Test/review of Gpower 18650 3000mAh (Yellow-black)
2 posts / 0 new
HKJ
HKJ's picture
Last seen: 2 days 7 hours ago
DSC_6932
Official specifications:
  • Capacity: 3000mAh
  • MAX Discharge Current: 40A
  • CDR (Continuous Discharge Current): 20A
  • Voltage: 3.7v
  • Material: Li-ion
  • Length: 65.30mm
  • Diameter: 18.20mm
  • Top: Flat top(18mm 65mm)
  • Warranty: 12 months
Gpower%2018650%203000mAh%20(Yellow-black)-info
A high capacity high current rated cell.
DSC_6931
DSC_6933 DSC_6934
DSC_6935
DSC_6936
DSC_6937
Gpower%2018650%203000mAh%20(Yellow-black)-Capacity
This chart is a mess, the two cells has different capacity. At 0.2A A was 2435mAh and B was 2749mAh, neither reach the specified 3000mAh
Gpower%2018650%203000mAh%20(Yellow-black)-Temp-15.0
Both cells can handle 15A without getting too hot.
Gpower%2018650%203000mAh%20(Yellow-black)-Temp-20.0
At 20A the B cell gets too hot and I terminate the test.
Gpower%2018650%203000mAh%20(Yellow-black)-Temp-30.0
The B cell cannot handle 30A, the A cell gets too hot after some time.
Gpower%2018650%203000mAh%20(Yellow-black)-CapacityTimeHours
Gpower%2018650%203000mAh%20(Yellow-black)-Energy
Gpower%2018650%203000mAh%20(Yellow-black)-PowerLoadTime
Gpower%2018650%203000mAh%20(Yellow-black)-TripCurrent
Gpower%2018650%203000mAh%20(Yellow-black)-Charge
Conclusion
I do not like these cells, both are below specifications and they are very different.
As 3000mAh high current cells they are bad.
Notes and links
The batteries was supplied by gpower-battery.com for a review.
Compare to 18650 and other batteries
Keron
Keron's picture
thanks for revealing another not so good cell
You’re not wining, you’re surviving.
