiency of the circuit. Luckily, the datasheet for the TPS61021 has a chart that outlines converter efficiency:
At 1.2V input and 1A output, max theoretical efficiency is 70%. This means 30% of your input wattage is burned off as heat/waste and 70% makes it through as output power. Adding efficiency in to the calculation:
4.95W 7.07W
70% 100%
So to get 4.95W of output power, you need to supply 7.07W of input power. 1.2V is a non-negotiable value so the input current must change to accommodate:
7.07W / 1.2V = 5.89A input current
At nearly 6A of input current, alkaline batteries have long given up the ghost. Even NiMh and L91 cells are struggling to keep above 1V. So now instead of 1.2V input, we only have 1V available. Let's adjust our equation for that:
7.07W / 1V = 7.07A
Input current has jumped to 7A! Checking the discharge charts at 7A for those batteries brings bad news: voltage droop has lowered us to ~0.9V. Time to adjust our equation again:
7.07W / 0.9V = 7.85A
You can see where I'm going with this. There is a limit on how much current you can ask from a cell until the voltage droop puts it into a death spiral. This is not an issue with a benchtop power supply. Assuming the power supply is connected to mains voltage, you have 120V * 15A = 1800W of constant, stable power available. The datasheet is not lying: the converter is able to supply 1A @ 1.2V when plugged into a power source able to comfortably provide that wattage. The datasheet does not say this device was tested using Eneloop batteries, however.
Looking at a light like the Zebralight SC52 (an example of a light with an outstanding converter):
- Output: 300 lumens (out the front)
- Runtime on High: 55minutes (round up to 60minutes)
Eneloops are rated 2A for 60 minutes before depleted. We know the SC52 runs 60 minutes before it goes dark, so we can assume 2A was drawn from the battery.
1.2V * 2A = 2.4W
Assuming a very efficient converter (85%) let's say the emitter saw 2.04W. The forward voltage of an XM-L2 is 2.9V.
2.04W / 2.9V = 0.7A
The Cree XM-L2 datasheet tells us that at 700mA drive, we can expect ~342 lumens. If we subtract some losses for the reflector and the glass, we get ~300lm OTF.
I suppose the conclusion to be drawn is that 1.5A @ 3.3V from an alkaline/NiMh/L91 battery is not feasible. Some of the most efficient drivers on the market manage 700-800mA to the LED. The Texas Instruments chip looks very good on paper, and while it may well be a solid chip, batteries simply aren't going to provide the power necessary to provide the full output it lists.
Okay, thanks for the info. I think since the chip is made for up to 4.2V input, the best scenario is going to be in the range of 2S NiMH or 1S Li-Ion. With that being the case, I can see the 1.8V under load from 2x Eneloop as a reasonable expectation. I’m just wondering how this chip compares to other boost circuits available. I’ve seen boost drivers claim up to 500mA output from ~1.5V and up to 1A output from ~3V source. So, I thought 1.5A from 1.8V source looked special to me. But, I don’t know anything. That’s why I’m asking. :innocent:
Wait a minute! Did I just see what I think I saw? Looking at this chart again, it appears that at 3.0V input, this chip is capable of handling ~3.5A output!
Tell me I’m dreaming! :heart_eyes:
I’ve toyed around with this chip for a bit. It’s not bad, but with a single AA it gets uncomfortable beyond 500mA.
That being said, @500mA it stays in regulation in the usable range of a NiMH down to about 1V (unlike the PAM2803 where the output starts to drop immediately).
A no-name (Aldi) NiMH ran for 65 minutes at constant output current with some minor fluctuations, probably temperature-related.
A small downside is the high Vfb of 0.8V. The easiest workaround is biasing the feedback loop with the output voltage (but that makes the current regulation finicky). There are better solutions, but ultimately it comes down to available space on the driver board.
Some rough efficiency measurements @500mA, the LED was a LH351D with ~3V Vf
1.5V(in) - ~86%
1.4V 84%
1.3V 82%
1.2V 79%
1.1V 75%
at around 1.0V it starts reducing output current to ~400mA.
-Current draw with no load (but converter running) is very low, in the range of 40-50µA and some of that depends on the feedback circuitry and might be brought down further.
(Open output is possible, no zener or other output clamp necessary.)
—> Dimming via low-side FET works
—> e-switch drivers might be doable too, I’ll have to check if the standby current of an Attiny raises the no-load current draw considerably or not
Should be possible to cram the thing onto a 15mm board, I think….
Thanks for the testing kikkoman!
Another runtime test with a 1900mAh Eneloop gives pretty much the same result: 65 minutes of flat 500mA output. At ~0.95V (under load) the battery can’t keep up with the current draw and the LED starts blinking at around 0.5Hz (this speeds up if the circuit isn’t disconnected).
Yes it’s possible to fit this + FET + Attiny85 onto a 15mm single-side board:
