Dedomed XM-L2 U4 1A Issues
12 posts / 0 new
djburkes
djburkes's picture
Last seen: 3 months 2 days ago
Has anyone had any problems with dedomed XM-L2 U4 1As lately? The last 3 that I’ve dedomed (with gas) have popped on me. I’m using one of the newer fet+1 drivers from mtn with 22awg wire. Each one has popped at the bond wires. Both wires were burned through on the first two, the third still has one intact and the led barely lights up. One was on a 20mm tpad, one was on a 20mm noctigon, the third one was on a 14mm tpad. I’ve never had this issue with them before. I used a Samsung 30Q each time as well.
Mitko
Mitko's picture
Last seen: 16 hours 17 min ago
U4 binned XMLs are sometimes very sensitive to voltage( and heat)- some batches will pop up great time, especialy if direct driven
That will happen also if they overstayed in the jar
Nasty buggers they are….yet they run very cool when overdriven
And yes, it happened to me, lately nope but i depleted my u4 1a long time ago, using 1C atm
djburkes
djburkes's picture
I’m gonna try to dedome my last one with heat. We’ll see how it does.
djburkes
djburkes's picture
The hot dedome worked…hello Eagletac M25C2 Turbo with a fet+1 and dedomed XM-L2 U4 1A!!
Swib
Last seen: 9 hours 59 min ago
Very nice djburkes. Focus looks great too. Thumbs Up
If you don’t like what it looks like on the wall, take it outside.
dhvl1357
Last seen: 4 hours 54 min ago
Pardon the noob question, but does that mean you run the led out of the heatsink to heat it up and then slice off the dome with a blade?
Slow is smooth; smooth is fast.
djburkes
djburkes's picture
Yeah, just connect a couple of leads to the mcpcb that the LED is reflowed to and connect the other ends to a battery. Turn it on for about 15-20 seconds and slice the corners. Turn it on for about 15-20 seconds again and slice under the dome towards the bond wires and lift before you get there so you don’t break the wires. Then carefully clean off any left over residue. There’s a few vids floating around of members hot dedoming.
dhvl1357
Thanks, that info is much appreciated!
Cheers.
LightRider
LightRider's picture
Last seen: 1 hour 38 min ago
So do you lift from the side with the bond wires or lift up from the opposite side then flip it towards the bond wires?
djburkes
djburkes's picture
From the opposite side towards the bond wires.
LightRider
Ok. That’s what I thought but wasn’t sure
ARsee
ARsee's picture
Last seen: 6 days 13 hours ago
Tagged
Good info
