Review: Convoy Diffuser for S2+
15 posts / 0 new
stephenk
stephenk's picture
Last seen: 3 min 2 sec ago
Disclaimer
The diffusers reviewed were purchased by myself.
Product link: https://www.aliexpress.com/store/product/Max-inner-diameter-24-5mm-flash...
Introduction
The white plastic diffusers reviewed have a maximum internal diameter of 24.5mm, and are designed to fit the Convoy S2, S2+, S3, S4, S5, S6, S7, and S8. I tested them on a black Convoy S2+ with new firmware. They may also fit other similar tube lights with an approximately 24.5mm external diameter tubes. In fact, a photo on Convoy’s website shows it being used on a Roche F12.
Design
The manufacturer specifications are as follows:
outer diameter:28mm
inner diameter:24.5mm
length:60mm
weight:6.5g/pcs
Material:plastic
The diffuser sits around the end of the flashlight tube, but doesn’t clip onto place. Despite the lack of clipping, it remained surprisingly stable on the end of tube when waving it around. The diffuser is quite solid, and will take quite a few knocks or mis-treatment when not fitted on the light.
Diffusion
The diffuser does a great job of diffusing the light almost 360 degrees around the light as shown in the photos. As expected there is more “throw” forward than behind.
There appears to be a small amount of tint shift, which seems to be slightly cooler. However, in reality this is not much of an issue, and may just be due to the evening out of the overall tint (which is variable between the hotspot and spill beam when not diffused). These photos are with Convoy S2+ with 1A (cool white), 4C (neutral white), and 7A (warm white) emitters.
Heat handling
As with most tube lights, the more powerful Convoy S2+ models can heat up very quickly on high, and can even get rather toasty on medium in some ambient conditions (especially if not handheld). During testing the diffuser handled the heat better than the flashlight. When having to step down due to the flashlight getting too hot, the diffuser was experiencing no adverse affects from the heat.
If using the light as a diffuser where it is not being hand held (e.g. hanging diffuser light in tent), and not experienced with that use case, I would recommend periodically checking on the flashlight’s temperature.
Conclusion
This diffuser is great for photography (e.g. light painting, or diffused illumination), camping, or other purposes requiring a low to medium output diffused light. As with other Convoy products, the price (US$1.65 at the time of writing) is exceptionally low for the quality. Below are few photos of the diffusers in use.
Edited by: stephenk on 11/20/2016 - 05:05
MILSPEC
Last seen: 3 weeks 14 hours ago
amazing pictures! I was looking for one and now I know which item to buy! good review!
Flashy Mike
Flashy Mike's picture
Last seen: 2 hours 22 min ago
Great review and beautiful pictures! I’m going to order them.
atbglenn
atbglenn's picture
Last seen: 3 min 41 sec ago
Nice! I’m going to order a couple. BTW, your pictures are stunning!
The Miller
The Miller's picture
Last seen: 2 months 12 hours ago
nice review and nice pics
indeed nifty little thingy!
hIKARInoob
hIKARInoob's picture
Last seen: 1 hour 7 min ago
Wowwwwwww, stunning pictures!!! Amazing… seriously wow… Wink
Dwantink
Dwantink's picture
Last seen: 1 month 2 days ago
Wow!! Those pictures!! What kind of camera? Settings? Did you use for those outdoor shots? I’m glad I’ve been looking for diffusers or I probably wouldn’t have clicked on this thread. Thanks for the awesome review!!
stephenk
stephenk's picture
Thanks for the comments!
Camera Nikon D3300 and Nikon 18-55mm VR II lens. Remote shutter used. Post processed from RAW files in Adobe Lightroom 6.
Convoy S2+ output in these photos would be in the 300-400 lumen range.
From top to bottom of the three photos:
Manual, f/16, 30secs, ISO800
Manual, f/8, 30secs, ISO400
Manual, f/16, 30secs, ISO200
Keron
Keron's picture
i dont know why but in my particular diffuser from convoy requires somesort of ‘break-in’ if you get what i mean, not sure if yours had the same issue but mine appeared to have me forcefully fit it on as the S2+ bezel scrape away some of its plastic ridges inside and only then it fits and works perfectly after that
i need to stop with the hype on XP-L leds
stephenk
stephenk's picture
I haven’t found that I’ve had to purposefully ‘break them in’, though they do indeed seem to fit better each time I use them.
Splott-Light
Splott-Light's picture
Last seen: 3 days 6 hours ago
stephenk,
Thanks for your review.
Nice captures too.
Splott-Light Smile
Ouchyfoot to a New Member: Welcome CJ. Now you have to learn about buying an inexpensive flashlight and modifying it until it either blows up, or starts small fires on the moon…………
Hugh Johnson:
I, too, once lived a tragic and empty life. Then I found [portable] light.
You forgot to mention clothes. I sold most of my clothes to fund my light collection. This is actually fine, since I only go out after dark, and most people can’t see me.
Finally, I got my priorities straight.
Keron
Keron's picture
Thanks a lot for your input, maybe i got a weird one, two of them actually directly from simon at aliexpress.
caramba
caramba's picture
Last seen: 2 weeks 1 day ago
love the pictures.
Phlogiston
Last seen: 1 hour 58 min ago
Nice review, much more comprehensive than my quick text-only summary on CPF.
However, my CPF post does include some thoughts on the use of Convoy, Fenix and Nitecore diffusers with the S2+, along with some comments on a couple of other accessories, if that’s useful to anyone here.
bemymonkey
Last seen: 15 hours 27 min ago
stephenk wrote:
Camera Nikon D3300 and Nikon 18-55mm VR II lens. Remote shutter used. Post processed from RAW files in Adobe Lightroom 6. Convoy S2+ output in these photos would be in the 300-400 lumen range. From top to bottom of the three photos: Manual, f/16, 30secs, ISO800 Manual, f/8, 30secs, ISO400 Manual, f/16, 30secs, ISO200
Awesome idea using the diffusor for your pictures. I’ve just ordered some for my next night photography outing.
Are you using standard emitters in your S2(+) lights or did you mod them for High-CRI? I assume you turned up the saturation and vibrance a little in Lightroom?
