What kind of sorcery is this?
55 posts / 0 new
MAD TM26
MAD TM26's picture
Last seen: 8 months 4 weeks ago
Hi, can somebody please explain to me what’s happening here as I’m completely clueless Flat Stare
When inserted in Olight i3S battery tube… I get this reading Shocked
we buy light for a brighter tomorrow
Edited by: MAD TM26 on 12/04/2016 - 10:53
everydaysurvivalgear
everydaysurvivalgear's picture
Last seen: 2 hours 20 min ago
Your shorting out the battery. It’s using amperage from the battery so it’s giving you a higher reading. That’s my guess.
hIKARInoob
hIKARInoob's picture
Last seen: 21 min 6 sec ago
The dial is pointing at Volt (exact opposite of current on the meter), so it shouldn’t cause a short.
Gurthang
Is the tube so tight it’s squeezing out more volts?
Jerommel
Jerommel's picture
Last seen: 1 month 5 days ago
I assume it’s a NiMH battery.
Mine certainly doesn’t do that.
hexcode
Last seen: 1 week 3 days ago
Its set on Voltage so no shorts. I was too slow to post this Smile
hIKARInoob
Technology inspired by the Note 7.
Jerommel
Jerommel's picture
(PS: The tear off is still on your display)
hIKARInoob
(P.S. Don’t take it off, it will lose value! rofl)
freeme
freeme's picture
Last seen: 15 min 52 sec ago
What about other battery?
Jerommel
Jerommel's picture
Wait, did you accidentally drop a button cell in there before placing the AAA?
Otherwise i’m totally clueless about this doubling of the voltage.
Yokiamy
Yokiamy's picture
Last seen: 1 hour 6 min ago
I thougt you were measuring on the battery both times, until i realized that the second photo is not the battery, but the top view of your flashlight!
The flashlight obvious uses some sort of step-up converter
MAD TM26
MAD TM26's picture
lol! Its my spare DMM. Only got that out to confirm my other DMM isn’t the problem Silly
freeme
freeme's picture
I believe the head unit is off. He did mention battery tube.
Yokiamy wrote:
I thougt you were measuring on the battery both times, until i realized that the second photo is not the battery, but the top view of your flashlight! The flashlight obvious uses some sort of step-up converter
MAD TM26
MAD TM26's picture
Yes. Its just the i3S tube.
Tried with different AAA and still the same. Facepalm
hIKARInoob
I checked out how the inside of the i3S looks like; it’s just a plain tube with a spring in it… So there is no capacitor or something that could bump voltage…
If the multimeter is broken it could still draw power. Also you will have resistance in the battery tube it’s self that could be messing up the reading. It’s not a true rms meter.
Yokiamy
Yokiamy's picture
My bad, i should have read better before posting.
I haven’t got any clue
Jerommel
Jerommel's picture
Not possible because the (+) of the battery is not connected to anything (except to the meter probe)
Jerommel
Jerommel's picture
Wuut??
So what happens if you stick the (+) probe in the battery tube, measure voltage over tube and spring?
freeme
freeme's picture
Could it be the exposed wrapper at cathode?
hIKARInoob
Maybe the LSD makes the meter trip or something?
pilotdog68
pilotdog68's picture
^^^^^Best comment Big Smile
MAD TM26
MAD TM26's picture
My other AAA are all in great shape (not tear no dent) and I still get the same reading when inserted in the magical tube Smile
@Jerommel
I’m not sure understand you correctly? You mean like the second photo?
I have had the same issue with LSD lol
What’s really going on.
Jerommel
Jerommel's picture
MAD TM26 wrote:
@Jerommel
Yeah, but without the battery, because apparently the tube and spring add 1.3 Volts to it, so you should measure the voltage over tube and spring.
So if you can, stick the (+) probe inside the tube touching the spring.
It should read 1.3 Volts somehow.
Speaking of LSD, maybe there’s some acid in the bottom of the tube, maybe from a leaky alkaline?
I don’t know what voltage aluminium and chrome produce, but that could be it.
Does the light work properly?
hIKARInoob
If there is acid, that would explain the doubling of voltage; acid is the same as LSD, hence its voltage value must be identical.
JohnnyMac
JohnnyMac's picture
Last seen: 2 years 4 months ago
Looks like you are taking the second, higher, reading with the cell installed and the head off. Looks like the driver is not in the head but in the body and is boosting voltage so the LED can light up. This is the only way a NiMH or AA can work in a flashlight with a single cell. Pretty much everyone who posted before me knows this as well so I must clearly be missing something here. In the second pic are you measuring at the tail with the tail cap off or at the front of the battery tube with the head off? It’s really hard to see exactly what you are doing.
Jerommel
Jerommel's picture
Not possible, because the (+) is not connected to the assumed booster in the tail, which incidentally isn’t there..
It’s just a tube with a spring.
MAD TM26
MAD TM26's picture
Jerommel wrote:
MAD TM26 wrote:
@Jerommel
You nailed it!! Acid from alkaline battery that came with it and leaked inside. Thumbs Up
JohnnyMac
JohnnyMac's picture
You posted before I could get my edited post saved. So this light has the cell reversed with + in the back like the S1?
