Test/review of TLife 18650B 2200mAh (Green)
3 posts / 0 new
HKJ
HKJ's picture
Last seen: 1 hour 55 min ago
Button top and flat top unprotected TLife 2200mAh cells.
TLife 18650B BT 2200mAh (Green)
DSC_6529
Official specifications:
  • Model: 18650B
  • Battery Type: Lithium-ion
  • Rechargeable: Yes
  • Protected: Yes
  • Positive terminal style: Button-top
  • Nominal voltage: 3.7V
  • Discharge end voltage: 2.75V
  • Charging voltage: 4.20 +/- 0.03 V
  • Standard charging current: 1.625 A
  • Nominal capacity: 2200mAh
  • Rated capacity (minimum): 2100mAh
  • Dimensions: (2.65 × 0.72)” / (6.73 × 1.84)cm (L x Dia.)
  • Color: Green
TLife%2018650B%20BT%202200mAh%20(Green)-info
This is a low capacity, low current cell. Tmart has this cell in four configurations, this is the unprotected button top.
DSC_6528
DSC_6530 DSC_6531
DSC_6532
DSC_6533
DSC_6534
TLife%2018650B%20BT%202200mAh%20(Green)-Capacity
The cell can deliver up to 5A before it looses capacity. The curves here looks good when staying below 5A, but as can be seen with the flat top version there is some variation between cells.
TLife%2018650B%20BT%202200mAh%20(Green)-Temp-5.0
There is no problem with temperature at 5A
TLife%2018650B%20BT%202200mAh%20(Green)-CapacityTimeHours
TLife%2018650B%20BT%202200mAh%20(Green)-Energy
TLife%2018650B%20BT%202200mAh%20(Green)-PowerLoadTime
TLife%2018650B%20BT%202200mAh%20(Green)-TripCurrent
TLife%2018650B%20BT%202200mAh%20(Green)-Charge
TLife 18650B FT 2200mAh (Green)
DSC_6543
  • Model: 18650B
  • Rechargeable: Yes
  • Protected: Yes
  • Positive terminal style: Flattop
  • Dimensions: (2.57 × 0.72)” / (6.54 × 1.84)cm (L x Dia.)
  • Color: Green
TLife%2018650B%20FT%202200mAh%20(Green)-info
This is a low capacity, low current cell. Tmart has this cell in four configurations, this is the unprotected flat top.
DSC_6542
DSC_6544 DSC_6545
DSC_6546
DSC_6547
DSC_6548
TLife%2018650B%20FT%202200mAh%20(Green)-Capacity
These two cells do not match neary as fine as above. The current handling is the same.
TLife%2018650B%20FT%202200mAh%20(Green)-Temp-5.0
No temperature problem here.
TLife%2018650B%20FT%202200mAh%20(Green)-CapacityTimeHours
TLife%2018650B%20FT%202200mAh%20(Green)-Energy
TLife%2018650B%20FT%202200mAh%20(Green)-PowerLoadTime
TLife%2018650B%20FT%202200mAh%20(Green)-TripCurrent
TLife%2018650B%20FT%202200mAh%20(Green)-Charge
Conclusion
These batteries do not win on capacity or high current, but they can easily drive a normal single cell flashlight.
I would have liked a bit better matching between the cells, but when used one at a time it is not a problem.
Notes and links
The batteries was supplied by TMart.com for a review.
Compare to 18650 and other batteries
Budda
Budda's picture
Last seen: 5 days 43 sec ago
thanks
the link on your site is broken
All my reviews, in italian and english, here: Lumenreviews.com
HKJ
HKJ's picture
Budda wrote:
thanks the link on your site is broken
Oops, thanks. I copied my internal link, instead of the public one. It is fixed now.
