Test/review of AW 17500 1100mAh (Black) 2016
1 post / 0 new
HKJ
HKJ's picture
Last seen: 1 hour 11 min ago
DSC_5295
Official specifications:
  • Nominal Voltage: 3.7V
  • Nominal capacity: 1100mAh
  • Minimum capacity: 1000mAH
  • Internal Impedance: < 100 m Ohm at 1KHz
  • Ambient Temperature: Standard Charge : 0 C ~ 45 C, Discharge: -20 C ~ 60 C
  • Max. Discharge Rate: 2C
  • Dimensions: 17 × 51mm +/-0.5mm
  • Weight: 30g +/-2 g
AW%2017500%201100mAh%20(Black)%202016-info
One of the more uncommen LiIon sizes from AW.
DSC_5294
DSC_5296 DSC_5297
DSC_5298
DSC_5299
AW%2017500%201100mAh%20(Black)%202016-Capacity
These discharge curves tracks perfectly and the capacity is constant at any load.
AW%2017500%201100mAh%20(Black)%202016-Temp-2.0
AW%2017500%201100mAh%20(Black)%202016-Temp-3.0
At 3A the cells will warm up, but not that much.
AW%2017500%201100mAh%20(Black)%202016-CapacityTimeHours
AW%2017500%201100mAh%20(Black)%202016-Energy
AW%2017500%201100mAh%20(Black)%202016-PowerLoadTime
AW%2017500%201100mAh%20(Black)%202016-TripCurrent
AW%2017500%201100mAh%20(Black)%202016-Charge
Conclusion
This look like a good cell and this size can be useful. The capacity and current handling is not that great, but when used as replacement for CR123 the performance is more then enough.
Notes and links
Two of these batteries matches 3xCR123 fairly well in both voltage and size and the protection will prevent the batteries being damaged when the run empty.
The batteries was supplied by aw-akku.de for review.
Compare to 18650 and other batteries
