Test/review of Enercig 18650 2600mAh (Gray)
1 post / 0 new
HKJ
HKJ's picture
Last seen: 1 hour 53 min ago
DSC_5326
Official specifications:
  • Typical capacity: 2600mAh
  • Minimum capacity: 2500mAh
  • Nominal voltage: 3.6V
  • Standard charge: CC/CV, 0.2C, 4.2V
  • Standard discharge: CC, 0.2C, 2.5V
  • End-of-charge voltage: 4.20V +/-0.05V
  • End-of-charge current: 0.02C
  • End-of-discharge voltage: 2.00V
  • Continuous maximum charge current: 5000mA (1.5C)
  • Continuous maximum discharge current: 20000mA (8C)
  • Continuous maximum discharge current: 30000mA (12C) with temp. limited to 80°C
  • Max. discharge current vs. time: 30-40A>33s, 50A>18s, 60A->15s, 80A>9s, 100A->3s
  • Initial impedance: 7-15mOhm
  • Weight: 44.3g +/-1.5g
  • Operating temperature: Charging 0°C ~ 45°C, discharging: -20°C ~ 60°C
  • Storage temperature: -5°C ~ 35°C
  • Cycle life: 300 times to 80% at 0.5C
Enercig%2018650%202600mAh%20(Gray)-info
A high current cells with good capacity.
DSC_5325
DSC_5327 DSC_5328
DSC_5329
DSC_5330
DSC_5331
Enercig%2018650%202600mAh%20(Gray)-Capacity
Very good discharge curves with perfect tracking and nearly constant capacity up to 20A
Enercig%2018650%202600mAh%20(Gray)-Temp-15.0
Enercig%2018650%202600mAh%20(Gray)-Temp-20.0
Enercig%2018650%202600mAh%20(Gray)-Temp-30.0
At 30A the cell temperature must not be above 80°C, it goes over the limit here, but I do first see it after I have stopped the discharge, because the temperature measure is not instantaneous.
Enercig%2018650%202600mAh%20(Gray)-CapacityTimeHours
Enercig%2018650%202600mAh%20(Gray)-Energy
Enercig%2018650%202600mAh%20(Gray)-PowerLoadTime
Enercig%2018650%202600mAh%20(Gray)-TripCurrent
Enercig%2018650%202600mAh%20(Gray)-Charge
Conclusion
This is a very good high current battery, it has fairly high capacity and can deliver a lot of current.
Notes and links
The batteries was supplied by ENERDan for review.
Compare to 18650 and other batteries
